查看: 2768|回复: 0
[资料] Linear PCM integrated example test bench 0.4
发表于 2012-5-23 10:58:16 | 显示全部楼层 |阅读模式
Description: A simple integrated example test bench for people who want to learn UVM.
This is pre-alpha, unreviewed and buggy code. If you use this as a basis for anything other than reviewing it for bugs then you're on your own.
If you tape-out something based on this you will waste time and money.
See the README for more information
lpcm-0.4.tar.gz (11.65 KB , 下载次数: 19 )
GMT+8, 2025-12-30 00:08 , Processed in 0.044582 second(s), 7 queries , Gzip On, Redis On.
