查看: 10858|回复: 19
Cadence Allegro SPB 16.5 Hotfix_SPB16.50.018_wint_1of1.exe
发表于 2012-4-16 11:07:34 | 显示全部楼层 |阅读模式
Cadence SPB OrCAD 16.5.018 (Allegro SPB) Hotfix | 567MB
Cadence OrCAD PCB design suites combine industry-leading, production-proven, and highly scalable PCB design applications to deliver complete schematic entry, simulation, and place-and-route solutions. With these powerful, intuitive tools that integrate seamlessly across the entire PCB design flow, engineers can quickly move products from conception to final output.
Cadence Design Systems is the world’s leading EDA company. Cadence customers use our software, hardware, and services to overcome a range of technical and economic hurdles.
New Allegro 16.5 Technology
The latest Allegro technology will be available through flexible on-demand product configurations that offer cost-efficiency and scalability. Allegro 16.5 spans silicon, SoC, and system-level development and offers PCB designers benefits such as:
- Higher functional density with a constraint-driven flow for embedded components
- Faster timing closure with new PCB interconnect design planning technology
- Fewer physical prototype iterations with concurrent team design authoring
- More efficient low-power design with integrated power delivery network analysis
- A compliant and faster implementation path with package/board-aware SoC IP
- Smoother collaboration among global teams with new SiP distributed co-design
- Flexibility through “base plus options” configurations
Fixed in Cadence SPB OrCAD 16.5.018
DATE: 03-16-2012 HOTFIX VERSION: 018
758924 PDN_ANALYSIS PCB_STATICIRDROP IRDrop via current report with flag for over current
903166 PSPICE FRONTENDPLUGIN Pspice > View netlist not working if .NET is assiciated with Capture
947680 PSPICE FRONTENDPLUGIN Out file is not displayed with view output file option in Win 7
951483 CAPTURE GEN_BOM SYLK File format is not valid in Excel
954330 CAPTURE GEN_BOM Corrupt BOM for attached design. How can we correct it ?
964000 CAPTURE NETLIST_OTHER User Defined Footprint getting replaced by value in Other netlist
968261 CAPTURE NETGROUPS Refdes Control required with Netgroup blocks
968345 CAPTURE NETGROUPS Cannot tick in the Place Netgroup window
974894 CAPTURE DATABASE Capture crashes when updating part from database
977355 ALLEGRO_EDITOR DATABASE Presence of fillets causing no such child error during add connect.
978007 ALLEGRO_EDITOR PCAD_IN PCAD Translation failure
978382 CAPTURE SCHEMATICS Placing testpoint symbol causes extra junction
978522 SIG_INTEGRITY LICENSING Q- Is there a way to set via model option in Orcad PCB Designer Professional license?
979041 SIG_INTEGRITY LIBRARY Contents of model_pcbsi.ndx were constantly accumulated when doing the distribution on each time
979594 CONSTRAINT_MGR CONCEPT_HDL Extra and incorrect information dumped in the alias conflicts reported generated from DE HD-CM Audit
981621 ALLEGRO_EDITOR DRC_CONSTR Updating DRC fails to set Shape Out of Date after changing NetClass membership that affects spacing
983608 F2B BOM Generating all variant BOMs changes selected variant
983629 SIG_EXPLORER EXPORT No exported cross section file created in directory with spaces
984218 CONCEPT_HDL INFRA Uprev from 162 > 165 causes certain ECSets to be in an illegal conflict state which is false
984578 F2B DDBPI PDV and con2con crash on part having illegal data into ptf view
984768 APD SHAPE Dynamic shape finishing with strange void.
985346 SIP_LAYOUT IMPORT_DATA import netlist-in-wizard fails and crashes
985451 APD DIE_GENERATOR die text in results in Invalid object type passed to GetPadstackLayer
986268 ALLEGRO_EDITOR GRAPHICS Copy & Move graphics issue with OpenGL
986552 ALLEGRO_EDITOR EDIT_ETCH The Cline is not avoided the “Route Keepout” by hug in 165. but it does in 16.3
986704 ALLEGRO_EDITOR EDIT_ETCH PCB Editor crashes during add connect
986895 ALLEGRO_EDITOR NC Any layer back drill issues
987309 SIP_LAYOUT COMPONENT_COMPAR Component Compare with DIA file and Net Assignment fails on co-design die with net assignment done by scm
987339 CONCEPT_HDL INFRA replace component inconsistent in .dcf file
987455 ALLEGRO_EDITOR DRC_CONSTR Allegro wrongly reporting Mechanical Pin Antipad to Pin Spacing drc
987669 ALLEGRO_EDITOR DRC_CONSTR multi-thread update DRC causes the application to crash
987843 SPIF OTHER Fanout vias on BOTTOM Layer are shown on TOP Layer in Allegro after routing and importing a session file from SPECCTRA.
988001 CONCEPT_HDL CONSTRAINT_MGR Cant assign Xnet to Electrical class at all and CM crashes if Ecset is assigned to xnet
988133 SIG_INTEGRITY OTHER Extra pin pairs are created in Prop Delay worksheet when ECSet is assigned to diff pair
988609 SIP_LAYOUT SYMB_EDIT_APPMOD When using the Symbol Applicatoin mode to edit a BGA the pin pitch settings are incorrect.
989078 ALLEGRO_EDITOR OTHER Export IDF’s total thickness is not correct
Name: Cadence SPB OrCAD
Version: 16.5.018 (Allegro SPB) 32bit Hotfix
Creator: http://www.cadence.com
Interface: english
OS: Windows XP / Vista / Seven
Platform: Cadence SPB/OrCAD 16.50.000 – 16.50.017
软件Cadence Allegro SPB 16.5使用的补丁:Hotfix_SPB16.50.018_wint_1of1.exe
下载地址如下:
http://115.com/file/e7noq3cd
如有什么不妥的,或者需要上传附件,请指示!
发表于 2012-4-22 18:17:28 | 显示全部楼层
该网盘所文件没有分享,需要输入提取码?谢谢!
发表于 2012-4-23 17:25:19 | 显示全部楼层
提取码是多少?
发表于 2012-4-24 10:24:42 | 显示全部楼层
请楼主提供提取码,谢谢!
 楼主| 发表于 2012-4-25 23:57:14 | 显示全部楼层
不好意思,这次可以了,刚刚学使用115网盘,原来是我没有将其共享出来!对不起各位!
这是提取码的图片
这是提取码的图片
发表于 2012-5-8 10:51:41 | 显示全部楼层
打完补丁可以破解码
发表于 2012-5-15 13:59:21 | 显示全部楼层
发表于 2012-5-28 12:18:20 | 显示全部楼层
谢谢楼主!!!!
 楼主| 发表于 2012-6-5 14:39:38 | 显示全部楼层
这个是需要全新安装以后,接着打上补丁,然后进行CRACK!
发表于 2012-7-4 11:04:24 | 显示全部楼层
谢谢楼主!!!
GMT+8, 2025-12-23 14:02 , Processed in 0.026072 second(s), 7 queries , Gzip On, Redis On.
