查看: 2090|回复: 2
求翻译
发表于 2006-11-29 15:16:10 | 显示全部楼层 |阅读模式
The voltage drops are added together
and applied as VPRE-AVP between the AVP and IN+ pins,
which are connected through resistor RPRE-AVP.
看不懂,翻译一下,谢谢!
发表于 2006-11-30 14:38:14 | 显示全部楼层
回复 #1 deangreen 的帖子
所有电压降,作为Vpre-avp作用在电阻Rpre-avp上,电阻连接在AVP和IN+管脚之间。
 楼主| 发表于 2006-12-1 09:25:33 | 显示全部楼层
thanks
GMT+8, 2025-12-25 22:37 , Processed in 0.022838 second(s), 6 queries , Gzip On, Redis On.
