楼主: tntdog
[原创] 请教多时钟综合的设置
发表于 2012-8-27 14:18:13 | 显示全部楼层
你的这个CLK_2是不是作为port输出了,那样的话咱的现象就一样了,查了一个这个解决方案,但是只讲到mux clock的解决方法,并没有讲到这个的解决方法,你要是有synopsys的账户的话可以进这个网址看看,我没有看不了,希望有人看了能把内容贴出来!https://solvnet.synopsys.com/retrieve/015752.html,大家共同学习一下!
发表于 2012-8-27 14:21:23 | 显示全部楼层
NAME
       PTE-075 (warning) Generated clock '%s' has no path to its master clock.
DESCRIPTION
       The generated clock has no path to the master clock  on  which  it  has
       been  defined.   This  may  be  because  there  is no physical path, or
       because the generated clock has been defined as  a  -combinational  and
       the generated clock is not in the direct fanout of the master clock.  A
       propagated source latency of zero will be use from the master clock  to
       the generated clock.
WHAT NEXT
       Please  check  the design and redefine the generated clock to be in the
       fanout of its master clock.
发表于 2012-8-27 14:22:59 | 显示全部楼层
NAME
       UITE-461 (Error) Generated clock '%s' '%s' is not satisfiable%s
DESCRIPTION
       This  is an error  message whenever the clock network traversal can not
       find a path which satisfies the  sense  relationship  defined  by  cre-
       ate_generated_clock command.
WHAT NEXT
       Check  for the generated clock definition to see if the generated clock
       is correctly defined. One example is  that  a  divided_by  2  generated
       clock  is  driven  by  a  inverter  only. In this case, generated clock
       should be redefined with -invert with -divided_by 1.   Another  example
       is  a  divided_by  2 generated clock with preinverting. If master clock
       source pin is used as generated clock source pin, PrimeTime will  issue
       the warning message. In this case, generated clock source pin should be
       redefined to clock pin of divider.
发表于 2012-8-27 14:36:36 | 显示全部楼层
回复 5# falloutmx
    如何使能?加门控?
发表于 2012-8-27 18:15:32 | 显示全部楼层
回复 14# neoitachi
Solvnet的答案,没有细看,是你需要的吗?
Why is the Polarity of the Clock Edge Incorrect.rar
105.02 KB, 下载次数: 275 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2012-8-27 19:14:29 | 显示全部楼层
非常感谢,
发表于 2012-8-27 19:20:56 | 显示全部楼层
学习一下
发表于 2020-6-17 16:27:30 | 显示全部楼层
非常感谢
发表于 2020-6-18 16:43:58 | 显示全部楼层
学习一下 看了半天,是不是clk3的源应该是clk2而不是clk1
发表于 2020-7-16 18:39:33 | 显示全部楼层
tntdog 发表于 2012-7-12 18:04
两个图是一样的,多上传了一次。
请问最后是怎么解决的????
GMT+8, 2025-12-30 10:35 , Processed in 0.019604 second(s), 4 queries , Gzip On, Redis On.
