查看: 8062|回复: 5
ic615启动时出现如下问题,怎么弄呀
发表于 2012-5-4 20:03:47 | 显示全部楼层 |阅读模式
19:43:23 (lmgrd)
19:43:23 (lmgrd) FLEXnet Licensing (v11.7.0.0 build 73797 i86_lsb) started on lei (linux) (5/4/2012)
19:43:23 (lmgrd) Copyright (c) 1988-2009 Acresso Software Inc. All Rights Reserved.
19:43:23 (lmgrd) US Patents 5,390,297 and 5,671,412.
19:43:23 (lmgrd) World Wide Web:  http://www.acresso.com
19:43:23 (lmgrd) License file(s): /home/lei/cadence/installs/IC615/share/license/license.dat
19:43:23 (lmgrd) lmgrd tcp-port 5288
19:43:23 (lmgrd) The license server manager has found no vendor daemons to start
19:43:23 (lmgrd)  (There are no VENDOR (or DAEMON) lines in the license file),
    lmgrd exiting.
这是怎么回事呀,各位大侠回答下呀
发表于 2012-5-4 22:19:52 | 显示全部楼层
......The license server manager has found no vendor daemons to start
License file ( /home/lei/cadence/installs/IC615/share/license/license.dat )
欠缺對DAEMON( cdslmd )的設定 :
DAEMON cdslmd your_path/cdslmd
提供參考 !!
 楼主| 发表于 2012-5-5 08:26:59 | 显示全部楼层
回复 2# lik4965
  谢谢呀,倒是搞定这个问题了,不过问题不断呀,都怪自己用的ubuntu太新了,patch都不能用,缺少一些老的库文件,换个低版本的试试
发表于 2012-7-19 09:14:29 | 显示全部楼层
回复 3# fl550780
请问这个问题您是怎么解决的?
发表于 2012-7-31 11:17:21 | 显示全部楼层
坚持就是胜利,,,我也在用UBUNTU12.04安装这些EDA软件,,,
发表于 2012-8-1 22:18:14 | 显示全部楼层
回复 6# wlf204
   只用Redhat AS4的路过。。。。。这个和windows系统也一样,太新的不支持~~~~
GMT+8, 2025-12-14 02:55 , Processed in 0.019244 second(s), 6 queries , Gzip On, Redis On.
