查看: 15402|回复: 47
A Continuous-Time Sigma-Delta Modulator(IEEE2004)
发表于 2006-11-30 12:45:54 | 显示全部楼层 |阅读模式
IEEE JOURNAL OF SOLID-STATE CIRCUITS, VOL. 39, NO. 1, JANUARY 2004 75
A Continuous-Time Sigma-Delta Modulator With 88-dB Dynamic Range and 1.1-MHz Signal Bandwidth
Shouli Yan, Member, IEEE, and Edgar Sánchez-Sinencio, Fellow, IEEE
Abstract—This paper presents the design and experimental results
of a continuous-time Sigma-Delta  modulator for ADSL applications.
Multibit nonreturn-to-zero (NRZ) DAC pulse shaping is used to reduce
clock jitter sensitivity. The nonzero excess loop delay problem
in conventional continuous-time Sigma-Delta  modulators is solved by our
proposed architecture. A prototype third-order continuous-time
Sigma-Delta  modulator with 5-bit internal quantization was realized in
a 0.5- m double-poly triple-metal CMOS technology, with a chip
area of 2.4 2.4 mm2. Experimental results show that the modulator
achieves 88-dB dynamic range, 84-dB SNR, and 83-dB SNDR
over a 1.1-MHz signal bandwidth with an oversampling ratio of 16,
while dissipating 62 mW from a 3.3-V supply.
Index Terms—Analog-to-digital conversion, CMOS analog integrated
circuits, continuous-time Sigma-Delta modulation, multibit internal
quantization.
01261290.pdf
880.26 KB, 下载次数: 198 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2006-11-30 15:31:35 | 显示全部楼层
goooooooooooooooood
发表于 2006-11-30 16:06:29 | 显示全部楼层
Thanks
发表于 2007-1-31 22:55:42 | 显示全部楼层
回复 #1 semico_ljj 的帖子
连续时间得还没看过。
发表于 2007-6-10 00:23:33 | 显示全部楼层
偶有这个,就不花钱了。
发表于 2007-6-11 12:59:16 | 显示全部楼层
it seems more and more people are working on CT sigma delta now.
a promising design architecture .
Thanks
发表于 2007-6-17 18:57:58 | 显示全部楼层
不错,正找 着呢,谢谢。
发表于 2007-6-18 14:07:55 | 显示全部楼层
文章不错,正在研究中
发表于 2007-6-18 20:42:29 | 显示全部楼层
xiexie !!
发表于 2007-12-6 21:37:46 | 显示全部楼层
hao dong dong
GMT+8, 2025-12-14 17:46 , Processed in 0.027885 second(s), 8 queries , Gzip On, Redis On.
