楼主: ohmylittlec
[求助] spectre中的stb仿真
发表于 2014-12-11 18:45:06 | 显示全部楼层
回复 6# stm2010
   伙计,能仔细说明下么?我现在遇到这样一个问题,用ac仿真和stb仿真,结果中相频特性的相位起始点分别从0和+180度开始的,
发表于 2014-12-11 18:46:38 | 显示全部楼层
回复 5# andrew1986
发表于 2015-8-20 11:40:15 | 显示全部楼层
学习了
发表于 2016-5-12 15:04:02 | 显示全部楼层
受教了,mark mark
发表于 2016-5-23 11:42:21 | 显示全部楼层
The loop-based algorithm provides accurate stability information for single-loop circuits and
multi-loop circuits in which a probe component can be placed on a critical wire to break all
loops. For a multi-loop circuit in which such a wire may not be available, the loop based
algorithm can be performed only on individual feedback loops to ensure they are stable.
Although the stability of all feedback loops is only a necessary condition for the whole circuit
to be stable, the multi-loop circuit tends to be stable if all individual loops are associated with
reasonable stability margins.
回复 支持 3 反对 0
发表于 2016-5-24 14:12:59 | 显示全部楼层
对于多loop的电路,觉得还是AC仿真好些
发表于 2016-6-13 13:49:20 | 显示全部楼层
学习。
发表于 2016-8-10 17:05:12 | 显示全部楼层
回复 7# gougou_123
应该加在运放的输出和GATE之间。
发表于 2018-7-19 09:50:29 | 显示全部楼层
回复 3# andrew1986
   学习了,我一个单环的地方,把stb加在低阻节点和高阻节点,得到的结果都不一样
发表于 2018-7-19 13:57:35 | 显示全部楼层
测试电压源放在loop中的高阻节点
GMT+8, 2025-12-11 12:29 , Processed in 0.017640 second(s), 3 queries , Gzip On, Redis On.
