查看: 5353|回复: 7
[讨论] ACTEL的fpga AEP125上电不需要控制上电顺序吗?是不是和atera和xilinx不一样啊?
发表于 2012-9-24 18:06:24 | 显示全部楼层 |阅读模式
 楼主| 发表于 2012-9-24 18:25:30 | 显示全部楼层
自己顶一下,proasic3系列手册上没有明确说上电顺序问题,只说保证满足各个电平的条件,不知道是不是不需要控制上电顺序。
发表于 2012-9-24 19:37:38 | 显示全部楼层
一般core最先
 楼主| 发表于 2012-9-26 11:43:19 | 显示全部楼层
The I/O bank VMV pin must be tied to the VCCI pin within the same bank. Therefore, the supplies that
need to be powered up/down during normal operation are VCC and VCCI. These power supplies can be
powered up/down in any sequence during normal operation of IGLOO, IGLOO nano, IGLOO PLUS,
ProASIC3L, ProASIC3, and ProASIC3 nano FPGAs. During power-up, I/Os in each bank will remain
tristated until the last supply (either VCCIBx or VCC) reaches its functional activation voltage. Similarly,
during power-down, I/Os of each bank are tristated once the first supply reaches its brownout
deactivation voltage.
发表于 2014-4-24 12:01:08 | 显示全部楼层
一般core最先
发表于 2014-4-24 20:17:03 | 显示全部楼层
谢谢楼主
发表于 2014-4-27 00:36:20 | 显示全部楼层
i need lic
发表于 2014-4-27 01:18:46 | 显示全部楼层
great info
GMT+8, 2025-12-30 09:30 , Processed in 0.026864 second(s), 6 queries , Gzip On, Redis On.
