查看: 15143|回复: 23
BDA FastSpice info
发表于 2012-6-12 04:25:43 | 显示全部楼层 |阅读模式
Any lead to BDA (Berkeley Design Automation)  Analog Fast Spice (AFS)?  I have searched the forum but no avail. Thanks in advance.
任何BDA的铅(伯克利设计自动化)快速Spice模拟(AFS)的?我已经搜查了论坛,但无济于事。感谢在前进。
发表于 2012-6-13 12:44:47 | 显示全部楼层
回复 1# AcoAco
    BDA的软件很难能搞到吧,他们家本来就做的很精,性能很好,只是用户没有synopsys家的多。
 楼主| 发表于 2012-6-14 03:26:10 | 显示全部楼层
回复 2# fancy1984
Thank you very much. Indeed "BDA Analog FastSpice" convergence and accuracy is valuable at times to check some circuits. Circuits could be developed with other software but could be checked at the end with "BDA Analog FastSpice", at that point of time a single user capability restriction is suitable. Still I am surprised that no BDA software on the forum.
非常感谢。事实上,“BDA模拟FastSPICE”的收敛性和准确性是有价值的检查部分电路。电路可以与其他软件的开发,但可以在结束检查“BDA的模拟FastSPICE”,一个单一的用户能力的限制,在这个时间点是适合的。我仍然感到意外的是没有在论坛上的BDA软件。
发表于 2013-3-7 11:19:15 | 显示全部楼层
回复 1# AcoAco
    You are right
发表于 2013-9-9 11:00:13 | 显示全部楼层
BDA 和 hsim , finesim , aditspice ..
到底如何?
沒聽過多少人使用 BDA tools ..
发表于 2014-7-16 12:01:47 | 显示全部楼层
BDA被mentor收购了。也想试试,看看结果。
 楼主| 发表于 2014-7-17 16:33:53 | 显示全部楼层
回复 6# waveguides
   你知道到了BDA是集成在哪个产品?Do you know into which product  that BDA is integrated in?
发表于 2014-8-4 18:33:02 | 显示全部楼层
回复 7# AcoAco
Analog FastSPICE Platform
Software Version 2014_Q2
May 2014
发表于 2014-8-5 16:09:20 | 显示全部楼层
回复 8# chipless
   能否上传一下?非常感谢!
 楼主| 发表于 2014-8-6 14:27:26 | 显示全部楼层
回复 7# AcoAco
Mentor Graphics Eldo Premierand
Mentor Graphics Analog Fast Spice (AFS) platform
Mentor graphics has two products those integrates Fast Spice (AFS) from Berkeley Advanced Design (BDA acquired by Mentor in March 2014).
1. Eldo Premier
2. Analog Fast Spice (AFS) platform.
Also Mentor have its own Fast Spice programs like ADIT.
Mentor Graphics公司有两款产品的集成快速Spice(AFS)的伯克利高级设计(北京经济技术开发区2014年3月收购了导师)。
1,国务院总理的Eldo
2,模拟快速Spice(AFS)的平台。
导师也有像ADIT自己的快速Spice程序。
GMT+8, 2025-12-23 03:44 , Processed in 0.025831 second(s), 5 queries , Gzip On, Redis On.
