楼主: wjchuan
[求助] ICC的psynopt什么时候用,什么作用?
发表于 2019-9-26 14:57:16 | 显示全部楼层
After modifying placement and path group parameters
(as appropriate) execute psynopt:
Performs incremental timing-driven logic optimization
Legalizes placement
补充上面回答
发表于 2019-9-26 14:58:07 | 显示全部楼层
Include -area_recovery
May help reduce congestion and power – may impact run time
If power optimization is a priority include -power
Enable GLPO dynamic power optimization (if not already
enabled prior to place_opt –power)
If the design is congested include –congestion
..刚才补充错了,sorry
发表于 2020-6-9 11:06:56 | 显示全部楼层
学习ing
发表于 2020-11-30 15:20:17 | 显示全部楼层
学习中
发表于 2021-3-12 09:50:28 | 显示全部楼层
place后可以用,cts后可以用,route后也可以用,但记得legalize_placement ,然后route_zrt_eco。
psynopt针对时序违例而不考虑其它问题,所以会带来一些其它错误。
发表于 2025-6-7 11:18:21 | 显示全部楼层
psynopt,可用在cts之后修复违例。其后参数 -power可优化功耗同时优化timing,-only fix hold专门用来修复hold violation。(小白留言,欢迎讨论指正
GMT+8, 2025-9-17 07:22 , Processed in 0.013996 second(s), 4 queries , Gzip On, Redis On.
