系统版本。虚拟机REHL4先前一段时间曾在服务器上成功安装了ic610.没有出现问题。
现在安装的过程同上一次一样。安装中没有报错。
在终端输入lmli回车icfb&回车后。ic610能够启动。但启动的框里显示有error和warning
具体如下
PYRIGHT © 1992-2006 CADENCE DESIGN SYSTEMS INC. ALL RIGHTS RESERVED.
© 1992-2006 UNIX SYSTEMS Laboratories INC.,
Reproduced with permission.
This Cadence Design Systems program and online documentation are
proprietary/confidential information and may be disclosed/used only
as authorized in a license agreement controlling such use and disclosure.
RESTRICTED RIGHTS NOTICE (SHORT FORM)
Use/reproduction/disclosure is subject to restriction
set forth at FAR 1252.227-19 or its equivalent.
Program:
@(#)$CDS: virtuoso.exe version 6.1.0 10/10/2006 14:09 (cds126047) $
Sub version:
sub-version IC6.1.0.243 (32-bit addresses)
Loading geView.cxt
Loading LVS.cxt
Loading layerProc.cxt
Loading xlUI.cxt
Loading auCore.cxt
Loading schView.cxt
Loading selectSv.cxt
Loading vhdl.cxt
Loading seismic.cxt
Loading ams.cxt
Loading NCSU CDK 1.5.1 customizations...
loading vars from /home/pdk/ncsu/cdssetup/cdsenv for tool adle
loading vars from /home/pdk/ncsu/cdssetup/cdsenv for tool asimenv
loading vars from /home/pdk/ncsu/cdssetup/cdsenv for tool ddserv
loading vars from /home/pdk/ncsu/cdssetup/cdsenv for tool layout
loading vars from /home/pdk/ncsu/cdssetup/cdsenv for tool schematic
loading vars from /home/pdk/ncsu/cdssetup/cdsenv for tool ui
*WARNING* Cannot find /home/eda/ic610/tools.lnx86/dfII/etc/tools/cdsSpice directory to load environment variables
loading vars from /home/pdk/ncsu/cdssetup/cdsenv for tool mmsimenv
loading vars from ~/.cdsenv for tool mmsimenv
loading vars from ~/.cdsenv for tool asimenv
loading vars from /home/pdk/ncsu/cdssetup/cdsenv for tool spectre
loading vars from ~/.cdsenv for tool spectre
loading vars from /home/pdk/ncsu/cdssetup/cdsenv for tool ams
loading vars from ~/.cdsenv for tool ams
Loading awv.cxt
*WARNING* There were no system .cdsplotinit files found.
Loading NCSU SKILL routines...
Loading oasis.cxt
ERROR (ADE-5066): Tool 'spectreS' has not been registered.
ERROR (ADE-5067): Unable to initialize tool 'spectreS'; either tool class is not
defined or tool is not registered.
*Error* The default SKILL generic function has not been defined for the function "asiEnvGetVar". Ensure that this function is called with the correct argument(s) (tool partition name).
// Calibre Skill Interface * (v2009.2_36.21) *
// Copyright Mentor Graphics Corporation 2005
// All Rights Reserved.
// THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
// WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION
// OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.
因为出现了这个error。在画原理图的时候,点添加元件。根本看不到元件。而且原理图底色是一片黑。正常应该是有点点的。
如下图
请问是我安装的问题?还是设置的问题????
这个问题是我上次没有遇到过的。。还有这个虚拟机的系统中已经安装了ic5141,synopsys等一系列的有关工具。会不会有什么冲突?
请高手解答。很着急。谢谢 |
