查看: 5976|回复: 3
[求助] Virtuoso ic610 的license问题,求救!!!
发表于 2012-8-30 17:50:38 | 显示全部楼层 |阅读模式
license配置好,启动后出现下面这样的问题,乞求高手指点指点~~~!感激不尽~~~
/home/Virtuoso/eda/ic610/share/license/license.dat: line 941: 7D042D8CE37C9EE8D0A1: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 945: FEATURE: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 946: ADB4ED1CE59001F84107: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 950: FEATURE: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 951: uncounted: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 955: FEATURE: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 956: uncounted: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 960: FEATURE: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 961: 7D644D4C5C1A405E7F37: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 965: FEATURE: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 966: uncounted: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 970: FEATURE: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 971: 4D24ED4CD1482BF56DD4: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 975: FEATURE: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 976: CDE43D9C6BDC982660C4: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 980: FEATURE: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 981: uncounted: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 985: FEATURE: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 986: FD54BDECF3A7A7BA6A36: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 990: FEATURE: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 991: BDC42DACC8665B26EBA8: command not found
/home/Virtuoso/eda/ic610/share/license/license.dat: line 995: FEATURE: command not found
发表于 2012-8-30 21:17:27 | 显示全部楼层
license启动行写的不对吧
 楼主| 发表于 2012-8-31 09:25:18 | 显示全部楼层
谢谢提醒!是配置文件.bashrc出现了错误:我原来是这样配置:lmli='/home/eda/ic610/tools/bin/lmgrd      /home/eda/ic610/share/license/license.dat'
应该是这样的:lmli='/home/eda/ic610/tools/bin/lmgrd  -c /home/eda/ic610/share/license/license.dat'
再启动就没有那样的错误了~~~
发表于 2012-9-19 14:46:59 | 显示全部楼层
想下载
GMT+8, 2025-12-28 15:37 , Processed in 0.021752 second(s), 7 queries , Gzip On, Redis On.
