查看: 8044|回复: 3
[求助] check_timing的warning,请帮忙分析。
发表于 2012-4-22 21:26:27 | 显示全部楼层 |阅读模式
sta时,check_timing出很多warning,命令返回0,如何逐个debug?我贴出log信息:
pt_shell> check_timing
Information: Checking 'no_driving_cell'.
Information: Checking 'unconstrained_endpoints'.
Warning: There are 25 endpoints which are not constrained for maximum delay.
Information: Checking 'unexpandable_clocks'.
Warning: There is 1 clock set for which periods were not expandable.
Information: Checking 'latch_fanout'.
Information: Checking 'no_clock'.
Warning: There are 7 register clock pins with no clock.
Information: Checking 'partial_input_delay'.
Warning: There are 34 ports with partially defined input delays.
Information: Checking 'generic'.
Information: Checking 'loops'.
Warning: There are 57 timing loops in the design.
Information: Checking 'generated_clocks'.
Information: Checking 'pulse_clock_non_pulse_clock_merge'.
Information: Checking 'pll_configuration'.
0
pt_shell>
发表于 2012-4-23 00:19:40 | 显示全部楼层
这一条条说得够清楚了,加-verbose选项看详细的list,照着改就是了
发表于 2012-4-25 17:23:50 | 显示全部楼层
据经验来,基本上就是看看,很少有实质上的作用
发表于 2012-4-26 01:34:59 | 显示全部楼层
那个warning 也会导致返回值是0吗
GMT+8, 2025-12-20 11:06 , Processed in 0.022251 second(s), 7 queries , Gzip On, Redis On.
