查看: 4914|回复: 11
[求助] 【求论文】7篇Elsevier上的solid state electronics的论文
发表于 2012-7-31 15:14:06 | 显示全部楼层 |阅读模式
自己通过某宝试图上science direct 下载这几篇论文,但悲剧的是其他的文章可以,就是solid state electronics 还有 microelectronic reliability 分类下面的文章发表时间在90年代以前的都不给下。。。。。。试了好多个方法有没有。。。。只好又来论坛求助了。   我知道这里是神仙出没的地方。。。。   文章很重要,各种求!!! 多谢各位了!这些文章都是和pn junction的capacitance有关,ESD transient pulse需要考虑的重点。。。
"Experimental results on transient space charge limited currents in p-n junctions"
http://www.sciencedirect.com/science/article/pii/0038110171901456
"Non-quasi-static capacitance of p/n junction space-charge regions"
http://www.sciencedirect.com/science/article/pii/0038110188900883
"Space charge limited currents in P-N junctions"
http://www.sciencedirect.com/science/article/pii/0038109869900179
"Analysis of space-charge induced negative resistance in linearly graded avalanching silicon p-n junctions"
http://www.sciencedirect.com/science/article/pii/0038110172900652
"p-i-n diode recovery storage time"
http://www.sciencedirect.com/science/article/pii/0038110180901185
"The p+n−n+ diode pulsed at extremecurrent densities—II: The forwardpulsedcase and its anomalous voltage response"
http://www.sciencedirect.com/science/article/pii/0038110180901525
"The p+n−n+ diode pulsed at extreme current densities—I: Numerical techniques and reverse pulsed case"
http://www.sciencedirect.com/science/article/pii/0038110180901513
 楼主| 发表于 2012-7-31 16:54:40 | 显示全部楼层
自己顶一下。。。。。求神仙帮忙。。。愿意出100信元/篇  求。
 楼主| 发表于 2012-7-31 17:56:50 | 显示全部楼层
自己再顶一下,直到找到为止。。。。
 楼主| 发表于 2012-8-1 10:22:21 | 显示全部楼层
再顶一下。。。。
发表于 2012-8-1 17:51:10 | 显示全部楼层
回复 1# analogmind
Experimental results on transient space charge limited currents in p-n junctions.pdf
Experimental results on transient space charge limited currents in p-n junctions.pdf (492.06 KB , 下载次数: 9 )
Non-quasi-static capacitance of pn junction space-charge regions.pdf
Non-quasi-static capacitance of pn junction space-charge regions.pdf (567.2 KB , 下载次数: 5 )
Space charge limited currents in P-N junctions.pdf
Space charge limited currents in P-N junctions.pdf (341.83 KB , 下载次数: 5 )
Analysis of space-charge induced negative resistance in linearly graded avalanching silicon p-n junctions.pdf
abbr_b439178ecfd71d0c2804b4099cb09308.pdf (363.38 KB , 下载次数: 5 )
p-i-n diode recovery storage time.pdf
p-i-n diode recovery storage time.pdf (807.86 KB , 下载次数: 5 )
The p+n−n+ diode pulsed at extremecurrent densitie-II.pdf
The p+n−n+ diode pulsed at extremecurrent densitie.pdf (470.99 KB , 下载次数: 6 )
The p+n−n+ diode pulsed at extremecurrent densitie-I.pdf
The p+n−n+ diode pulsed at extreme current densities—I.pdf (571.9 KB , 下载次数: 4 )
 楼主| 发表于 2012-8-2 13:42:54 | 显示全部楼层
兄弟,太感谢了,同时也要膜拜一下。。。。。。。
发表于 2012-8-4 15:56:03 | 显示全部楼层
客气了,顺手之劳而已
祝好运~
 楼主| 发表于 2012-8-7 15:41:11 | 显示全部楼层
客气了,顺手之劳而已
祝好运~
wildgoat 发表于 2012-8-4 15:56
    Wildgoat, 不知道能否再打扰你一下。还有7篇solid state electron的论文。我在science direct上试过几个入口都不能下,也没有其他办法。不得已来向你求助。能否再帮一个忙?谢谢了!都是一些早期的经典论文。对我目前的工作很有用。
"The emitter efficiency of bipolar transistors: Theory and experiments"
http://www.sciencedirect.com.ezproxy.scu.edu.au/science/article/pii/S0038110177810083
"Measuring and modeling minority carrier transport in heavily doped silicon"
http://www.sciencedirect.com.ezproxy.scu.edu.au/science/article/pii/0038110185902096
"Minority carrier injection into heavily doped silicon"
http://www.sciencedirect.com.ezproxy.scu.edu.au/science/article/pii/0038110177900697
"Unified apparent bandgap narrowing in n- and p-type silicon"
http://www.sciencedirect.com/science/article/pii/003811019290051D
"Two integral relations pertaining to the electron transport through a bipolar transistor with a nonuniform energy gap in the base region"
http://www.sciencedirect.com.eproxy1.lib.hku.hk/science/article/pii/003811018590190X
"Ananalyticalmodel for the steady-state and transient characteristics of the power insulated-gate bipolar transistor "
http://www.sciencedirect.com/science/article/pii/0038110188900251
"Diffusion in a short base"
http://www.sciencedirect.com.ezproxy.scu.edu.au/science/article/pii/0038110192901659
发表于 2012-8-11 10:18:00 | 显示全部楼层
Wildgoat, 不知道能否再打扰你一下。还有7篇solid state electron的论文。我在science direct上试 ...
analogmind 发表于 2012-8-7 15:41
不好意思,暂时无法下载。
一周之后应该可以,如果那时候还没有人出手,我可以再给你上传。
抱歉。
更正:刚才不能下载,以为是我这边服务器关闭的问题。
但似乎问题出在你这次给的链接上,我直接搜索之后可以下载。请稍候。
发表于 2012-8-11 10:33:28 | 显示全部楼层
The emitter efficiency of bipolar transistors Theory and experiments.pdf (523.96 KB , 下载次数: 3 )
An analytical model for the steady-state and transient characteristics of the power insulated-gate bipolar transistor
abbr_3e806141efc68b2e5830b8cf9a0540f7.pdf (1.79 MB , 下载次数: 3 )
Diffusion in a short base.pdf (551.34 KB , 下载次数: 2 )
Measuring and modeling minorit ...
Measuring and modeling minority carrier transport in heavily doped silicon.pdf (844.61 KB , 下载次数: 2 )
Minority carrier injection int ...
Minority carrier injection into heavily doped silicon.pdf (240.09 KB , 下载次数: 2 )
abbr_6b3cf4bef8dcbeb92fcc99957079c9bc.pdf (227.78 KB , 下载次数: 2 )
Unified apparent bandgap narro ...
Unified apparent bandgap narrowing in n- and p-type silicon.pdf (546.19 KB , 下载次数: 7 )
GMT+8, 2025-12-16 09:30 , Processed in 0.028211 second(s), 6 queries , Gzip On, Redis On.
