查看: 3654|回复: 0
[求助] 关于system generator的软硬件设计问题
发表于 2012-9-19 15:31:37 | 显示全部楼层 |阅读模式
大家好,我用到了system generartor(SG)里面的edk模块,SG和EDK之间通过shared memory进行通信。我首先建立一个EDK的xps工程,可以正常生成网表和bit文件。当我在SG里面导入这个xps工程后,由于加载了SG的shared memory模块,使xps的硬件结构发生了变化,然后我可以正常生成网表,但是生成bit文件的时候却不成功,提示一大堆让我费解的错误。不知道是否有人这么操作过,还请不吝赐教。
ERROR:MapLib:979 - LUT5 symbol
   "RS232_Uart_1/RS232_Uart_1/UARTLITE_CORE_I/UARTLITE_RX_I/fifo_din_1_rstpot"
   (output
   signal=RS232_Uart_1/RS232_Uart_1/UARTLITE_CORE_I/UARTLITE_RX_I/fifo_din_1_rst
   pot) has input signal
   "RS232_Uart_1/RS232_Uart_1/UARTLITE_CORE_I/UARTLITE_RX_I/rx_2" which will be
   trimmed. See Section 5 of the Map Report File for details about why the input
   signal will become undriven.
ERROR:MapLib:979 - LUT3 symbol
   "RS232_Uart_1/RS232_Uart_1/UARTLITE_CORE_I/UARTLITE_RX_I/running_rx_2_AND_7_o
1" (output
   signal=RS232_Uart_1/RS232_Uart_1/UARTLITE_CORE_I/UARTLITE_RX_I/running_rx_2_A
   ND_7_o) has input signal
   "RS232_Uart_1/RS232_Uart_1/UARTLITE_CORE_I/UARTLITE_RX_I/previous_rx" which
   will be trimmed. See Section 5 of the Map Report File for details about why
   the input signal will become undriven.
GMT+8, 2025-12-14 10:29 , Processed in 0.010680 second(s), 3 queries , Gzip On, Redis On.
