查看: 2391|回复: 2
[招聘] NO.82-Sr.IC Layout Designer(Shanghai)
发表于 2012-5-7 15:44:32 | 显示全部楼层 |阅读模式
Purpose:
The primary objective of this role is to transform IC schematics and related design material into physical IC layout representations.
Responsibilities:
1. Perform challenging IC mask design of advanced analog mixed signal and flash memory IC'S
2. Develop layout floor plans to optimize die size and circuit performance;
3. Plan and construct circuits, including critical signal and power bussing to analog layout guidelines;
4. Perform DRC and LVS verification of layout;
5. Other duties and when required.
Requirements:
1. Thorough understanding of IC layout design including use of CAD tools such as DRC, LVS and skill programs
2. Must be good at problem solving
3. Must have the ability to communicate effectively
4. Minimum of 4 years experience in IC layout. Use of cadence Virtuoso XL, Calibre Drc.
Other Attributes
Use of Cadence Virtuoso-XL, P-cells, Calibre DRC/LVS Qualification Bachelor Degree or higher preferred
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
发表于 2012-5-7 19:30:09 | 显示全部楼层
挺好的,我很想做layout 工作
 楼主| 发表于 2012-5-9 13:33:31 | 显示全部楼层
回复 2# icfbicfb
    那就把简历发过来吧
GMT+8, 2025-12-21 12:18 , Processed in 0.012868 second(s), 3 queries , Gzip On, Redis On.
