查看: 7883|回复: 7
急~~Sentaurus 破解安装lmgrd出现问题 ,求各位大神帮帮忙~~~
发表于 2012-9-21 11:13:16 | 显示全部楼层 |阅读模式
lmgrd运行情况如下[wangwei@localhost jqx]$ lmgrd
[wangwei@localhost jqx]$ 20:00:56 (lmgrd) -----------------------------------------------
20:00:56 (lmgrd)   Please Note:
20:00:56 (lmgrd)
20:00:56 (lmgrd)   This log is intended for debug purposes only.
20:00:56 (lmgrd)   In order to capture accurate license
20:00:56 (lmgrd)   usage data into an organized repository,
20:00:56 (lmgrd)   please enable report logging. Use Macrovision's
20:00:56 (lmgrd)   software license administration  solution,
20:00:56 (lmgrd)   FLEXnet Manager, to  readily gain visibility
20:00:56 (lmgrd)   into license usage data and to create
20:00:56 (lmgrd)   insightful reports on critical information like
20:00:56 (lmgrd)   license availability and usage. FLEXnet Manager
20:00:56 (lmgrd)   can be fully automated to run these reports on
20:00:56 (lmgrd)   schedule and can be used to track license
20:00:56 (lmgrd)   servers and usage across a heterogeneous
20:00:56 (lmgrd)   network of servers including Windows NT, Linux
20:00:56 (lmgrd)   and UNIX. Contact Macrovision at
20:00:56 (lmgrd)   www.macrovision.com for more details on how to
20:00:56 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
20:00:56 (lmgrd)   for your enterprise.
20:00:56 (lmgrd)
20:00:56 (lmgrd)
20:00:56 (lmgrd)
20:00:56 (lmgrd) FLEXnet Licensing (v10.8.6.0 build 54361 i86_re3) started on localhost.localdomain (linux) (9/20/2012)
20:00:56 (lmgrd) Copyright (c) 1988-2007 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
20:00:56 (lmgrd) US Patents 5,390,297 and 5,671,412.
20:00:56 (lmgrd) World Wide Web:  http://www.macrovision.com
20:00:56 (lmgrd) License file(s): /home/jqx/sentaurus/license/license.dat
20:00:56 (lmgrd) lmgrd tcp-port 27000
20:00:56 (lmgrd) Starting vendor daemons ...
20:00:56 (snpslmd) FLEXnet Licensing version v10.8.5.3 build 59306 i86_re3
20:00:56 (lmgrd) Started snpslmd (internet tcp_port 50252 pid 4502)
20:00:57 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_10.9.3
20:00:57 (snpslmd) Server started on localhost.localdomain for: SSS
20:00:57 (snpslmd) AdvanceCalibration_all AdvancedCalibration_all AN-Impl3D_all
20:00:57 (snpslmd) Dessis-3D_all        Dessis-BONSIM_all Dessis-DensityGrad_all
20:00:57 (snpslmd) Dessis-Ferro_all Dessis-FloatingGate_all Dessis-GateLeakage_all
20:00:57 (snpslmd) Dessis-Hetero_all Dessis-Hydro_all Dessis-kpGain_all
20:00:57 (snpslmd) Dessis-Laser_all Dessis-LED_all      Dessis-MixedMode_all
20:00:57 (snpslmd) Dessis-Mono-Semicond_all Dessis-MonteCarlo_all Dessis-Noise_all
20:00:57 (snpslmd) Dessis-Optic_all Dessis-Parallel4_all Dessis-Parallel_all
20:00:57 (snpslmd) Dessis-PMI_all       Dessis-Radiation_all Dessis-Reliability_all
20:00:57 (snpslmd) Dessis-Schroedinger_all Dessis-SiGe_all Dessis-Thermo_all
20:00:57 (snpslmd) Dessis-Traps_all Dessis-VectorOptic_all Dessis_all
20:00:57 (snpslmd) Dfisetools_all       Dios-3D_all     Dios-MC_all
20:00:57 (snpslmd) Dios-PDEF_all        Dios-SDO_all    Dios_all
20:00:57 (snpslmd) DiosSmall_all        Dip_all         Emlab-Dessis_all
20:00:57 (snpslmd) Emlab-Farfield_all Emlab-Nonuniform-2D_all Emlab-Nonuniform-3D_all
20:00:57 (snpslmd) Emlab-Static_all Emlab-Thermal_all Emlab-Uniform-2D_all
20:00:57 (snpslmd) Emlab-Uniform-3D_all Emlab_all       emw-farfield_all
20:00:57 (snpslmd) emw-nonuniform-2d_all emw-nonuniform-3d_all emw-sdevice_all
20:00:57 (snpslmd) emw-static_all       emw-thermal_all emw-uniform-2d_all
20:00:57 (snpslmd) emw-uniform-3d_all emw_all           Floops-1D-MC_all
20:00:57 (snpslmd) Floops-1D_all        Floops-2D-MC_all Floops-2D_all
20:00:57 (snpslmd) Floops-3D-MC_all Floops-3D_all       Floops-Parallel4_all
20:00:57 (snpslmd) Floops-Parallel_all Inspect_all      Interfise_all
20:00:57 (snpslmd) ISExtract_all        Ligament_all    LigamentFE_all
20:00:57 (snpslmd) Mesh1D_all   Mesh2D_all      Mesh3D_all
20:00:57 (snpslmd) Noffset-3D_all       ParDiSo_all     Prolyt_all
20:00:57 (snpslmd) sde_all              sdevice-3d_all  sdevice-densitygrad_all
20:00:57 (snpslmd) sdevice-ferro_all sdevice-floatinggate_all sdevice-gateleakage_all
20:00:57 (snpslmd) sdevice-hetero_all sdevice-hydro_all sdevice-kpgain_all
20:00:57 (snpslmd) sdevice-laser_all sdevice-led_all sdevice-mixedmode_all
20:00:57 (snpslmd) sdevice-montecarlo_all sdevice-noise_all sdevice-optic_all
20:00:57 (snpslmd) sdevice-parallel4_all sdevice-parallel_all sdevice-pmi_all
20:00:57 (snpslmd) sdevice-radiation_all sdevice-reliability_all sdevice-schroedinger_all
20:00:57 (snpslmd) sdevice-sige_all sdevice-thermo_all sdevice-traps_all
20:00:57 (snpslmd) sdevice-vectoroptic_all sdevice_all  sdevicemonosemicond_all
20:00:57 (snpslmd) sprocess-an-imp3d_all sprocess-parallel4_all sprocess-parallel_all
20:00:57 (snpslmd) sprocess2d_all       sprocess2dmc_all sprocess3d_all
20:00:57 (snpslmd) sprocess3dmc_all sprocess_all        sprocessmc_all
20:00:57 (snpslmd) sup2lig_all  swb-advanced_all swb_all
20:00:57 (snpslmd) Sxtract_all  Tdx_all         Tecplot_all
20:00:57 (snpslmd) TecplotSmall_all Ted_all             TedSmall_all
20:00:57 (snpslmd) alien2lig_all        amat-calib_all  Devise_all
20:00:57 (snpslmd) Devise-3D_all        Dfisetools-Topo_all GENESISe_all
20:00:57 (snpslmd) Noffset-2D_all       OptimISE-DOE_all OptimISE-Iterative_all
20:00:57 (snpslmd) OptimISE-RSMOpt_all OptimISE-Statistical_all prmspx_visual_all
20:00:57 (snpslmd) sde3d_all    sdevcie-laser_all sparallel_all
20:00:57 (snpslmd) spcmcalib_all        spcmstd_all     sprocesskmc_all
20:00:57 (snpslmd) sprocessmpp_all sptopography2d_all vsea-calib_all
20:00:57 (snpslmd)
20:00:57 (snpslmd) Licenses are case sensitive for TE_CATS
20:00:57 (snpslmd)
20:00:57 (snpslmd) EXTERNAL FILTERS are OFF
20:00:57 (lmgrd) snpslmd using TCP-port 50252
20:00:57 (snpslmd) Serving features for the following vendor names:
snpslmd  CADABRA  EPIC  ISE-TCADd  TE_CATS  adalmd  anagram  archprod  avantd  chrysalisd  everest  hscd  innologd  la_dmon  leda  metasoftd  nassd  numeritchd  saber_dmn  sandwork  sigmacd  slat  snpsOEM1  snpsOEM2  snpsOEM3  snpsOEM4  snpsOEM5  snpsOEM6  snpsOEM7  snpsOEM8  snpsOEM9  ssilmd  synopsysd  tmald  vcsd
20:00:57 (snpslmd) ------------------------------------------------------------------
20:00:57 (snpslmd) Checking the integrity of the license file....
20:00:57 (snpslmd) Valid SSS feature found.
20:00:57 (snpslmd) The feature is needed to enable the other keys in your license file.
license.dat文件如下
SERVER localhost.localdomain 000c29699f87 27000
DAEMON snpslmd /home/jqx/sentaurus/SCL/linux/bin/snpslmd
FEATURE SSS snpslmd 1.0 31-dec-2020 uncounted 4E317115FD68174DEC3B \
VENDOR_STRING="69656 d1d88 34cc3 3f943 c7eb9 df1ac c59a4 23589 \
aa9a3 196" HOSTID=000c29699f87 ISSUER="Team ZWT 2006" \
NOTICE="Licensed to mammoth//ZWT 2006 [PLEASE DO NOT DELETE THIS \
SSS KEY]" SN=RK:1978-0:001224:0 START=1-jan-2006
PACKAGE EFA_Synopsys_1 snpslmd 2019.12 60A0B09179801CF480B8 COMPONENTS="AdvanceCalibration_all \
sde_all sdevice-3d_all sdevice-densitygrad_all sdevice-ferro_all sdevice-floatinggate_all \
sdevice-gateleakage_all sdevice-hetero_all sdevice-hydro_all sdevice-kpgain_all \
sdevice-laser_all sdevice-led_all sdevice-mixedmode_all sdevice-montecarlo_all \
sdevice-noise_all sdevice-optic_all sdevice-parallel4_all sdevice-parallel_all \
sdevice-pmi_all sdevice-radiation_all sdevice-reliability_all sdevice-schroedinger_all \
sdevice-sige_all sdevice-thermo_all sdevice-traps_all sdevice-vectoroptic_all sdevice_all \
sdevicemonosemicond_all sprocess-an-imp3d_all sprocess-parallel4_all sprocess-parallel_all \
sprocess2d_all sprocess2dmc_all sprocess3d_all sprocess3dmc_all sprocess_all sprocessmc_all \
sup2lig_all swb-advanced_all swb_all Sxtract_all Tdx_all Tecplot_all TecplotSmall_all \
Ted_all TedSmall_all alien2lig_all amat-calib_all Devise_all Devise-3D_all \
Dfisetools-Topo_all GENESISe_all Noffset-2D_all OptimISE-DOE_all OptimISE-Iterative_all \
OptimISE-RSMOpt_all OptimISE-Statistical_all prmspx_visual_all sde3d_all sdevcie-laser_all \
sparallel_all spcmcalib_all spcmstd_all sprocesskmc_all sprocessmpp_all sptopography2d_all \
vsea-calib_all" ck=173
PACKAGE EFA_Synopsys_2 snpslmd 2019.12 10D0A0215EA04DCA2D65 COMPONENTS="AdvanceCalibration_all \
AdvancedCalibration_all AN-Impl3D_all Dessis-3D_all Dessis-BONSIM_all Dessis-DensityGrad_all \
Dessis-Ferro_all Dessis-FloatingGate_all Dessis-GateLeakage_all Dessis-Hetero_all \
Dessis-Hydro_all Dessis-kpGain_all Dessis-kpGain_all Dessis-Laser_all Dessis-LED_all \
Dessis-MixedMode_all Dessis-Mono-Semicond_all Dessis-MonteCarlo_all Dessis-Noise_all \
Dessis-Optic_all Dessis-Parallel4_all Dessis-Parallel_all Dessis-PMI_all \
Dessis-Radiation_all Dessis-Reliability_all Dessis-Schroedinger_all Dessis-SiGe_all \
Dessis-Thermo_all Dessis-Traps_all Dessis-VectorOptic_all Dessis_all Dfisetools_all \
Dios-3D_all Dios-MC_all Dios-PDEF_all Dios-SDO_all Dios_all DiosSmall_all Dip_all \
Emlab-Dessis_all Emlab-Farfield_all Emlab-Nonuniform-2D_all Emlab-Nonuniform-3D_all \
Emlab-Static_all Emlab-Thermal_all Emlab-Uniform-2D_all Emlab-Uniform-3D_all Emlab_all \
emw-farfield_all emw-nonuniform-2d_all emw-nonuniform-3d_all emw-sdevice_all emw-static_all \
emw-thermal_all emw-uniform-2d_all emw-uniform-3d_all emw_all Floops-1D-MC_all Floops-1D_all \
Floops-2D-MC_all Floops-2D_all Floops-3D-MC_all Floops-3D_all Floops-Parallel4_all \
Floops-Parallel_all Inspect_all Interfise_all ISExtract_all Ligament_all LigamentFE_all \
Mesh1D_all Mesh2D_all Mesh3D_all Noffset-3D_all ParDiSo_all Prolyt_all" ck=226
FEATURE EFA_Synopsys_1 snpslmd 2019.12 31-dec-2019 9999 6E51E1955AEECAA1542B \
VENDOR_STRING=^1Platform:ALL+S SUPERSEDE ISSUER=SYNOPSYS ISSUED=11-jul-2001 ck=238 \
START=11-jul-2001
FEATURE EFA_Synopsys_2 snpslmd 2019.12 31-dec-2019 9999 8EE1D155713427AFB141 \
VENDOR_STRING=^1Platform:ALL+S SUPERSEDE ISSUER=SYNOPSYS ISSUED=11-jul-2001 ck=216 \
START=11-jul-2001
请问各位有谁知道这个问题的吗?
帮我解答一下吧
发表于 2012-9-21 20:30:16 | 显示全部楼层
哇好残酷啊
 楼主| 发表于 2012-9-21 21:22:41 | 显示全部楼层
自己顶一个
 楼主| 发表于 2012-9-25 00:22:05 | 显示全部楼层
没有人么?
发表于 2012-9-25 00:27:01 | 显示全部楼层
Does the hostID in license.dat (000c29699f87) match with the hostID of computer which can be seen via "hostid" command ?
 楼主| 发表于 2012-9-25 00:36:56 | 显示全部楼层
回复 5# hoangt
   yes,of course
 楼主| 发表于 2012-9-25 01:01:24 | 显示全部楼层
算了,我自己弄好了,不用大家帮忙了。。。说来这个东西就像实验一样要看人品的。。。
发表于 2012-12-20 23:25:34 | 显示全部楼层
回复 7# jingqixiang
    楼主,能不能告诉是怎么调好的呢,我也是到这里就运行不下去了,
GMT+8, 2025-12-19 03:10 , Processed in 0.028410 second(s), 7 queries , Gzip On, Redis On.
