查看: 10765|回复: 13
[求助] starrc的skip_cells是什么意思?
发表于 2012-7-24 10:42:20 | 显示全部楼层 |阅读模式
我在咱们论坛上下载了个starrc的模版,请问里边的SKIP_CELLS是什么意思?应该怎么设置?
发表于 2012-7-24 11:32:10 | 显示全部楼层
找个user guide看看说明,体会下,然后回来讨论
总不能别人说啥就信啥吧,自己找到官方资料,理解下,和别人讨论下,印证下
发表于 2012-7-24 13:49:14 | 显示全部楼层
SKIP_CELLS
Creates a white-space-delimited list of cells for StarRC to skip during extraction.
Syntax
SKIP_CELLS: cell1 cell2 ... cellN
Arguments
Argument Description
cell1 cell2 ... cellN  A list of cells to be skipped during extraction. Wildcard characters
are acceptable.
Default: *
Description
The SKIP_CELLS command creates a white-space-delimited list of cells for StarRC to skip
during extraction. This command may be specified multiple times in a single command file.
The asterisk (*), exclamation mark (!), and question mark (?) wildcard characters are
acceptable. Case sensitivity for selection purposes is determined by the value of the
CASE_SENSITIVE command, but the netlist always retains the case of the original input
database.
Skipped cells are typically cells with their own timing models, which can later be applied,
along with the StarRC parasitic netlist, to perform a timing analysis. Skipped cells should
have labeled, or otherwise annotated, pin shapes for proper parasitic netlisting.
The default for all extraction flows is to skip everything in the input database, so any macro
blocks without timing models must be negated from the list.
 楼主| 发表于 2012-7-24 14:23:16 | 显示全部楼层
回复 2# damonzhao
    看了资料不是很懂才问的~~
 楼主| 发表于 2012-7-24 14:27:33 | 显示全部楼层
回复 3# yiyeyo
    谢谢你的回复~~想请问你这段资料是哪找的?我在user guide上没看到呀~~
发表于 2012-7-24 14:54:20 | 显示全部楼层
回复 5# hbbdlx
    那个版本的啊? 新版的就有啊
发表于 2012-7-24 15:38:51 | 显示全部楼层
可以到这个帖子里面下载最新版的 http://bbs.eetop.cn/thread-343120-1-1.html
发表于 2012-7-24 15:39:46 | 显示全部楼层
回复 4# hbbdlx
    2002[1].2_star-rcxt_Tutorial_Overview.pdf (584.33 KB , 下载次数: 202 )
 楼主| 发表于 2012-7-24 16:00:50 | 显示全部楼层
回复 7# yiyeyo
    2011的,好的,我一会下载个2012的,谢谢~~
 楼主| 发表于 2012-7-24 16:02:29 | 显示全部楼层
回复 8# damonzhao
    谢谢版主大人~~
GMT+8, 2025-12-20 17:39 , Processed in 0.020719 second(s), 5 queries , Gzip On, Redis On.
