查看: 5424|回复: 12
Coding style 强烈推荐
发表于 2006-12-17 01:08:02 | 显示全部楼层 |阅读模式
内容简明扼要,介绍了那些在仿真和综合时容易出问题的代码风格。有利于你纠正自己的写作风格,写出高质量的代码。
Knowing which coding styles can cause mismatches between pre-and post-synthesis simulations ,understanding why mismatches might occur,and avoiding error-prone coding styles will greatly reduce RTL design flaws and the debug time necessary to fix the mismatches.As ASICs continue to increase in size ,the ability to run 100% coverage regression tests after each synthesis turn is becoming more impractical,Designes must use every means available to reduce risk early in teh design cylcle.
RTL Coding Styles That Yield Simulation and Synthesis Mismatches.pdf
43.35 KB, 下载次数: 57 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2006-12-17 10:55:19 | 显示全部楼层
A paper or manual?
Who write this one?
 楼主| 发表于 2006-12-17 17:14:50 | 显示全部楼层
a paper.
Author:
        Don Mills
        L3 Communications
        Clifford E.Cummings
        Sunbrtst Design, Inc.
发表于 2007-1-21 18:40:09 | 显示全部楼层
资料还是不错的
发表于 2007-6-20 10:59:59 | 显示全部楼层
不错的资料,谢谢共享
发表于 2010-7-31 23:19:43 | 显示全部楼层
好东西
谢谢
发表于 2010-8-5 10:05:32 | 显示全部楼层
谢谢共享
发表于 2010-8-5 18:18:13 | 显示全部楼层
看看!!!!!!
发表于 2010-8-5 18:52:51 | 显示全部楼层
thanks
发表于 2010-8-8 10:35:14 | 显示全部楼层
关于代码风格的,下来看看
GMT+8, 2025-12-26 17:39 , Processed in 0.031895 second(s), 7 queries , Gzip On, Redis On.
