查看: 7106|回复: 7
[求助] Error : fail to find 'glbl' in hierarchical name?
发表于 2012-6-11 22:09:19 | 显示全部楼层 |阅读模式
如题。。。谢谢
发表于 2012-6-11 22:21:28 | 显示全部楼层
Are you running behavioral simulation with Xilnx verilog models? If so, you have to compile the "glbl.v" file in $Xilinx/verilog/src directory before running the simulation.
 楼主| 发表于 2012-6-13 22:41:55 | 显示全部楼层
回复 2# peppermint
    i compiled all the Xilinx lib files,special the glbl.v
发表于 2012-6-13 22:58:17 | 显示全部楼层
To my memory, you have to load all top module(s) for some old simulators. If the top module name of your testbench is called "testbench" and you have compiled both "testbench.v" and "glbl.v", then you should run
  vsim testbench glbl
rather than
  vsim testbench
 楼主| 发表于 2012-6-14 23:04:17 | 显示全部楼层
回复 4# peppermint
    en,u are right,thanks.
i have another question.
code : reg [4:0]data;
          if (data[4] == 1'b1)
          begin
                 tmp <= a;
          end
          else if (data[3] == 1'b1)
          begin
                 tmp <= b;
          end
          else if (data[0] == 1'b1)
          begin
                 tmp <= e;
          end
i think this is not a good coding and when data == 5'b11111,the DC's result may be different.
what about your idea?
发表于 2012-6-15 10:59:10 | 显示全部楼层
That is a priority encoder. I think it is OK if you want it to be that way.
 楼主| 发表于 2012-6-15 23:22:32 | 显示全部楼层
回复 6# peppermint
    thanks.
but i think it's better to use case clause for it.
发表于 2012-6-16 06:29:07 | 显示全部楼层
It would be easier to read the casez or casex statements. For a priority encoder, the resultant synthesized netlist will be the same.
GMT+8, 2025-12-22 20:49 , Processed in 0.024659 second(s), 5 queries , Gzip On, Redis On.
