查看: 3823|回复: 1
[求助] 关于star-mtb的使用与错误解决,后续软件
发表于 2012-5-9 00:13:26 | 显示全部楼层 |阅读模式
synopsys的star-mtb是2004年就停止继续升级的EDA工具,能够将spice网表,通过hspice模拟,提取信息,生成synopsys可以使用的lib和db文件,但是现在遇到一些问题,不知还有没有会使用?
有没有人知道,它的后续软件是什么?
运行
synopsys_model_build -mode full -ps 1 -tol 2 -r yes -c yes -a ../<library>.rcf -f ../ <library>.sld -kav yes -pwr yes -sarc yes -mcf all -d median
后,报错,其中
dc_shell.log中的错误如下:
                        DC Professional (TM)
                           DC Expert (TM)
                            DC Ultra (TM)
                       FloorPlan Manager (TM)
                          HDL Compiler (TM)
                         VHDL Compiler (TM)
                        Library Compiler (TM)
                      DesignWare Developer (TM)
                          DFT Compiler (TM)
                            BSD Compiler
                         Power Compiler (TM)
             Version C-2009.06 for linux -- May 21, 2009
              Copyright (c) 1988-2008 by Synopsys, Inc.
                         ALL RIGHTS RESERVED
This software and the associated documentation are confidential and
proprietary to Synopsys, Inc. Your use or disclosure of this software
is subject to the terms and conditions of a written license agreement
between you, or your company, and Synopsys, Inc.
The above trademark notice does not imply that you are licensed to use
all of the listed products. You are licensed to use only those products
for which you have lawfully obtained a valid license key.
Initializing...
read_lib inv.lib_cell
Reading '/home/d3/synopsys/inv/inv.lib_cell' ...
Warning: Line 31, Found a duplicate nom_process attribute. Using the latest value. (LBDB-16)
Warning: Line 32, Found a duplicate nom_temperature attribute. Using the latest value. (LBDB-16)
Warning: Line 33, Found a duplicate nom_voltage attribute. Using the latest value. (LBDB-16)
Warning: Line 92, Cell 'INV', The 'area' attribute is not specified. Using 0.00. (LBDB-172)
Warning: Line 94, Cell 'INV', pin 'IN', The port 'IN' does not have the attribute 'rise_capacitance_range' specified. The value (6.080000, 6.080000) will be assigned to the attribute. (LBDB-1054)
Warning: Line 94, Cell 'INV', pin 'IN', The port 'IN' does not have the attribute 'fall_capacitance_range' specified. The value (2.638000, 2.638000) will be assigned to the attribute. (LBDB-1054)
Warning: Line 1, The 'default_fanout_load' attribute is not specified. Using 1.00. (LBDB-172)
Warning: Line 1, The 'default_inout_pin_cap' attribute is not specified. Using 1.00. (LBDB-172)
Warning: Line 1, The 'default_input_pin_cap' attribute is not specified. Using 1.00. (LBDB-172)
Warning: Line 1, The 'default_output_pin_cap' attribute is not specified. Using 0.00. (LBDB-172)
Warning: Line 1, The default_operating_conditions is not defined. operating_conditions "nom_pvt" is created
and set as the default_operating_conditions. (LBDB-662)
Technology library 'inv' read successfully
1
read -f verilog inv.voct
Error: wrong # args: should be "read channelId ?numChars?" or "read ?-nonewline? channelId"
Use error_info for more info. (CMD-013)
link_library = target_library = inv.db
Error: unknown command 'link_library' (CMD-005)
link
Error: Current design is not defined. (UID-4)
0
include inv_l_150_s_1000_typ.dcsh
Error: unknown command 'include' (CMD-005)
write_sdf  inv_l_150_s_1000_typ.sdf
0
include inv_l_150_s_100_typ.dcsh
write_sdf  inv_l_150_s_100_typ.sdf
0
include inv_l_150_s_20_typ.dcsh
write_sdf  inv_l_150_s_20_typ.sdf
0
include inv_l_150_s_500_typ.dcsh
write_sdf  inv_l_150_s_500_typ.sdf
0
include inv_l_15_s_1000_typ.dcsh
write_sdf  inv_l_15_s_1000_typ.sdf
0
include inv_l_15_s_100_typ.dcsh
write_sdf  inv_l_15_s_100_typ.sdf
0
include inv_l_15_s_20_typ.dcsh
write_sdf  inv_l_15_s_20_typ.sdf
0
include inv_l_15_s_500_typ.dcsh
write_sdf  inv_l_15_s_500_typ.sdf
0
include inv_l_30_s_1000_typ.dcsh
write_sdf  inv_l_30_s_1000_typ.sdf
0
include inv_l_30_s_100_typ.dcsh
write_sdf  inv_l_30_s_100_typ.sdf
0
include inv_l_30_s_20_typ.dcsh
write_sdf  inv_l_30_s_20_typ.sdf
0
include inv_l_30_s_500_typ.dcsh
write_sdf  inv_l_30_s_500_typ.sdf
0
include inv_l_5_s_1000_typ.dcsh
write_sdf  inv_l_5_s_1000_typ.sdf
0
include inv_l_5_s_100_typ.dcsh
write_sdf  inv_l_5_s_100_typ.sdf
0
include inv_l_5_s_20_typ.dcsh
write_sdf  inv_l_5_s_20_typ.sdf
0
include inv_l_5_s_500_typ.dcsh
write_sdf  inv_l_5_s_500_typ.sdf
0
include inv_l_75_s_1000_typ.dcsh
write_sdf  inv_l_75_s_1000_typ.sdf
0
include inv_l_75_s_100_typ.dcsh
write_sdf  inv_l_75_s_100_typ.sdf
0
include inv_l_75_s_20_typ.dcsh
write_sdf  inv_l_75_s_20_typ.sdf
0
include inv_l_75_s_500_typ.dcsh
write_sdf  inv_l_75_s_500_typ.sdf
0
quit
Memory usage for this session 27 Mbytes.
CPU usage for this session 2 seconds ( 0.00 hours ).
Thank you...
发表于 2013-3-7 06:37:13 | 显示全部楼层
现在他收购了silliconsmart
GMT+8, 2025-12-20 21:10 , Processed in 1.644575 second(s), 5 queries , Gzip On, Redis On.
