查看: 6314|回复: 4
[求助] 一个primetime annotated的问题
发表于 2012-4-18 23:56:54 | 显示全部楼层 |阅读模式
以下是我的大概步骤set power_enable_analysis TRUE
set link_path
read_verilog
link
set_wire_load_model
create_clock
read_sdc
read_vcd :在这时候,显示
Summary:
Total number of nets = 50237
Number of annotated nets = 50237 (100.00%)
Total number of leaf cells = 33717
Number of fully annotated leaf cells = 33717 (100.00%)
但之后我用
report_annotated_power 显示
                                         |           |                  |    NOT    |
     Cell type                       |    Total  | Annotated | Annotated |
unresolved black-box cell    |        0  |        0      |        0  |
leaf cell                              |    33717  |        0     |    33717  |
所有的cells又都没有被annotated,我的pt_shell version    - F-2011.06-SP1
这是咋回事啊。
万分感谢啊
发表于 2012-4-19 08:42:03 | 显示全部楼层
难道上面的是sdf?
发表于 2012-4-19 09:09:07 | 显示全部楼层
用report_power 试试?
 楼主| 发表于 2012-4-19 13:04:58 | 显示全部楼层
确实是sdc,并且report_power之后还是那样。不管咋样谢谢回复哈
 楼主| 发表于 2012-4-19 13:10:01 | 显示全部楼层
我看report_annotated_power这个说明
DESCRIPTION
This command provides a summary report of how many powers are annotated
in the current design and, if the -list_annotated option is specified,
a list of cells with power values annotated on them.
EXAMPLES
The following example shows how power is annotated, removed, and
reported.
pt_shell> set_annotated_power -int 1 -leak 0.01 u0/*
1
pt_shell> report_annotated_power -list_annotated
我需要自己手动设置这个annotated power information吗,还是通过vcd文件它就可以自己找到这个annotated power 信息啊。
GMT+8, 2025-12-14 13:05 , Processed in 0.019812 second(s), 5 queries , Gzip On, Redis On.
