楼主: chainingruijie1
[求助] 【问题】关于UVM的复用
 楼主| 发表于 2012-9-26 09:43:24 | 显示全部楼层
Sequence Item Overrides:
In principle, the same factory override mechanism could be used for sequence_items. However, it would require a driver
to be written with prior knowledge of the derived type, so that it could cast a received sequence_item to the right type.
Therefore, from a practical point of view, sequence_items are unlikely to be overriden.
根据这么说可能item的override不是太灵,不知道我理解的对不对
发表于 2012-9-29 13:51:20 | 显示全部楼层
BFM调用item提供的function或者task来完成数据的pack或者unpack,这样,只要接口不变,数据结构怎么变,都可以只override item提供的pack/unpack。
发表于 2012-10-13 15:03:22 | 显示全部楼层
No you need not change any bit of code,use instance_override_by_* methods from the factory ovrride the instance of sequence_item in your sequence
发表于 2012-10-13 15:11:58 | 显示全部楼层
First you should review the UVM guide and OVM guide, Be sure you master the basic verification mthodology!
发表于 2012-10-23 14:23:09 | 显示全部楼层
ye guanzhu
发表于 2012-10-25 09:53:10 | 显示全部楼层
回复 10# tbb2009
    you have got the point about this question!
发表于 2012-12-7 13:58:10 | 显示全部楼层
同问
GMT+8, 2025-12-22 08:44 , Processed in 0.015141 second(s), 3 queries , Gzip On, Redis On.
