查看: 4138|回复: 2
[求助] [未解决] PT问题:min_capacitance 违例
发表于 2012-5-22 19:12:19 | 显示全部楼层 |阅读模式
小弟最近做PT,遇到如下问题:
report_constraint -all_violators > ./log/sd_lpf_top.violators
报告如下,没有 setup、hold 违例,但有很多min_capacitance违例,这是什么意思?怎么解决呢?谢谢啦!
Report : constraint
        -all_violators
        -path slack_only
Design : digital_top
Version: D-2010.06
Date   : Tue May 22 16:39:31 2012
   min_capacitance
                             Required        Actual
   Pin                      Capacitance    Capacitance       Slack
   dto/CSW_cos_reg_0/Q          0.00           0.00           0.00  (VIOLATED: increase significant digits)
   dto/CSW_cos_reg_1/Q          0.00           0.00           0.00  (VIOLATED: increase significant digits)
   dto/CSW_cos_reg_2/Q          0.00           0.00           0.00  (VIOLATED: increase significant digits)
   dto/CSW_cos_reg_3/Q          0.00           0.00           0.00  (VIOLATED: increase significant digits)
   dto/CSW_cos_reg_4/Q          0.00           0.00           0.00  (VIOLATED: increase significant digits)
   dto/CSW_sin_reg_0/Q          0.00           0.00           0.00  (VIOLATED: increase significant digits)
   dto/CSW_sin_reg_1/Q          0.00           0.00           0.00  (VIOLATED: increase significant digits)
   dto/CSW_sin_reg_2/Q          0.00           0.00           0.00  (VIOLATED: increase significant digits)
   dto/CSW_sin_reg_3/Q          0.00           0.00           0.00  (VIOLATED: increase significant digits)
   dto/CSW_sin_reg_4/Q          0.00           0.00           0.00  (VIOLATED: increase significant digits)
   hb1/multiplier2/add_0_root_add_0_root_add_2117/U45/Z
   hb2/multiplier2/add_0_root_add_0_root_add_2117/U45/Z
   hp1/add_1_root_add_0_root_add_1636/U2/Z
   hp1/add_1_root_add_0_root_add_1636/U3/Z
   hp1/add_1_root_add_0_root_add_1636/U4/Z
   hp1/add_1_root_add_0_root_add_1636/U5/Z
   hp1/add_1_root_add_0_root_add_1636/U6/Z
   hp1/add_1_root_add_0_root_add_1636/U7/Z
   hp1/add_1_root_add_0_root_add_1636/U8/Z
   hp1/add_1_root_add_0_root_add_1636/U9/Z
   hp1/add_1_root_add_0_root_add_1636/U10/Z
   hp1/add_1_root_add_0_root_add_1636/U11/Z
   hp1/add_1_root_add_0_root_add_1636/U12/Z
   hp2/add_1_root_add_0_root_add_1636/U2/Z
   hp2/add_1_root_add_0_root_add_1636/U3/Z
   hp2/add_1_root_add_0_root_add_1636/U4/Z
   hp2/add_1_root_add_0_root_add_1636/U5/Z
   hp2/add_1_root_add_0_root_add_1636/U6/Z
   hp2/add_1_root_add_0_root_add_1636/U7/Z
   hp2/add_1_root_add_0_root_add_1636/U8/Z
   hp2/add_1_root_add_0_root_add_1636/U9/Z
   hp2/add_1_root_add_0_root_add_1636/U10/Z
   hp2/add_1_root_add_0_root_add_1636/U11/Z
   hp2/add_1_root_add_0_root_add_1636/U12/Z
   max_area
                             Required        Actual
   Design                       Area           Area          Slack
   digital_top                  0.00       103361.27      -103361.27
        (VIOLATED)
发表于 2012-5-23 00:00:04 | 显示全部楼层
回复 1# shuanghx
    同问,
 楼主| 发表于 2012-5-23 15:02:33 | 显示全部楼层
自己顶顶~
GMT+8, 2025-12-20 23:20 , Processed in 0.017020 second(s), 5 queries , Gzip On, Redis On.
