已知Die的SPICE模型和配套的封装的SPICE模型,如何拟合出 Fmin Zopt Rn?
我正在弄的是BFP640这款,想拟合出500Mhz的相关参数,原厂只提供了900Mhz以上的噪声参数
spice文件如下:
* Infineon Technologies AG
* GUMMEL-POON Transistor MODEL IN SPICE 2G6 SYNTAX
* BFP640 Model in SOT343
* Incuding 1/f Noise Model and Temperature Model
* June 2002
* For DC-simulations, the parameter set is valid in the
* temperature range from T = -25 癈 upto T = 125 癈.
* The AC-behaviour is correctly simulated only at T = 25 癈.
* In order to simulate S-Parameters at T = -25 癈 resp.
* T = 125 癈, the parameter ITF of the main transistor must
* be modified by the following equation:
* ITF(T) = ITF(To) * ( 1 - 6.5e-3 * (T-To) + 1.0e-5 * (T-To)^2 )
* To = 25 癈
* This means:
* ITF(-25 癈) = 1.35 * ITF(25 癈)
* ITF(125 癈) = 0.45 * ITF(25 癈)
* If in Parameter Set available set:
* TITF1 = -6.5e-3
* TITF2 = 1.0e-5
* BFP640
*.OPTION TNOM = 25, GMIN = 1.0E-12
* BFP640 C B E
.SUBCKT BFP640 1 2 3
X1 22 11 33 2 1 3 SOT343_BFP640
X2 11 22 33 CHIP_BFP640
.ENDS BFP640
* Chip parasitics BFP640
* CHIP_BFP640 C B E
.SUBCKT CHIP_BFP640 1 2 3
Q1 10 20 30 4 M_BFP640
CBEC 20 30 9.840E-14
CBCC 20 10 5.593E-14
LBC 2 20 1.200E-10
LCC 1 10 1.200E-10
LEC 3 30 2.000E-11
CES 3 33 1.800E-13
CBS 2 22 7.900E-14
CCS 1 11 7.500E-14
RBS 4 22 1.200E+03
RCS 4 11 1.200E+03
RES 4 33 3.000E+02
.ENDS CHIP_BFP640
* Package Model SOT343 for BFP640
* SOT343_BFP640 Bi Ci Ei Bo Co Eo
.SUBCKT SOT343_BFP640 1 2 3 10 20 30
LBB 1 10 0.6962E-9
LCB 2 20 0.6824E-9
LEB 3 30 0.2306E-9
CCEO 20 30 131.2E-15
CBEO 30 10 102.5E-15
CCEI 2 3 112.6E-15
CBEI 3 1 180.4E-15
.ENDS SOT343_BFP640
* BJT Model SOT343 for BFP640
.MODEL M_BFP640 NPN(
+ IS = 2.200E-16
+ NF = 1.025E+00
+ BF = 4.500E+02
+ NE = 2.000E+00
+ ISE = 2.100E-14
+ NR = 1.000E+00
+ BR = 5.500E+01
+ NC = 1.800E+00
+ ISC = 4.000E-13
+ VAF = 1.000E+03
+ VAR = 2.000E+00
+ IKF = 1.500E-01
+ IKR = 3.800E-03
+ RB = 3.129E+00
+ RBM = 2.707E+00
+ IRB = 1.522E-03
+ RE = 6.000E-01
+ RC = 3.061E+00
+ XTB =-1.420E+00
+ EG = 1.078E+00
+ XTI = 3.000E+00
+ TF = 1.800E-12
+ VTF = 1.500E+00
+ XTF = 1.000E+01
+ ITF = 4.000E-01
+ CJE = 2.276E-13
+ VJE = 8.000E-01
+ MJE = 3.000E-01
+ CJC = 6.743E-14
+ VJC = 6.000E-01
+ MJC = 5.000E-01
+ XCJC = 1.000E+00
+ CJS = 9.335E-14
+ VJS = 6.000E-01
+ MJS = 2.700E-01
+ FC = 8.000E-01
+ TR = 2.000E-10
+ PTF = 0.000E+00
+ AF = 2.000E+00
+ KF = 7.291E-11
+ TNOM = 25)
配套的S2P文件 1V 4mA的文件如下:
! Infineon Technologies Discrete & RF Semiconductors
! BFP640
! VCE = 1.0 V, IC = 4.0 mA
! Common Emitter S-Parameters: Sep 2002
# GHz S MA R 50
! f S11 S21 S12 S22
! GHz MAG ANG MAG ANG MAG ANG MAG ANG
0.100 0.9366 -6.7 12.759 173.5 0.0066 83.0 0.9967 -4.4
0.200 0.9357 -13.9 12.709 168.4 0.0146 82.9 0.9909 -8.7
0.300 0.9260 -21.0 12.518 163.1 0.0223 79.6 0.9781 -13.0
0.400 0.9103 -27.9 12.249 157.7 0.0296 75.9 0.9600 -17.1
0.500 0.8909 -34.6 11.936 152.3 0.0364 72.1 0.9381 -21.1
0.600 0.8690 -41.2 11.595 147.2 0.0428 68.4 0.9132 -24.9
0.700 0.8455 -47.5 11.236 142.4 0.0488 64.9 0.8862 -28.5
0.800 0.8211 -53.6 10.864 137.8 0.0543 61.5 0.8578 -31.8
0.900 0.7961 -59.5 10.482 133.5 0.0593 58.4 0.8285 -35.0
1.000 0.7711 -65.1 10.097 129.5 0.0639 55.4 0.7988 -37.9
1.100 0.7463 -70.6 9.714 125.6 0.0680 52.7 0.7694 -40.6
1.200 0.7222 -75.8 9.339 122.0 0.0718 50.2 0.7406 -43.1
1.300 0.6988 -80.9 8.977 118.5 0.0752 47.8 0.7127 -45.5
1.400 0.6765 -85.8 8.633 115.2 0.0782 45.7 0.6861 -47.6
1.500 0.6554 -90.5 8.308 112.0 0.0810 43.7 0.6607 -49.6
1.600 0.6356 -95.1 8.004 109.0 0.0835 41.9 0.6368 -51.4
1.700 0.6171 -99.5 7.718 106.0 0.0859 40.2 0.6143 -53.1
1.800 0.6000 -103.8 7.449 103.3 0.0880 38.7 0.5931 -54.7
1.900 0.5842 -107.9 7.194 100.6 0.0900 37.2 0.5731 -56.2
2.000 0.5697 -112.0 6.950 98.1 0.0919 35.9 0.5542 -57.6
2.200 0.5442 -119.8 6.492 93.3 0.0955 33.5 0.5193 -60.2
2.400 0.5226 -127.2 6.076 88.7 0.0988 31.4 0.4876 -62.5
2.600 0.5039 -134.4 5.720 84.4 0.1018 29.4 0.4590 -64.7
2.800 0.4878 -141.2 5.425 80.2 0.1045 27.7 0.4339 -66.7
3.000 0.4750 -147.9 5.103 76.3 0.1072 26.1 0.4115 -68.5
3.500 0.4505 -163.2 4.502 66.9 0.1139 22.4 0.3669 -73.1
4.000 0.4378 -177.0 4.008 58.4 0.1201 19.0 0.3226 -77.3
4.500 0.4358 170.2 3.622 50.4 0.1262 16.3 0.2897 -80.3
5.000 0.4367 158.0 3.294 42.5 0.1329 13.5 0.2642 -83.8
5.500 0.4417 147.0 3.018 35.3 0.1398 10.8 0.2382 -88.5
6.000 0.4517 137.1 2.796 28.2 0.1470 8.0 0.2129 -92.5
6.500 0.4626 127.4 2.595 21.2 0.1541 5.1 0.1891 -96.6
7.000 0.4708 118.8 2.429 14.8 0.1619 2.4 0.1699 -100.3
7.500 0.4882 111.3 2.301 8.0 0.1717 -0.9 0.1497 -107.7
8.000 0.5029 103.6 2.164 1.5 0.1788 -4.3 0.1245 -112.7
8.500 0.5209 97.1 2.071 -4.7 0.1897 -7.4 0.1093 -121.9
9.000 0.5433 90.4 1.978 -11.5 0.1993 -11.7 0.0855 -135.4
9.500 0.5620 84.0 1.896 -17.9 0.2088 -15.9 0.0642 -153.7
10.000 0.5842 78.0 1.826 -24.8 0.2182 -20.5 0.0505 174.4
10.500 0.6010 72.4 1.735 -31.9 0.2229 -25.7 0.0530 137.7
11.000 0.6302 67.3 1.663 -37.9 0.2291 -28.8 0.0720 104.0
11.500 0.6543 62.2 1.602 -44.4 0.2365 -34.1 0.0966 86.0
12.000 0.6992 56.9 1.553 -51.4 0.2421 -37.4 0.1359 73.5
12.500 0.7263 50.2 1.477 -58.9 0.2527 -42.1 0.1709 62.3
13.000 0.7471 44.7 1.397 -65.4 0.2616 -47.2 0.2054 53.8
13.500 0.7689 39.1 1.327 -71.5 0.2694 -52.7 0.2417 45.6
14.000 0.7811 33.6 1.259 -78.2 0.2790 -59.7 0.2804 37.1
14.500 0.7972 29.8 1.183 -84.4 0.2714 -68.4 0.3040 31.8
15.000 0.8268 25.9 1.122 -90.1 0.2537 -74.0 0.3371 28.0
15.500 0.8767 21.0 1.063 -95.7 0.2401 -74.0 0.3809 26.1
16.000 0.9056 14.5 1.007 -102.2 0.2538 -77.6 0.4560 19.9
16.500 0.9170 8.7 0.939 -108.7 0.2528 -84.5 0.5117 11.5
17.000 0.9205 3.0 0.860 -114.7 0.2458 -89.4 0.5435 4.2
17.500 0.9113 -1.7 0.784 -119.4 0.2432 -95.1 0.5729 -1.5
18.000 0.8948 -6.1 0.712 -122.5 0.2317 -102.3 0.6032 -8.5
18.500 0.8853 -7.6 0.667 -125.3 0.2027 -109.1 0.5843 -12.3
19.000 0.9314 -11.3 0.614 -129.6 0.1798 -106.6 0.6441 -11.7
19.500 0.9242 -17.3 0.561 -131.2 0.1824 -106.4 0.7039 -17.6
20.000 0.8962 -20.9 0.515 -132.0 0.1849 -109.3 0.7427 -22.4
! f Fmin Gammaopt rn/50
! GHz dB MAG ANG -
0.900 0.34 0.42 20 0.16
1.800 0.67 0.21 40 0.13
2.400 0.74 0.24 63 0.13
3.000 0.86 0.18 106 0.11
4.000 0.95 0.08 174 0.11
5.000 1.14 0.15 -96 0.14
6.000 1.29 0.26 -120 0.13
! (c) 2002 Infineon Technologies AG, Munich |
