查看: 2747|回复: 5
[求助] 关于ram 的testbench 编写
发表于 2012-6-14 23:16:13 | 显示全部楼层 |阅读模式
各位好 我现在设计了一个ram, 读数据的时候,地址是另外单独控制的, 这个我不清楚testbench 怎么写,谁能帮助一下
以下是ram 的verilog code
module memory_256(addr, data_in, data_out, write, read, clk_sys, rst
input [7:0]
addr;
//256 address
input [7:0]
data_in;
// 8 bit
input write, read, clk_sys, rst;
output [7:0]
data_out;
reg [7:0]
data_out;
reg [7:0]
memory [255:0];
wire [7:0]
addr;
integer i;
// asynchronous reset
always @(posedge clk_sys or posedge rst)
begin
if(rst)
begin
data_out <= 0;
for (i=0;i<255;i=i+1)
memory <= 0;
end
else
begin
if(read)
data_out <= memory [addr];
else if (write)
begin
data_out <= 0;
memory [addr] <= data_in;
end
end
end
//===============================How many column in one MB============================
reg         [3:0]
r_col_address;
reg
[1:0]
r_blk_col_cnt;
wire
[1:0]
s_blk_col_cnt;
if(rst == 1'b1)
r_blk_col_cnt <= 0;
else if(r_blk_col_cnt == 3)
r_blk_col_cnt <= 0;
else if(r_blk_col_cnt < 3)
r_blk_col_cnt <= r_blk_col_cnt + 1;
assign
s_blk_col_cnt = r_blk_col_cnt;
//==============================How many macroblock in Horizontal============================
reg
[1:0]
r_blk_num_h;
wire
[1:0]
s_blk_num_h;
if(rst == 1'b1)
r_blk_num_h <= 0;
else
  begin
if(r_blk_num_h == 3)
r_blk_num_h <= 0;
else if(s_one_block_finish == 1'b1)
begin
if(r_blk_num_h < 3)
r_blk_num_h <= r_blk_num_h + 1;
else
r_blk_num_h <= 0;
end
  end
assign s_blk_num_h = r_blk_num_h;
//================================address in horizontal direction=======================================
wire
[3:0]
s_address_h;
assign
s_address_h = {s_blk_num_h,s_blk_col_cnt};
//==============================how many row in one MB==========================================
reg
[1:0]
r_blk_row_cnt;
wire
[1:0]
s_blk_row_cnt;
if(rst == 1'b1)
r_blk_row_cnt <= 0;
else if(r_blk_row_cnt == 3)
r_blk_row_cnt <= 0;
else
r_blk_row_cnt <= r_blk_row_cnt + 1;
assign
s_blk_row_cnt = r_blk_row_cnt;
//=============================how many macroblock in one vertical=================================
reg
[1:0]
r_blk_num_v;
wire
[1:0]
s_blk_num_v;
if(rst == 1'b1)
r_blk_num_v <= 0;
else if(r_blk_num_h == 3)
begin
if(r_blk_num_v < 3)
r_blk_num_v <= r_blk_num_v + 1;
else
r_blk_num_v <= 0;
end
else r_blk_num_v <= 0;
assign
s_blk_num_v = r_blk_num_v;
//=============== ============address in vertical direction==================================================
wire
[3:0]
s_address_v;
assign
s_address_v = {r_blk_num_v, r_blk_row_cnt};
//===========================address of pixel in the frame===========================================
//wire
[7:0]
addr;
   assign
addr = {s_address_v,s_address_h};
endmodule
一下是普通ram读写的testbench
module memory_256_tb(
wire [7:0]
address, addr;
reg [7:0]
data, data_in;
reg
wire s_one_block_finish;
wire [7:0]
data_out;
parameter cycle = 20;
integer i;
initial
begin
addr = 0;
rst = 0;
read = 0;
write = 0;
data_in = 0;
clk_sys = 0;
forever #20 clk_sys = ~clk_sys;
end
initial
begin
//for reset
rst = 0;
#cycle;
rst = 1;
#cycle;
rst = 50;
#cycle;
begin
address = i;
data = i;
memory_write(address, data);
#cycle;
end
for(i=255;i>0;i=i-1)
begin
address = i;
memory_read(address);
#cycle;
end
$stop;
end
task memory_write;
input [7:0] data;
input [7:0]
address;
begin
addr = address;
data_in = data;
write = 0;
#cycle;
write = 1;
read = 0;
repeat (2) #cycle;
write = 0;
#cycle;
$display ("Completed writing data %h at address %h", data_in, addr);
end
endtask
task memory_read;
input [7:0] address;
begin
read = 0;
addr = address;
data_in = 0;
#cycle;
read = 1;
repeat (2) #cycle;
read = 0;
#cycle;
$display ("Completed reading memory at address %h. Data is %h", addr, data_out);
end
endtask
endmodule
发表于 2012-6-15 10:18:19 | 显示全部楼层
没看懂,等高手解释!
发表于 2012-6-15 10:41:29 | 显示全部楼层
地址是另外单独控制的
那应该就根据你验证需要来编写它的地址输入啊
代码太长,没看
 楼主| 发表于 2012-6-15 11:26:53 | 显示全部楼层
回复 3# SKILLER
感谢你的回答
你的意思 就是专门编写testbench 去验证地址了?
发表于 2012-6-15 14:11:22 | 显示全部楼层
回复 4# zhaow0422
    对啊,你的设计要证明是正确的,你就应该给它一定激励信号,验证输出是否与期望值相同
 楼主| 发表于 2012-6-15 16:59:36 | 显示全部楼层
回复 5# SKILLER
  明白了,谢谢了,我起初打算把memory 跟地址一起验证 ,把memory 作为源,去读数据,现在明白了 分开来 保证memory 读写正确 地址控制正确 谢谢
GMT+8, 2025-12-24 20:34 , Processed in 0.023906 second(s), 5 queries , Gzip On, Redis On.
