查看: 27463|回复: 63
Coware Processor Designer V2010.1.0 (win) 100% working crack
发表于 2012-6-10 22:10:43 | 显示全部楼层 |阅读模式
See also below thread:
Doc for synopsys processor designer 2011
http://bbs.eetop.cn/viewthread.p ... rocessor%2Bdesigner
Coware company has been taken by Synopsys so for newer versions refer to:
http://www.synopsys.com/Systems/BlockDesign/ProcessorDev/Pages/default.aspx
PD.rar
9.73 MB, 下载次数: 813 , 下载积分: 资产 -4 信元, 下载支出 4 信元
发表于 2012-6-11 00:37:44 | 显示全部楼层
软件在哪里啊??
 楼主| 发表于 2012-6-11 01:25:55 | 显示全部楼层
发表于 2012-6-11 07:50:07 | 显示全部楼层
 楼主| 发表于 2012-6-11 08:29:10 | 显示全部楼层
Yes I know. They are only for release notes and also encouraging someone posts that or newer version.
Be ware that processors are the heart of every SoC design and all of the ESL Softwares from Mentor, cadence, synopsys, carbon and etc will be meaningless without them. Processor designing is the most challenging job in Electronic engineering and Today's companies are moving to TLM-2 based models for rapid virtual prototyping. EDA companies' providing Processor designing tools are not really mature for creating every abstract levels and moving from one level to the other should be done manualy though some companies are trying to automate them. For more info refer to:
http://www.ovpworld.org
http://portal.carbondesignsystems.com/Default.aspx?CategoryView=1
http://bbs.eetop.cn/thread-335946-1-1.html
发表于 2012-6-11 11:32:00 | 显示全部楼层
great great great
发表于 2012-6-11 20:54:25 | 显示全部楼层
Yes I know. They are only for release notes and also encouraging someone posts that or newer version ...
ald_syn_cad 发表于 2012-6-11 08:29
的确如此啊。
btw,本版有Carbon的工具,还挺新的,就是没有XX。
发表于 2012-6-12 14:06:55 | 显示全部楼层
测试了一次,初步成功了。
当然还有一些问题:测试编译一个项目,cl.exe选择VC6版本时,直接提示“ Error! Problems during build”;选择VC2010版本,依然会提示较多的“error LNK2001”、“error LNK2019”的故障。
原因继续检查一下吧。
发表于 2012-6-12 14:18:31 | 显示全部楼层
按照coware的说明,最佳版本是VC2008,简单点的可以安装一个VC2008 Express版本,当然按照完整的VC2008更好。现在找一下VC2008版本去。
发表于 2012-6-12 15:56:15 | 显示全部楼层
本破解非常成功!
安装了Visual C++ 2008 Express Edition,Coware Processor Designer V2010很快就认出了该版本的CL.exe工具。之后使用一个example进行的编译均获得通过。
Coware Processor数年前就接触到,可惜一直没有破解成功,对设计CPU来说实在是很大的遗憾。现在相当于获得了一个相当重分量的CPU设计工具。
再配合一下另一个工具simics来进行系统级的模拟,加上手工设计VerilogHDL级别的简单处理器,可以大大上一个台阶了!
十分感谢楼主。
GMT+8, 2025-12-25 23:09 , Processed in 0.029227 second(s), 8 queries , Gzip On, Redis On.
