查看: 8675|回复: 14
[求助] icc 读.v 报错
发表于 2012-8-14 18:58:38 | 显示全部楼层 |阅读模式
*****  Verilog HDL translation! *****
*****    Start Pass 1 *****
Compiling source file /home/hanlei/Projects/pr/pr_umc018/net_sdc/ccb.gv
*****  Pass 1 Complete *****
Elapsed =    0:00:00, CPU =    0:00:00
*****    Start Pass 2 *****
Error:   /home/hanlei/Projects/pr/pr_umc018/net_sdc/ccb.gv:410:  module INV4CK is not defined.
(VER-500)
Error: Module 'INV4CK' is not defined.  (MWNL-297)
Error:   /home/hanlei/Projects/pr/pr_umc018/net_sdc/ccb.gv:410: ERROR: near line 410: Port connection failed.
(VER-500)
^G^G
Error: Verilog parser cannot parse the /home/hanlei/Projects/pr/pr_umc018/net_sdc/ccb.gv source file. (MWNL-047)
No such file or directory
Error: Current design is not defined. (UID-4)
谁知道是什么原因?
 楼主| 发表于 2012-8-14 19:35:23 | 显示全部楼层
没人知道吗?
发表于 2012-8-14 20:24:29 | 显示全部楼层
没读库文件吧?
 楼主| 发表于 2012-8-14 21:28:22 | 显示全部楼层
库文件都读进去了,不知道是什么原因呀?
发表于 2012-8-14 22:01:09 | 显示全部楼层
check_library,看下问题所在,估计link_library没有设置好。
回复 4# hanlei8266
顶层模块有没有写上呢?
 楼主| 发表于 2012-8-14 22:18:14 | 显示全部楼层
写了,会不会是库本身有问题,或者软件有问题那?
 楼主| 发表于 2012-8-14 22:32:05 | 显示全部楼层
谢谢,
 楼主| 发表于 2012-8-15 07:54:08 | 显示全部楼层
check_library
#BEGIN_XCHECK_LOGICCELLS
All 0 physical cells in ../lib/FSA0A_C_GENERIC_CORE are missing in logic library.
#END_XCHECK_LOGICCELLS
#BEGIN_XCHECK_PHYSICALCELLS
All 484 logic cells in fsa0a_c_generic_core_ss1p62v125c are missing in physical library.
#END_XCHECK_PHYSICALCELLS
 楼主| 发表于 2012-8-15 08:20:21 | 显示全部楼层
这是什么原因?
GMT+8, 2025-12-18 16:53 , Processed in 0.018097 second(s), 4 queries , Gzip On, Redis On.
