查看: 2679|回复: 0
[招聘] Cadence is looking for IC design and design services Engineer
发表于 2012-8-17 18:26:40 | 显示全部楼层 |阅读模式
Cadenceis looking for IC design and design services Engineer
SOC-R Front-end Design Team
Position: Principal/Lead Design Engineer
Position Description:
Deliver/implement IP and SoC chip.The engineer should be able to act as a strong team member and contributor,leading team projects and initiatives. Exercise judgment within generallydefined practices and policies.
Specific duties include:
- Be responsible for building andleading a high-performance IC design team, owning the IC micro-architecture,package and test platform development, refining the EDA design flow
- Proficiency in logic design,simulation, synthesis, STA and testing
- Proficiency in Verilog and itssimulation environment
- Good knowledge of SOC design
At least five years experiencedriving complex IC development projects, excellent communication skills and theuncanny ability to both lead and contribute in a cooperative team environmentis required.
Position Requirements:
1.BS degree with 10~15+ years ofapplicable experience, MS degree with 7~10+ years of applicable experience inelectrical engineering, microelectronics
2.Comparable engineering science orsolid state physics.
3.Essential that the individualdemonstrates strong communication, verbal and written. Requires goodcommunication skills in English.
If you have interest, PLS send yourCV to zhangyl@cadence.com
SOC-R Physical Design Team
Position: Lead Physical Design Engineer
-Perform physical designimplementation, including synthesis, floor planning, power grid design, placeand route, clock tree synthesis, timing closure, power/signal integritysignoff, physical verification (DRC/LVS/Antenna), EM/IR signoff, DFM Closure,and physical design project management.
-The candidate will have theopportunity to work on many varieties of challenging designs, i.e. low powerand high speed design. The responsibility includes participating in or leadingnext generation physical design, methodology and flow development.
1.BS degree with 10+ years ofapplicable experience, MS degree with 7+ years of applicable experience inelectrical engineering, microelectronics.
2.Experienced with ASIC design flow,hierarchical physical design strategies, methodologies and understand deepsub-micron technology issues.
3.Solid knowledge on LP Design, DFT,static timing analysis, EM/IR-Drop/crosstalk analysis, formal verification,physical verification, DFM.
4.Successful track records of tapingout complex, 65/40/28 nm SOC chips.
5.Automation and programming-minded,solid coding experience in Makefile/Tcl/Tk/Perl.
6. Self-motivated, able to workindependently or as a team player, excellent verbal and written communicationskills in English.
SOC-R Design Services Team
Position: Lead Implementation Services Engineer
1.The candidates should be senior ina way that they are not only technical excellent but also mature & able tocommunicate with customers, following team members.
2.This engineer should have excellentdesign experiences in the digital implementation domain including Floorplan,P&R, STA, Physical verification, DFM.
3.The engineer must have a solidbackground in circuits, electronics & physics & should be very willingto learn new stuff.
Key Accountabilities:
1.Ability to handle large sized designimplementation tasks & architectural tasks alone. 2.Ability to assessCustomer's Design environment, to understand his application needs & tobuild new Design environment based on specifications & available Cadencetool technology.
3.Ability to acquire a basicunderstanding of the (services) business environment of Cadence within 1 month.
4.Working on multi person projects ofvarying complexity, working especially in a multi-site/multi-cultural project.The latter requires good communication skills in English. 5.Feeling responsiblefor technical delivery as well as business development & opportunitycreation. Behavioral competencies: Teamwork; Customer focus; 6.Accountability;Communication; Coaching & feedback; Employee development; Leadership.
2.Essential that the individualdemonstrates strong communication, verbal and written, and project managementskills.
3.Requires good communication skillsin English.
GMT+8, 2025-12-22 08:52 , Processed in 0.017047 second(s), 7 queries , Gzip On, Redis On.
