查看: 2436|回复: 0
[招聘] 【社会招聘】LSI中国2012年9月7日职位更新
发表于 2012-9-7 11:36:45 | 显示全部楼层 |阅读模式
有意者,请将简历发至:
Tracey.zheng@lsi.com
如有任何疑问,请发送邮件至Tracey.zheng@lsi.com或拨打电话021-24191709.
也可加我msn: zql975504@hotmail.com
或微博:
http://www.weibo.com/u/1752448637
QQ: 2306464914
!!!友情提示:本页发布的所有职位均为社招职位,不面向应届毕业生。LSI的校园招聘线上系统将于913启动,请各位同学届时通过51job的校招系统投递简历并了解相关宣讲行程。谢谢!
1.
ASIC Customer Design Engineer-上海
Job Description
- LSI Corporation offers an excellent opportunity to contribute to a team environment and to grow personal career path. You will be working with internal and external customers to develop state of the art IC solutions utilizing LSI's leading edge CMOS cell-based ASIC technologies. You will have responsibility for ASIC designs through all of the key development and implementation phases including RTL analysis, synthesis, design optimization, timing verification, simulation, test insertion, physical design, vector generation, and post-prototype test support. Candidates will have opportunity to work on the latest 40nm/28nm designs.
Detail design tasks include
- Presales support (die size support, memory generation, addressing customer questions and concerns.)
- RTL analysis & synthesis
- Top level and block level physical design Implementation (bonding, floor planning, power structure insertion, place and route, timing closure)
- Test structure insertion/silicon testing debug
- Formal verification
- Static timing analysis
- Cross talk analysis
- Power verification
- Physical verification
- Overtime, candidates are expected to develop the most of above skills. Candidates who have the desire to seek the in-depth and broad technical challenge should apply.
Requirements/Qualifications (Education)
Education: BS/MS Electrical, Computer Engineering or Equivalent
- 2+ years experience in ASIC design and implementation. Familiar with all aspects of ASIC design implementation flow and specializing in physical design or DFT implementation. The ideal candidate should have successfully completed at least one mid-size ASIC or ASSP tapeout.
- Experience with Synopsys Astro or ICC is a plus. Other physical design tool experience will also be considered. Scripting skill is a strong plus.
- Experience in debugging prototypes considered a strong plus. Knowledge and hands on use of test insertion / vector generation / verification a plus. Some experience with Signal integrity a bonus.
- Experience in working with customers is desired. Must possess excellent communication skills and strong self-motivation. Be able to effectively communicate with other members of the design team, supporting organizations, and management. This position requires frequent interface with LSI customers
- Candidates have ONE OR MORE good skill sets of the following areas are highly encouraged to apply:
- RTL Analysis/Synthesis/STA: The ideal candidate should have strong skills for the front-end of design
- implementation which includes RTL Analysis, Synthesis Strategies, and STA setup for complex ASIC
- environments. This would include strategies for power management.
OR
Physical Design Implementation: The ideal candidate should be strong in the Physical Design (at least at block level) which includes floor planning, design closure, & STA. Having strong DRC & LVS skills are a plus. Strong
- Synopsys Astro/ICC experience a plus. Having Mentor Calibre skills a plus.
- OR
- Physical Verification: The ideal candidate should have in-depth understanding of transistor level IC fabrication process, familiar with major foundries(TSMC or SMIC) runsets and verification flow, custom layout experience is a plus, successfully done LVS/DRC/ERC/Antenna check for multiple tapeouts is a strong plus. Understanding of DFM is a plus. Calibre experience is a plus.
- OR
- DFT: The ideal candidate should be strong in all DFT (Design for Test) for all aspects. This would include
- scan/TDF, TestKompress, MEMBIST/BISR, JTAG and etc. Having STA skills is a plus for all aspects of test. Responsible for support / debug of customer designs after delivery of prototypes
2.
SerDes Field Coreware Engineer  -上海
Job Description
The Field Coreware Engineer is a challenging and cutting-edge position with responsibilities to work closely with LSI internal IP development, foundation IP, methodology, and design center engineering/development teams to support complex ASIC designs. This position will support LSI/3rd Party IP for customer ASIC and internal ASSP designs providing “Best in Class” support
Strong communications skills are important for this position. This is a position for developing and honing verbal and written communication skills, and for interfacing to many different people and engineering organizations within and external to LSI. Position requires regular interface with LSI customers. A successful candidate will have a strong design background, debug skills, good scripting skills, and hands on experience with IP integration. This position will require travel and onsite support at times at the customer site.
- 5-10+ years experience as an application, design or development engineer
- Experience developing IP or integrating/implementing IP in an SOC (System on Chip)
- Prior experience with RTL coding and verification a plus
- Knowledge in one or more of the following IP:
o SerDes
o Memory IF: DDR, etc,
o Protocol IP : PCIe, Ethernet (example: 10G-KR4), etc…
o Processors/Subsystems
o SOC interconnect: AMBA, etc.
- Must have the ability to understand Specifications
- Experience with EDA tools such as Simulators (Synopsys VCS, Cadence NC-Verilog, Mentor ModelSim), Synopsys IC Compiler, Synopsys PrimeTime SI
- Understanding of the ASIC Design Flow
o Design Closure STA (Static Timing Analysis) Constraints
o Simulation/Debug
o Basic understanding of DFT (Design for Test)
o Basic Understand Power Estimation & Optimization
- Experience Debugging Simulations
- Basic Understanding of System Architecture/Applications
- Prototyping/Emulator knowledge a plus
- Soft/People Skills:
o Customer support skills (Communication, Positioning etc.)
o Issue Solving
o Conflict Management
- Willing to learn, expand horizons
- Positive attitude and ownership taking a must
3.
Serdes Analog/Mixed-signal Design Engineer-
上海
Job Description
- Design and simulate mixed-signal circuitry for high-speed transceiver cores or products
- Create design documents based on the mixed-signal design flow
- Supervise physical layouts of analog circuits
- Work with test engineers to validate designs in silicon
- BSEE/MSEE with 3 year of direct experiences in design of mixed-signal circuits, such as high-speed transceivers, amplifiers, phase-locked loops, and digital-to-analog converters. Knowledge in high-speed Serdes is a plus
4.
Verification Engineer-上海
Job Responsibilities
Duties will include working with a Verification Team to develop reusable block and system level verification environment using high level verification language to support ASIC development.
Review RTL architectural and implementation specifications. Develop test plan, create stimulus drivers, monitors, reference models, scoreboards, protocol checkers to verify function and performance of advanced multiprotocol networking ASICs.
Define and develop application tests required to verify ASICs meet functional and performance goals.
Define and implement functional coverage plans.
Define and implement code coverage plans. Develop testing and regression methodologies for new verification flow.
Coordinate test plan implementation and
regressions with remote team.
Incorporate reusability into all aspects of the verification environment.
Develop/maintain/enhance environment tools/scripts/makefiles.
Required:
- Proven ASIC Design Verification skills
- Proficient with high level verification languages such as System Verilog
- Knowledge of data and telecommunication networking
- Proficient with one or more scripting languages, such as Shell, Perl and TCL.
- Superior debugging skills for large ASIC designs
- Strong written and verbal communication skills
- Adaptable to evolving customer requirements
Education/Certifications:
Required Degree: BS
Preferred Degree: MS
Preferred Major: Electrical Engineering or related discipline
5.
Software Quality Assurance (SQA) Engineer –
上海
Come join us! Exceptional possibilities await you at LSI’s rapidly expanding Flash Component Division (FCD) in Shanghai. We are one of the top innovators in data storage today, by pioneering use of standard flash in consumer, and enterprise applications, we revolutionize storage in reliability, performance and energy efficiency. LSI Sandforce Flash Storage Processor is by far the best selling SSD processor on the market today, and is named Product of the Year by Electronic Products Magazine.
As a Software Quality Assurance (SQA) Engineer (软件测试工程师/嵌入式软件测试工程师), you will work with an exceptionally talented and dynamic development team based in Shanghai, to test and validate cutting-edge firmware for our enormously successful second generation of mass storage controller in the consumer and enterprise segments. Participate in all aspects of design and product development through introduction and release. Duties include supporting test program development for validation of key complex features and storage protocol compliance; participate in refining methodology for compliance and interoperability testing. You will have the opportunity to create cutting edge products that transforms data storage.
Job Description
- Quick learner with high level of self-motivation and dedication, with ability to deliver high quality products on time
- Meticulous, methodical, uncompromising, and creative in testing
- Experience in software debugging, problem creation and trapping
- Experience in devising testing / validation methodology is strong plus
- Communicate effectively in a team, able to multitask effectively in fast-paced environment
- Understanding of NAND Flash concepts, knowledge of Flash management techniques, including wear leveling, garbage collection (strong plus)
- Knowledge and hands-on experience with storage protocols is preferred (SAS / SATA)
- BS/MS in Electrical Engineering, Computer Science, or Computer Engineering is required with firmware development
6.
Jr. Software Quality Assurance (SQA) Engineer –
上海
Job Description
Come join us! Exceptional possibilities await you at LSI’s rapidly expanding Flash Component Division (FCD) in Shanghai. We are one of the top innovators in data storage today, by pioneering use of standard flash in consumer, and enterprise applications, we revolutionize storage in reliability, performance and energy efficiency. LSI Sandforce Flash Storage Processor is by far the best selling SSD processor on the market today, and is named Product of the Year by Electronic Products Magazine. As a Junior Software Quality Assurance (SQA) Engineer (软件测试工程师/嵌入式软件测试工程师), you will work with an exceptionally talented and dynamic development team based in Shanghai, to test and validate cutting-edge firmware for our enormously successful second generation of mass storage controller in the consumer and enterprise segments. Participate in all aspects of design and product development through introduction and release. Duties include setting up interoperability lab, participating and refining methodology in interoperability testing. You will have the opportunity to create cutting edge products that transforms data storage.
- BS in Electrical Engineering, Computer Science, or Computer Engineering is required with 2+ years of software/hardware validation.
Knowledge, Skills, and Abilities
- C / C++ Programming experience is optional but preferred
- Prior experience with PC / Notebook / HDD / SSD testing is optional but preferred
7.
Firmware Engineer-上海
Education and Experience Requirements
BS in Electrical Engineering, Computer Science, or Computer Engineering is required with 6+ years of firmware development.
M.S. preferred with 4+ years in firmware development.
Must demonstrate expertise in design and implementation of event-driven, real time firmware solutions using C/C++ programming
Must be able to work with ASIC and software engineers in a collaborative environment
Must have an excellent computer science background and demonstrated strength in designing efficient embedded firmware for storage or networking products
Firmware/System debug skills utilizing debugger, protocol analyzer is required
Good understanding of RTOS concepts including task switching, deadlocks, and resource management issues is required
High level of skill in problem recreation, trapping and resolution, possess good written and verbal communication skills.
Communicate effectively in a team, able to multitask effectively in fast-paced environment.
Understanding of NAND Flash concepts, knowledge of Flash management techniques, including wear leveling, garbage collection (optional but strong plus).
8.
NPI Program Manager –上海
Job Description
Scope of programs:
- Geographic spread across US & Asia
- Mission critical SoCs with enormous business impact in the $100M+ range
- High development cost and effort and significant cross-functional coordination & teamwork
Responsibilities:
- Project Definition:
* Support quote & SOW/PRD generation as needed
* Support design managers & program managers in defining baseline plan of record or POR (scope, schedule, resources/budget, quality, etc.) for the program
* Develop project plans & risk mitigation plans for new product introduction (NPI) including wafer fabrication, assembly, test, proto ship, validation, qualification and production ramp
* Coordinate and facilitate the set up of program teams in cooperation with other functional groups
* Drive project plans for product cost reduction and second sourcing initiatives across multipleproducts
- General Program management:
* Partner with various organizations to drive efficient & common program management practices & capabilities
* Drive the development and adoption of common NPI milestones, checklists and handoff requirements
* Support PMO in monthly or quarterly program reviews * Become a PMO advocate and expert
* Drive the management of product issues in NPI to ensure quick corrective and preventive action implementation
- Skills:
* Demonstrated problem solving skills on high-impact problems
* Consistent positive “can do” attitude and approach – persistence and diligence to overcome challenges
* Excellent people skills and emotional intelligence – with the ability to motivate & direct people without a direct reporting structure
* Ability to be a strong team leader and influencer under pressure - strong internal stakeholder and customer management skills
* Ability to partner very effectively with & attain credibility amongst a wide swath of functional groups including engineering, marketing, sales, operations, program management, etc.
* Detailed knowledge of project management methodology, processes and tools (esp. MS Project)
* Engineering degree or equivalent; knowledge of hard disk drives/solid state drives, read channels, and related electronics a big plus
* Good understanding of semi-custom/ASIC/ASSP design
* Excellent understanding of semiconductor manufacturing, test/validation, product engineering and product qualification
* Ability to be strongly self-driven and a self-starter who can succeed with limited startup training
* Outstanding verbal, written & communication skills in English
* A very structured thinker who has excellent documentation and presentation skills to present issues and status to executive management in ways that effectively convey the message
* Excellent working knowledge of MS Office products (esp. PPT, Excel); knowledge of MS Sharepoint & Wikis a plus
* A good tops-down and bottoms-up perspective on what is required to effectively take a complete solution to market
Requirements:
- BSEE or equivalent, Masters preferred
- Significant program management experience, relating to semiconductor new product development, introduction and product ramp for large customers/OEMs with revenues in the high tens to hundreds of millions of dollars
- Experience in leading/program managing large, complex, mission-critical semiconductor IC programs involving cross-geographic, international teams in the U.S. and Asia
- Experience dealing with supply chain organizations & major semiconductor suppliers/vendors in Asia
9.
Technical Marketing Engineer-上海/北京/深圳/杭州
Description
LSI is looking for an experienced Technical Marketing Engineer to provide comprehensive pre-sales technical support to customers, enabling them to successfully understand, evaluate and implement Nytro PCIe Flash Solution in their enterprise applications.
Location:  Beijing, Shanghai/Hangzhou, Shenzhen or Taipei
Responsibilities
Run and own proof of concept activities introducing Nytro PCIe flash solutions
Analyze customer requirements and recommend creative architectures and solutions that implement Nytro solutions
Answer technical questions regarding hardware and software on sales calls
Provide constructive feedback to engineering regarding product requirements, support tools, and support methodologies
Provide an effective bridge between end users and LSI’s engineering team
Assist in architecture definition with customers and provide technical support for evaluation and proof of concept projects to reach successful completion
Maintain close contact with engineers and management at customers’ sites, and provide status and new project information to sales and product marketing managers
Debug hardware and/or software problems related to proof of concept evaluations
Desired Skills & Experience
Over 7 years experience with 3+ years enterprise solution development experience. BSEE/BSCS or higher.
Willingness to travel over 50% of the time
Understanding of Window/Linux/VMware OS and provide support
Strong analytical and troubleshooting skills
Know how to use performance tools (IOmeter, VDBench, Flex IO, Sysbench, IOZone, IOStat, etc)
Ability to handle and resolve critical customer issues/problems resulting in a high level of customer satisfaction
Strong leadership skills. Drive to succeed, achievement orientation, self-motivation.
Strategic thinking, with the ability to identify and unravel issues before they hit the schedule.
Positive, energetic, persistent and can-do attitude. Not requiring a lot of hand-holding.
Excellent written and oral communications skills as well as proven presentation skills
Advantages
Enterprise storage technical marketing role in the last 3 years
Data center customer engagement experience highly desired
Experience in Oracle/SAP database, virtualization, caching software, SAN and NAS
Knowledge of solid state storage
Understand how applications work in caching environment
LSI Corporation is a leading provider of innovative silicon, systems and software technologies that enable products which seamlessly bring people, information and digital content together. We offer a broad portfolio of capabilities and services including custom and standard product ICs, adapters, systems and software that are trusted by the world's best known brands to power leading solutions in the storage and networking markets.
GMT+8, 2025-12-22 10:37 , Processed in 0.064893 second(s), 7 queries , Gzip On, Redis On.
