查看: 2610|回复: 5
[求助] [器件模拟] sentaurus 2010.3 安装后运行异常,求解
发表于 2012-8-20 23:36:34 | 显示全部楼层 |阅读模式
error
error
如上图,运行后随便我怎么设置,保存project都会出现这样的异常,求解。
 楼主| 发表于 2012-8-21 23:44:10 | 显示全部楼层
自己顶一个
发表于 2012-8-29 13:36:13 | 显示全部楼层
回复 1# seabert1997
    This is related to the way you define the pathway in the .bashrc file.
(1) Make sure to create only STDB directory.
(2) Make sure also the tmp directory is created if you wanna save your project there.
(3) Ctrl + h  ====> to unhide files in home directory.
(4) gedit the file ===> .bashrc
(5) Add instruction inside the .bashrc file.
STDB=/user/home/STDB
export STDB
(6) Assume that the STDB directory resides in the home directory. If it is inside synopsys directory, then just add synopsys name after the home directory such as below.
STDB=/user/home/synopsys/STDB
export STDB
Hoep this help!
发表于 2012-9-30 23:37:21 | 显示全部楼层
我也出现了同样的问题,同请教啊
发表于 2012-11-28 01:26:05 | 显示全部楼层
+1我也是~怪了...試不出來
发表于 2012-12-11 08:51:02 | 显示全部楼层
3楼正解
$ gedit .bashrc
然后添加
export STDB
这个stdb是软件默认的工作目录,加上它就不提示有问题了
GMT+8, 2025-12-14 05:20 , Processed in 0.022572 second(s), 8 queries , Gzip On, Redis On.
