查看: 14239|回复: 29
Autodesk AutoCAD 2013 (Crack Only)
发表于 2012-4-9 17:04:38 | 显示全部楼层 |阅读模式
1.Install Autodesk Autocad 2013
2.Use as Serial 666-69696969, 667-98989898, 400-45454545 066-66666666 ..
  or anything matching those templates
3.Use as Product Key 001E1
4.Finish the installation & restart Autodesk Product
5.Before clicking on Activate
  You have 2 options :
   - a) Disable Your network Card, pull the network cable out or block with firewall
     (this is just to disable online serial check)
OR
   - b) Click on Activate and it will tell you that your serial is wrong, simply click
     on close and click on activate again.
Choose option a or b.
6. Select I have an activation code from Autodesk
7.Once at the activation screen:
  start XFORCE Keygen 32bits version or 64bits version
8.Click on Mem Patch (you should see successfully patched)
9.Copy the request code into the keygen and press generate
10.Now copy the activation code back to the activation screen and click Next
  You have a fully registered autodesk product
NB: Make sure you are running the Keygen as administrator and with UAC off on Windows7
    And use the keygen for the right Product
AutoCAD_2013_Crack.rar (3.56 MB , 下载次数: 337 )
发表于 2012-4-9 18:30:01 | 显示全部楼层
这个放在这里合适吗?
还有,Autocad每年都有新版本吧!
 楼主| 发表于 2012-4-9 22:57:33 | 显示全部楼层
不合適的話麻煩請版主幫忙移文...
发表于 2012-8-16 08:57:24 | 显示全部楼层
谢谢mm分享啦,正好要用13画图O(∩_∩)O~
发表于 2012-8-16 10:46:44 | 显示全部楼层
中文版的?
发表于 2012-12-20 10:19:06 | 显示全部楼层
2013都出来了?
发表于 2013-1-2 01:31:48 | 显示全部楼层
真是太快了!
发表于 2013-6-25 14:07:14 | 显示全部楼层
发表于 2013-7-14 11:16:33 | 显示全部楼层
貌似没有看到安装文件
发表于 2013-7-28 17:20:40 | 显示全部楼层
支持啊 ···
GMT+8, 2025-12-29 13:06 , Processed in 0.022525 second(s), 7 queries , Gzip On, Redis On.
