查看: 2202|回复: 2
[求助] 安装IC610后还需要安装什么
发表于 2012-8-19 00:08:56 | 显示全部楼层 |阅读模式
我已经把IC 610安装好了,,,请问仿真的时候还需要安装什么呢?
发表于 2012-8-21 19:45:45 | 显示全部楼层
助] rhel4中装IC610环境变量设置后遇到问题
2012, 环境, process, file
错误显示为:
bash: ./etc/bashrc: No such file or directory
bash-3.00$ su
但查看etc下有bashrc文件的啊,很郁闷,报警信息如下:
E325: ATTENTION
Found a swap file by the name ".bashrc.swp"
          owned by: root   dated: Mon Aug 20 06:13:00 2012
         file name: /home/xu/.bashrc
          modified: YES
         user name: root   host name: localhost.localdomain
        process ID: 5764
While opening file ".bashrc"
             dated: Tue Aug 21 01:38:03 2012
      NEWER than swap file!
(1) Another program may be editing the same file.
    If this is the case, be careful not to end up with two
    different instances of the same file when making changes.
    Quit, or continue with caution.
(2) An edit session for this file crashed.
    If this is the case, use ":recover" or "vim -r .bashrc"
    to recover the changes (see ":help recovery").
    If you did this already, delete the swap file ".bashrc.swp"
    to avoid this message.
".bashrc" 19L, 611C
求助啊
收藏 分享
发表于 2012-8-23 16:41:08 | 显示全部楼层
你的路径是不是错了?
多了一个点 ./etc/........
GMT+8, 2025-12-26 17:40 , Processed in 0.048852 second(s), 6 queries , Gzip On, Redis On.
