查看: 2504|回复: 3
[求助] Rocketio can't be used when 8b/10b is bypassed.
发表于 2012-7-24 16:07:38 | 显示全部楼层 |阅读模式
Hi,alI .
Rocketio can work well when 8b/10b is used.
However, when 8b/10b is bypassed,even the example design(added in the IP core)can't work.In simulation, the output data is not the input data.And the 'track data '  signal is low at all time.
Can you help me?
Thank you a lot.
 楼主| 发表于 2012-7-29 21:28:30 | 显示全部楼层
顶一下
发表于 2012-8-15 08:45:17 | 显示全部楼层
Have you found the reason yet? my take is that if you bypass 8b/10b, you might not get enough transition density for CDR to work well (resulting too much jitter).
发表于 2013-5-3 22:21:43 | 显示全部楼层
求解等解
GMT+8, 2025-12-26 21:22 , Processed in 0.016787 second(s), 6 queries , Gzip On, Redis On.
