查看: 5186|回复: 2
[求助] 請教一下,mic in 和 line in 有什么區別?
发表于 2012-5-17 19:36:02 | 显示全部楼层 |阅读模式
如題,非常感謝。
相关帖子
发表于 2012-5-17 22:29:42 | 显示全部楼层
Microphone produces very weak signal (10mV ~ 50mV) which needs to be amplified. Therefore mic in signal goes through amplifier with high gain up to +40dB. Sometimes it's a two stage amplifiers. One is +20dB microphone boost; the other is a PGA (programmable gain amplifier) with gain range around 0dB to +20dB.
Line in signal usually needs little gain. Standard line in/out signal is 1Vrms or 0.75Vrms.
发表于 2012-5-18 09:49:57 | 显示全部楼层
Are there any other difference such as input/output resistance/capacitance, noise consideration, THD and so on
GMT+8, 2025-12-15 11:41 , Processed in 0.017039 second(s), 7 queries , Gzip On, Redis On.
