查看: 4645|回复: 0
[求助] 请问一般论文说的Xilinx的Slices数是报告中的LUT+Register吗?
发表于 2012-5-9 22:00:57 | 显示全部楼层 |阅读模式
Slice Logic Utilization:
  Number of Slice Registers:                    97 out of  28,800    1%
    Number used as Flip Flops:                  81
    Number used as Latches:                     16
  Number of Slice LUTs:                        336 out of  28,800    1%
    Number used as logic:                      334 out of  28,800    1%
      Number using O6 output only:             319
      Number using O5 output only:              13
      Number using O5 and O6:                    2
    Number used as exclusive route-thru:         2
  Number of route-thrus:                        15
    Number using O6 output only:                14
    Number using O5 and O6:                      1
Slice Logic Distribution:
  Number of occupied Slices:                   115 out of   7,200    1%
  Number of LUT Flip Flop pairs used:          354
    Number with an unused Flip Flop:           257 out of     354   72%
    Number with an unused LUT:                  18 out of     354    5%
    Number of fully used LUT-FF pairs:          79 out of     354   22%
    Number of unique control sets:              14
    Number of slice register sites lost
      to control set restrictions:              11 out of  28,800    1%
假如报告如此,那写论文时,Slices数等于Slice Registers+Slice LUTs吗??
另外想问一下一些论文说什么工艺库下测得的功耗为XX uW,我在synopsys下report power最起码都是mW,哪里来uW的测试数据呢??
GMT+8, 2025-12-20 18:09 , Processed in 0.011194 second(s), 4 queries , Gzip On, Redis On.
