查看: 4348|回复: 3
[原创] 综合时一定要用CCS model吗? 毕竟综合时还没有physical呢!
发表于 2012-5-11 10:29:49 | 显示全部楼层 |阅读模式
是不是APR时用CCS model更合适呢? 以下是从DC手册截取的一段话,
Design Compiler supports logic libraries that use nonlinear delay models (NLDMs),
Composite Current Source (CCS) models (either compact or noncompact), or both. Design
Compiler automatically selects the timing model to use based on the contents of the logic
libraries. If the logic libraries contain only CCS models, the tool uses CCS models. If the
libraries contain nonlinear delay models (NLDMs) or both NLDM and Composite Current
Source (CCS) models, the tool uses the NLDM models. For optimal runtime and the level of
accuracy, the tool may not use all of the CCS data during logic synthesis and pre-route
optimizations.
当NLDM和CCS共存时,CCS根本不与考虑, 这是啥道理,看来DC有改进的必要。
发表于 2012-5-11 17:15:25 | 显示全部楼层
CSS是分析crosstalk glitch的,综合的时候用NLDM就够了吧~
发表于 2012-5-11 17:20:37 | 显示全部楼层
For optimal runtime and the level of accuracy
这个就是原因吧,即使是physical synthesis,也很少用ccs model。
发表于 2012-5-28 12:09:15 | 显示全部楼层
用CCS可以替代SPICE仿真麽?
GMT+8, 2025-12-28 10:33 , Processed in 0.018023 second(s), 7 queries , Gzip On, Redis On.
