查看: 8731|回复: 8
[求助] ICC 输出GDS时,如何merge std cell的GDS?[已解决]
发表于 2012-7-27 15:12:57 | 显示全部楼层 |阅读模式
如题,在write_stream命令中没有找到相关选项,输出的GDS只有METEL层和VIA,没有std cell。
icc_shell> write_stream -help
Usage: write_stream    # Write an GDSII or OASIS file
        [-lib_name lib_name]   (Name of library which stalls the data)
        [-format gds_or_oasis] (Output file format. gds(default) or oasis)
        [-cells cell_name]     (Name of the cells to output)
        [-cell_file cell_name_file]
                               (Output cells specified in file)
        stream_file_name       (Name of stream file to write)
发表于 2012-7-27 16:40:46 | 显示全部楼层
有个depth
发表于 2012-7-27 16:40:52 | 显示全部楼层
有个depth
 楼主| 发表于 2012-7-27 17:01:15 | 显示全部楼层
发表于 2015-12-26 17:02:49 | 显示全部楼层
这个命令就可以吗?
发表于 2015-12-31 10:57:37 | 显示全部楼层
这样也是不行的!
发表于 2015-12-31 13:55:36 | 显示全部楼层
set map file option
发表于 2018-9-3 10:14:47 | 显示全部楼层
找找gds2out.map这样的map文件,加到set_write_stream_options中
发表于 2024-12-16 15:23:53 | 显示全部楼层
set_write_stream_options -child_depth 20
-child_depth child_cell_depth
              Specifies  the number of hierarchical levels below the top level
              to write out. The write_stream command exports the CEL  view  of
              each  child cell to the specified level of hierarchy.  To export
              all child cells, specify a large number such as 20.  The default
              value is 0, meaning only the top-level cell is written.
GMT+8, 2025-12-26 20:06 , Processed in 0.020141 second(s), 5 queries , Gzip On, Redis On.
