查看: 11796|回复: 15
[求助] assura做完DRC LVS之后
发表于 2012-5-17 16:36:13 | 显示全部楼层 |阅读模式
assura做完DRC LVS之后  本来想接着做RCX的  但是RCX这个选项莫名奇妙的没有了  出现了QRC这个选项
据说QRC也可以提参 但是QRC不会用
有谁会用QRC的 或者 有相关方面的教程(不要user guide)
或者有谁能够将RCX选项恢复的
用QRC提参的时候,设置和RCX一模一样,但是报错,如下:
INFO (EXTQRCXOPT-249) : For Assura inputs , if the "output_setup -directory_name" option was not specified,  it is automatically set to the input directory.
ERROR (LBRCXM-554): ?capCoupling Factor is an unrecognized rcxParameter in the DFII flow.
ERROR (LBRCXM-554): ?capGround  is an unrecognized rcxParameter in the DFII flow.
ERROR (LBRCXM-554): ?arrayViasSpacing  is an unrecognized rcxParameter in the DFII flow.
ERROR (LBRCXM-554): ?maxFractureLength  is an unrecognized rcxParameter in the DFII flow.
ERROR (LBRCXM-554): ?FractureLengthUnits  is an unrecognized rcxParameter in the DFII flow.
ERROR (LBRCXM-554): ?maxMergeViaSize  is an unrecognized rcxParameter in the DFII flow.
ERROR (LBRCXM-554): ?netNameSpace  is an unrecognized rcxParameter in the DFII flow.
ERROR (LBRCXM-554): ?excludeSelfCaps  is an unrecognized rcxParameter in the DFII flow.
ERROR (LBRCXM-554): ?minC is an unrecognized rcxParameter in the DFII flow.
ERROR (LBRCXM-554): ?minCByPercentage is an unrecognized rcxParameter in the DFII flow.
ERROR (LBRCXM-554): ?minR is an unrecognized rcxParameter in the DFII flow.
ERROR (LBRCXM-554): ?lvsSource is an unrecognized rcxParameter in the DFII flow.
ERROR (LBRCXM-554): ?CapModels is an unrecognized rcxParameter in the DFII flow.
ERROR (LBRCXM-554): ?parasticCapModels is an unrecognized rcxParameter in the DFII flow.
ERROR (LBRCXM-554): ?parasticResModels is an unrecognized rcxParameter in the DFII flow.
ERROR (LBRCXM-554): ?parasticResWidth is an unrecognized rcxParameter in the DFII flow.
ERROR (LBRCXM-554): ?parasticResWidthDrawn is an unrecognized rcxParameter in the DFII flow.
求指教。。。
发表于 2012-5-18 13:52:03 | 显示全部楼层
出现QRC还不好?这是新版的RCX,你可以这么理解。
和RCX用法一样的,界面也一样,放心使用吧。
 楼主| 发表于 2012-5-18 20:50:28 | 显示全部楼层
回复 2# question23
   问题是相同的界面 相同的设置 却提不出来参数  有没有资料参考
发表于 2012-5-19 10:26:43 | 显示全部楼层
回复 3# lyz5432
    看看log有什么错误提示吧。
 楼主| 发表于 2012-5-26 13:40:34 | 显示全部楼层
回复 4# question23
   今天又做了一次QRC  报错如下:INFO (EXTQRCXOPT-249) : For Assura inputs , if the "output_setup -directory_name" option was not specified,  it is automatically set to the input directory.
这些不知道什么意思,网上的资料也很少
发表于 2012-5-27 12:28:56 | 显示全部楼层
回复 5# lyz5432
    看起来原因是你的Assura版本太老,从新安装一个新版的assura。还要保证和软件和操作系统匹配,和rule匹配。
发表于 2012-5-27 15:49:50 | 显示全部楼层
学习到了
 楼主| 发表于 2012-5-27 16:39:58 | 显示全部楼层
回复 6# question23
貌似assura和规则文件都太旧了  才这样的 我换个新的试试。。。多谢
发表于 2012-5-27 17:48:19 | 显示全部楼层
回复 8# lyz5432
    规则文件都会指定相关软件版本的,好好阅读一下readme
发表于 2019-11-9 00:53:43 来自手机 | 显示全部楼层
我最近在RHEL6.9里也有遇到ERROR (LBRCXM-554)的错误,原因是缺少rpm包。遇到此类错误,可以先试着在命令行里使用命令执行qrc软件进行排错,这样能检查出是否由于系统库缺失造成的:qrc  -cmd -32或者qrc  -cmd -64。
GMT+8, 2025-12-22 10:29 , Processed in 0.022356 second(s), 5 queries , Gzip On, Redis On.
