查看: 8074|回复: 20
ic615在UBUNTU12.04上启动时间要12分钟????
发表于 2012-7-31 17:03:17 | 显示全部楼层 |阅读模式
ic615.72终于在UBUNTU12.04上安装成功,,但是,从,virtuose &  到操作窗口出现(及可操作)要12分钟。。。
在这12分钟内只有鼠标能动,但点不了任何东东,至到操作窗口出现。一担进入操作窗口,可正常工作。。。
想问问大虾们,我要检查哪个方向的问题来解决那12分钟的假死问题。。
发表于 2012-7-31 17:08:42 | 显示全部楼层
看 当前用户的主目录下面的CDS.log,里面应该有很多的try
基本上这个是获取hostname的时候获取不到导致的,在/etc/hosts里加入本机的hostname 即可
 楼主| 发表于 2012-7-31 22:39:26 | 显示全部楼层
\# Program start time UTC 2012.07.31 14:22:20.738
\# Local time Tuesday 31 July 2012, 10:22 pm
\o Program:                @(#)$CDS: virtuoso version 6.1.5 01/10/2011 12:16 (sjfdl225) $
\o Hierarchy:                /eda/cadence/IC6151/tools.lnx86/dfII/
\o Sub version:                sub-version  IC6.1.5.72  (32-bit addresses)
\# Host name (type):        wlf (i686)
\# Operating system:        Linux 3.2.0-26-generic-pae #41-Ubuntu SMP Thu Jun 14 16:45:14 UTC 2012
\# X display name (WxH):        :0.0 (1920x1080)
\# Available geometry:                        TL(52:24) BR(1919:1079)
\# X server:                        The X.Org Foundation
\# Depth of Visual (Root):        24 (24)
\# Number of Planes Used:        24
\# X version:                11.0 (vendor release 11103000)
\# X resource pool:        base 0x4200000, mask 0x1fffff (2097151), shift 0
\#                         current id 0x0, current max 0x1ffffa (2097146)
\# Memory report:        maximum data size 4294967295 (0xffffffff) bytes
\# Memory report:        maximum process size 4294967295 (0xffffffff) bytes
\# Initial sbrk value:        364777472 (0x15be1000) bytes
\# Available memory:        4145996 (0x3f434c) kilobytes
\# System memory:        5628608 (0x55e2c0) kilobytes
\# Maximum memory size:        3963752447 (0xec420fff) bytes
\# Max mem available:        3963752447 (0xec420fff) bytes
\# Initial memory used:        33562624 (0x2002000) bytes
\# Qt version:                4.5.3
\# Window Manager:        other
\# User Name:                wlf204
\o Working Directory:        wlf:/eda/cadence/IC6151/bin
\# Process Id:                2915
\o
\o COPYRIGHT © 1992-2011  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
\o           © 1992-2011  UNIX SYSTEMS Laboratories INC.,
\o                          Reproduced with permission.
\o
\o This Cadence Design Systems program and online documentation are
\o proprietary/confidential information and may be disclosed/used only
\o as authorized in a license agreement controlling such use and disclosure.
\o
\o           RESTRICTED RIGHTS NOTICE (SHORT FORM)
\o Use/reproduction/disclosure is subject to restriction
\o set forth at FAR 1252.227-19 or its equivalent.
\# Available memory:        4006756 (0x3d2364) kilobytes UTC 2012.07.31 14:22:24.267
\o Loading geView.cxt
\o Loading menuBuilder.cxt
\o Loading schView.cxt
\o Loading selectSv.cxt
\o Loading LVS.cxt
\o Loading layerProc.cxt
\o Loading xlUI.cxt
\o Loading auCore.cxt
\o Loading vhdl.cxt
\o Loading seismic.cxt
\o Loading ci.cxt
\o Loading ams.cxt
\o Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.06s.
\i ddsWhatsNew()
\p >
\o Loading rte.cxt
\# Available memory:        3158672 (0x303290) kilobytes UTC 2012.07.31 14:22:34.267
\# Memory report: Maximum memory size now 3308281856 (0xc5306000) bytes, UTC 2012.07.31 14:22:34.267
\# Available memory:        3912744 (0x3bb428) kilobytes UTC 2012.07.31 14:32:24.285
\# Memory report: Maximum memory size now 3963752447 (0xec420fff) bytes, UTC 2012.07.31 14:32:24.285
 楼主| 发表于 2012-7-31 22:42:38 | 显示全部楼层
回复 2# snk88
    我把CDS.log贴出来了,没有看到try啊。。。
 楼主| 发表于 2012-7-31 22:52:48 | 显示全部楼层
好像是内存检测用了10分钟。。。。
这要改哪里啊。。。
发表于 2012-8-3 00:09:45 | 显示全部楼层
你试试在centos和RHEL上的表现如何
 楼主| 发表于 2012-8-3 09:08:31 | 显示全部楼层
回复 6# phoenixson
    我用的就是我们EETOP论坛的帖子里ic6151.帖子中说是验证过的,,,在REDHAT,,
发表于 2012-8-5 17:16:11 | 显示全部楼层
   我的意思是如果RHEL上的表现没问题,那可能就是你的ubuntu的问题了
发表于 2012-9-26 01:58:34 | 显示全部楼层
楼主,我也是在UBUNTU12.04上装的ic6151,发现和你遇到了一样的问题,我的内存检测大概用了8分钟。
请问楼主,现在的问题你搞定了么?
另外我的ic6151提示少了courier medium 和 helvetica medium 两种字体,于是显示出来的菜单有些有问题,请问楼主字体的问题你遇到了么?怎么解决的?
发表于 2012-9-26 20:46:03 | 显示全部楼层
同求答案,有人知道怎么解决么??
GMT+8, 2025-12-28 14:20 , Processed in 0.021530 second(s), 5 queries , Gzip On, Redis On.
