查看: 48912|回复: 30
[求助] 关于LVS中遇到missing injected Instances的问题
发表于 2012-4-6 01:56:51 | 显示全部楼层 |阅读模式
遇到的奇怪的事情,画好的版图分别assura和calibre跑LVS,assura可以通过,并且后仿成功,但是用calibre的LVS就过不了,主要的提示就是missing injected Instances,搜了好久找不到产生这个的原因.版图的连线和器件都能确保正确,毕竟assura后仿结果也比较符合..请问有谁遇到过这种情况..?该如何解决?谢谢.....LVS的结果如下
  1.                   ##################################################
  2.                   ##                                              ##
  3.                   ##         C A L I B R E    S Y S T E M         ##
  4.                   ##                                              ##
  5.                   ##             L V S   R E P O R T              ##
  6.                   ##                                              ##
  7.                   ##################################################
  8. REPORT FILE NAME:         Mirror.lvs.report
  9. LAYOUT NAME:              /Mirror.sp ('Mirror')
  10. SOURCE NAME:              /Mirror.src.net ('Mirror')
  11. RULE FILE:                /_calibre.lvs_
  12. CREATION TIME:            Fri Apr  6 01:47:33 2012
  13. CURRENT DIRECTORY:        /
  14. USER NAME:                XXX
  15. CALIBRE VERSION:          v2008.1_20.15    Tue Mar 4 19:02:13 PST 2008
  16.                                OVERALL COMPARISON RESULTS
  17.                   #   #         #####################
  18.                    # #          #                   #
  19.                     #           #     INCORRECT     #
  20.                    # #          #                   #
  21.                   #   #         #####################
  22.   Error:    Different numbers of nets.
  23.   Error:    Different numbers of instances.
  24.   Error:    Connectivity errors.
  25.   Error:    Property errors.
  26.   Warning:  Ambiguity points were found and resolved arbitrarily.
  27. **************************************************************************************************************
  28.                                       CELL  SUMMARY
  29. **************************************************************************************************************
  30.   Result         Layout                        Source
  31.   -----------    -----------                   --------------
  32.   INCORRECT      Mirror                        Mirror
  33. **************************************************************************************************************
  34.                                       LVS PARAMETERS
  35. **************************************************************************************************************
  36. o LVS Setup:
  37.    // LVS COMPONENT TYPE PROPERTY
  38.    // LVS COMPONENT SUBTYPE PROPERTY
  39.    // LVS PIN NAME PROPERTY
  40.    LVS POWER NAME                         "AVDDBG" "AVDDR" "AVDWELL" "VDWELL" "VD33APST" "VDD5V" "TAVD33" "VD33PST" "AVDD" "TAVDD"
  41.                                           "TAVD33PST" "TAVDDPST" "AVD33B" "VDD" "AVD33G" "DVDD" "AVDDG" "AVDDB" "VDDG" "VDDPST"
  42.                                           "VD33REF" "VD33" "AVD33R" "VDDSA"
  43.    LVS GROUND NAME                        "VSSPST" "AVS33R" "AVSSUB" "VSSREF" "VSSAPST" "VS33APST" "DVSS" "AVS33G" "AVSSBG" "TAVSS"
  44.                                           "AVS33B" "AVSSB" "GND" "VSSG" "VSSUB" "VSS" "AVSS" "TAVSSPST" "AGND" "AVSSR" "AVSSG"
  45.    LVS CELL SUPPLY                        NO
  46.    LVS RECOGNIZE GATES                    ALL
  47.    LVS IGNORE PORTS                       NO
  48.    LVS CHECK PORT NAMES                   NO
  49.    LVS IGNORE TRIVIAL NAMED PORTS         NO
  50.    LVS BUILTIN DEVICE PIN SWAP            YES
  51.    LVS ALL CAPACITOR PINS SWAPPABLE       YES
  52.    LVS DISCARD PINS BY DEVICE             NO
  53.    LVS SOFT SUBSTRATE PINS                NO
  54.    LVS INJECT LOGIC                       YES
  55.    LVS EXPAND UNBALANCED CELLS            YES
  56.    LVS EXPAND SEED PROMOTIONS             NO
  57.    LVS PRESERVE PARAMETERIZED CELLS       NO
  58.    LVS GLOBALS ARE PORTS                  YES
  59.    LVS REVERSE WL                         NO
  60.    LVS SPICE PREFER PINS                  YES
  61.    LVS SPICE SLASH IS SPACE               YES
  62.    LVS SPICE ALLOW FLOATING PINS          YES
  63.    // LVS SPICE ALLOW INLINE PARAMETERS
  64.    LVS SPICE ALLOW UNQUOTED STRINGS       NO
  65.    LVS SPICE CONDITIONAL LDD              NO
  66.    LVS SPICE CULL PRIMITIVE SUBCIRCUITS   NO
  67.    LVS SPICE IMPLIED MOS AREA             NO
  68.    // LVS SPICE MULTIPLIER NAME
  69.    LVS SPICE OVERRIDE GLOBALS             NO
  70.    LVS SPICE REDEFINE PARAM               NO
  71.    LVS SPICE REPLICATE DEVICES            NO
  72.    LVS SPICE STRICT WL                    NO
  73.    // LVS SPICE OPTION
  74.    LVS STRICT SUBTYPES                    NO
  75.    LAYOUT CASE                            NO
  76.    SOURCE CASE                            NO
  77.    LVS COMPARE CASE                       NO
  78.    LVS DOWNCASE DEVICE                    NO
  79.    LVS REPORT MAXIMUM                     50
  80.    LVS PROPERTY RESOLUTION MAXIMUM        65536
  81.    // LVS SIGNATURE MAXIMUM
  82.    LVS FILTER UNUSED OPTION               AB RC RE RG
  83.    // LVS REPORT OPTION
  84.    LVS REPORT UNITS                       YES
  85.    // LVS NON USER NAME PORT
  86.    // LVS NON USER NAME NET
  87.    // LVS NON USER NAME INSTANCE
  88.    // Reduction
  89.    LVS REDUCE SERIES MOS                  NO
  90.    LVS REDUCE PARALLEL MOS                YES
  91.    LVS REDUCE SEMI SERIES MOS             NO
  92.    LVS REDUCE SPLIT GATES                 YES
  93.    LVS REDUCE PARALLEL BIPOLAR            YES
  94.    LVS REDUCE SERIES CAPACITORS           YES
  95.    LVS REDUCE PARALLEL CAPACITORS         YES
  96.    LVS REDUCE SERIES RESISTORS            YES
  97.    LVS REDUCE PARALLEL RESISTORS          YES
  98.    LVS REDUCE PARALLEL DIODES             YES
  99.    LVS REDUCTION PRIORITY                 PARALLEL
  100.    // Trace Property
  101.    TRACE PROPERTY  mn(nd)  l l 2
  102.    TRACE PROPERTY  mn(nd)  w w 2
  103.    TRACE PROPERTY  m(y1)  l l 2
  104.    TRACE PROPERTY  m(y1)  w w 2
  105.    TRACE PROPERTY  mn(n)  l l 2
  106.    TRACE PROPERTY  mn(n)  w w 2
  107.    TRACE PROPERTY  m(y2)  l l 2
  108.    TRACE PROPERTY  m(y2)  w w 2
  109.    TRACE PROPERTY  mp(pd)  l l 2
  110.    TRACE PROPERTY  mp(pd)  w w 2
  111.    TRACE PROPERTY  mp(p)  l l 2
  112.    TRACE PROPERTY  mp(p)  w w 2
  113.    TRACE PROPERTY  q(pnp10)  a a 0
  114.    TRACE PROPERTY  q(pnp5)  a a 0
  115.    TRACE PROPERTY  d(dp)  a a 1
  116.    TRACE PROPERTY  d(dw)  a a 1
  117.    TRACE PROPERTY  d(dn)  a a 1
  118.    TRACE PROPERTY  r(m3)  r r 0
  119.    TRACE PROPERTY  r(ni)  r r 0
  120.    TRACE PROPERTY  r(m1)  r r 0
  121.    TRACE PROPERTY  r(pi)  r r 0
  122.    TRACE PROPERTY  r(pr)  r r 0
  123.    TRACE PROPERTY  r(m2)  r r 0
  124.    TRACE PROPERTY  r(m4)  r r 0
  125.    TRACE PROPERTY  r(pl)  r r 0
  126.    TRACE PROPERTY  r(wo)  r r 0
  127.    TRACE PROPERTY  c(pc)  c c 1
  128.                    CELL COMPARISON RESULTS ( TOP LEVEL )
  129.                   #   #         #####################
  130.                    # #          #                   #
  131.                     #           #     INCORRECT     #
  132.                    # #          #                   #
  133.                   #   #         #####################
  134.   Error:    Different numbers of nets (see below).
  135.   Error:    Different numbers of instances (see below).
  136.   Error:    Connectivity errors.
  137.   Error:    Property errors.
  138.   Warning:  Ambiguity points were found and resolved arbitrarily.
  139. LAYOUT CELL NAME:         Mirror
  140. SOURCE CELL NAME:         Mirror
  141. --------------------------------------------------------------------------------------------------------------
  142. INITIAL NUMBERS OF OBJECTS
  143. --------------------------
  144.                 Layout    Source         Component Type
  145.                 ------    ------         --------------
  146. Ports:              9         9
  147. Nets:              92        81    *
  148. Instances:        114        45    *    MN (4 pins)
  149.                     97        46    *    MP (4 pins)
  150.                     16         8    *    R (2 pins)
  151.                 ------    ------
  152. Total Inst:       227        99
  153. NUMBERS OF OBJECTS AFTER TRANSFORMATION
  154. ---------------------------------------
  155.                 Layout    Source         Component Type
  156.                 ------    ------         --------------
  157. Ports:              9         9
  158. Nets:              34        58    *
  159. Instances:         16        21    *    MN (4 pins)
  160.                     20        16    *    MP (4 pins)
  161.                      1         1         R (2 pins)
  162.                      9         4    *    _invv (4 pins)
  163.                     10        10         _smn2v (4 pins)
  164.                      8        13    *    _sup2v (4 pins)
  165.                 ------    ------
  166. Total Inst:        64        65
  167.        * = Number of objects in layout different from number in source.
  168. **************************************************************************************************************
  169.                                  INCORRECT OBJECTS
  170. **************************************************************************************************************
  171. LEGEND:
  172. -------
  173.   ne  = Naming Error (same layout name found in source
  174.         circuit, but object was matched otherwise).
  175. **************************************************************************************************************
  176.                                    INCORRECT NETS
  177. DISC#  LAYOUT NAME                                               SOURCE NAME
  178. **************************************************************************************************************
  179.   1    Net AVDD                                                  AVDD
  180.        --------------------------                                --------------------------
  181.
  182.        (_smn2v):in2                                              ** missing connection **
  183.          X78/M0(215.275,133.200):g
  184.
  185.
  186.        (_smn2v):in1                                              ** missing connection **
  187.          X79/M0(215.275,135.900):g
  188.
  189.
  190.        (_invv):in                                                ** missing connection **
  191.          X80/M0(213.200,72.175):g
  192.          X80/M3(195.800,72.175):g
  193.
  194.
  195.        (_invv):in                                                ** missing connection **
  196.          X84/M0(213.200,177.325):g
  197.          X84/M3(195.800,177.325):g
  198.
  199.
  200.        (_invv):in                                                ** missing connection **
  201.          X83/M0(213.200,156.225):g
  202.          X83/M3(195.800,156.225):g
  203.
  204.
  205.        (_invv):in                                                ** missing connection **
  206.          X81/M0(213.200,93.275):g
  207.          X81/M3(195.800,93.275):g
  208.
  209.
  210.        X84/M2(195.800,175.825):g                                 ** missing connection **
  211.        X83/M2(195.800,154.725):g                                 ** missing connection **
  212.        X81/M2(195.800,91.775):g                                  ** missing connection **
  213.        X80/M2(195.800,70.675):g                                  ** missing connection **
  214.        M58(196.050,133.200):g                                    ** missing connection **
  215.
  216. --------------------------------------------------------------------------------------------------------------
  217.   2    Net VDD                                                   VDD
  218.        --------------------------                                --------------------------
  219.
  220.        (_invv):sup1                                              ** missing connection **
  221.          X80/M3(195.800,72.175):b
  222.          X80/M3(195.800,72.175):s
  223.
  224.
  225.        (_invv):sup1                                              ** missing connection **
  226.          X84/M3(195.800,177.325):b
  227.          X84/M3(195.800,177.325):s
  228.
  229.
  230.        (_invv):sup1                                              ** missing connection **
  231.          X83/M3(195.800,156.225):b
  232.          X83/M3(195.800,156.225):s
  233.
  234.
  235.        (_invv):sup1                                              ** missing connection **
  236.          X82/M3(195.800,114.375):b
  237.          X82/M3(195.800,114.375):s
  238.
  239.
  240.        (_invv):sup1                                              ** missing connection **
  241.          X81/M3(195.800,93.275):b
  242.          X81/M3(195.800,93.275):s
  243.
  244.
  245.        X84/M2(195.800,175.825):b                                 ** missing connection **
  246.        X84/M2(195.800,175.825):d                                 ** missing connection **
  247.        X84/M1(195.800,174.325):b                                 ** missing connection **
  248.        X83/M2(195.800,154.725):b                                 ** missing connection **
  249.        X83/M2(195.800,154.725):d                                 ** missing connection **
  250.        X83/M1(195.800,153.225):b                                 ** missing connection **
  251.        X82/M2(195.800,112.875):b                                 ** missing connection **
  252.        X82/M2(195.800,112.875):d                                 ** missing connection **
  253.        X82/M1(195.800,111.375):b                                 ** missing connection **
  254.        X81/M2(195.800,91.775):b                                  ** missing connection **
  255.        X81/M2(195.800,91.775):d                                  ** missing connection **
  256.        X81/M1(195.800,90.275):b                                  ** missing connection **
  257.        X80/M2(195.800,70.675):b                                  ** missing connection **
  258.        X80/M2(195.800,70.675):d                                  ** missing connection **
  259.        X80/M1(195.800,69.175):b                                  ** missing connection **
  260.        M58(196.050,133.200):b                                    ** missing connection **
  261.        M58(196.050,133.200):s                                    ** missing connection **
  262.
  263. --------------------------------------------------------------------------------------------------------------
  264.   3    Net GND                                                   GND
  265.        --------------------------                                --------------------------
  266.
  267.        (_smn2v):out2                                             ** missing connection **
  268.          X78/M0(215.275,133.200):b
  269.          X79/M0(215.275,135.900):b
  270.          X79/M0(215.275,135.900):s
  271.
  272.
  273.        (_invv):sup2                                              ** missing connection **
  274.          X80/M0(213.200,72.175):b
  275.          X80/M0(213.200,72.175):s
  276.
  277.
  278.        (_invv):sup2                                              ** missing connection **
  279.          X84/M0(213.200,177.325):b
  280.          X84/M0(213.200,177.325):s
  281.
  282.
  283.        (_invv):sup2                                              ** missing connection **
  284.          X83/M0(213.200,156.225):b
  285.          X83/M0(213.200,156.225):s
  286.
  287.
  288.        (_invv):sup2                                              ** missing connection **
  289.          X82/M0(213.200,114.375):b
  290.          X82/M0(213.200,114.375):s
  291.
  292.
  293.        (_invv):sup2                                              ** missing connection **
  294.          X81/M0(213.200,93.275):b
  295.          X81/M0(213.200,93.275):s
  296.
  297. --------------------------------------------------------------------------------------------------------------
  298.   4    Net 15                                                    net17
  299.        --------------------------                                --------------------------
  300.
  301.        X84/M1(195.800,174.325):s                                 ** missing connection **
  302.        X83/M1(195.800,153.225):s                                 ** missing connection **
  303.        X82/M1(195.800,111.375):s                                 ** missing connection **
  304.        X81/M1(195.800,90.275):s                                  ** missing connection **
  305.        X80/M1(195.800,69.175):s                                  ** missing connection **
  306.
  307. --------------------------------------------------------------------------------------------------------------
  308.   5    Net 22                                                    ** no similar net **
  309. --------------------------------------------------------------------------------------------------------------
  310.   6    Net 17                                                    ** no similar net **
  311. --------------------------------------------------------------------------------------------------------------
  312.   7    Net 18                                                    ** no similar net **
  313. --------------------------------------------------------------------------------------------------------------
  314.   8    Net 21                                                    ** no similar net **
  315. --------------------------------------------------------------------------------------------------------------
  316.   9    Net 19                                                    ** no similar net **
  317. --------------------------------------------------------------------------------------------------------------
  318. 10    Net 20                                                    ** no similar net **
  319. --------------------------------------------------------------------------------------------------------------
  320. 11    Net X80/6                                                 ** no similar net **
  321. --------------------------------------------------------------------------------------------------------------
  322. 12    Net X81/6                                                 ** no similar net **
  323. --------------------------------------------------------------------------------------------------------------
  324. 13    Net X82/6                                                 ** no similar net **
  325. --------------------------------------------------------------------------------------------------------------
  326. 14    Net X83/6                                                 ** no similar net **
  327. --------------------------------------------------------------------------------------------------------------
  328. 15    Net X84/6                                                 ** no similar net **
  329. --------------------------------------------------------------------------------------------------------------
  330. 16    ** no similar net **                                      XI6/A1
  331. --------------------------------------------------------------------------------------------------------------
  332. 17    ** no similar net **                                      XI6/A2
  333. --------------------------------------------------------------------------------------------------------------
  334. 18    ** no similar net **                                      XI6/B
  335. --------------------------------------------------------------------------------------------------------------
  336. 19    ** no similar net **                                      XI6/GND
  337. --------------------------------------------------------------------------------------------------------------
  338. 20    ** no similar net **                                      XI6/VDD
  339. --------------------------------------------------------------------------------------------------------------
  340. 21    ** no similar net **                                      XI5/AVDD
  341. --------------------------------------------------------------------------------------------------------------
  342. 22    ** no similar net **                                      XI5/GND
  343. --------------------------------------------------------------------------------------------------------------
  344. 23    ** no similar net **                                      XI5/VDD
  345. --------------------------------------------------------------------------------------------------------------
  346. 24    ** no similar net **                                      XI5/Y
  347. --------------------------------------------------------------------------------------------------------------
  348. 25    ** no similar net **                                      XI41/AVDD
  349. --------------------------------------------------------------------------------------------------------------
  350. 26    ** no similar net **                                      XI41/GND
  351. --------------------------------------------------------------------------------------------------------------
  352. 27    ** no similar net **                                      XI41/VDD
  353. --------------------------------------------------------------------------------------------------------------
  354. 28    ** no similar net **                                      XI41/Y
  355. --------------------------------------------------------------------------------------------------------------
  356. 29    ** no similar net **                                      XI15/AVDD
  357. --------------------------------------------------------------------------------------------------------------
  358. 30    ** no similar net **                                      XI15/GND
  359. --------------------------------------------------------------------------------------------------------------
  360. 31    ** no similar net **                                      XI15/VDD
  361. --------------------------------------------------------------------------------------------------------------
  362. 32    ** no similar net **                                      XI15/Y
  363. --------------------------------------------------------------------------------------------------------------
  364. 33    ** no similar net **                                      XI42/AVDD
  365. --------------------------------------------------------------------------------------------------------------
  366. 34    ** no similar net **                                      XI42/GND
  367. --------------------------------------------------------------------------------------------------------------
  368. 35    ** no similar net **                                      XI42/VDD
  369. --------------------------------------------------------------------------------------------------------------
  370. 36    ** no similar net **                                      XI42/Y
  371. --------------------------------------------------------------------------------------------------------------
  372. 37    ** no similar net **                                      XI40/AVDD
  373. --------------------------------------------------------------------------------------------------------------
  374. 38    ** no similar net **                                      XI40/GND
  375. --------------------------------------------------------------------------------------------------------------
  376. 39    ** no similar net **                                      XI40/VDD
  377. --------------------------------------------------------------------------------------------------------------
  378. 40    ** no similar net **                                      XI40/Y
  379. --------------------------------------------------------------------------------------------------------------
  380. 41    ** no similar net **                                      net94
  381. --------------------------------------------------------------------------------------------------------------
  382. 42    ** no similar net **                                      net114
  383. --------------------------------------------------------------------------------------------------------------
  384. 43    ** no similar net **                                      net118
  385. --------------------------------------------------------------------------------------------------------------
  386. 44    ** no similar net **                                      net146
  387. --------------------------------------------------------------------------------------------------------------
  388. 45    ** no similar net **                                      net150
  389. --------------------------------------------------------------------------------------------------------------
  390. 46    ** no similar net **                                      XI5/net14
  391. --------------------------------------------------------------------------------------------------------------
  392. 47    ** no similar net **                                      XI41/net14
  393. --------------------------------------------------------------------------------------------------------------
  394. 48    ** no similar net **                                      XI15/net14
  395. --------------------------------------------------------------------------------------------------------------
  396. 49    ** no similar net **                                      XI42/net14
  397. --------------------------------------------------------------------------------------------------------------
  398. 50    ** no similar net **                                      XI40/net14
  399. **************************************************************************************************************
  400.                                  INCORRECT INSTANCES
  401. DISC#  LAYOUT NAME                                               SOURCE NAME
  402. **************************************************************************************************************
  403. 51    (_invv)                                                   ** missing injected instance **
  404.        Devices:
  405.          X81/M3(195.800,93.275)  MP(P)
  406.          X81/M0(213.200,93.275)  MN(N)
  407. --------------------------------------------------------------------------------------------------------------
  408. 52    (_invv)                                                   ** missing injected instance **
  409.        Devices:
  410.          X82/M3(195.800,114.375)  MP(P)
  411.          X82/M0(213.200,114.375)  MN(N)
  412. --------------------------------------------------------------------------------------------------------------
  413. 53    (_invv)                                                   ** missing injected instance **
  414.        Devices:
  415.          X83/M3(195.800,156.225)  MP(P)
  416.          X83/M0(213.200,156.225)  MN(N)
  417. --------------------------------------------------------------------------------------------------------------
  418. 54    (_invv)                                                   ** missing injected instance **
  419.        Devices:
  420.          X84/M3(195.800,177.325)  MP(P)
  421.          X84/M0(213.200,177.325)  MN(N)
  422. --------------------------------------------------------------------------------------------------------------
  423. 55    (_invv)                                                   ** missing injected instance **
  424.        Devices:
  425.          X80/M3(195.800,72.175)  MP(P)
  426.          X80/M0(213.200,72.175)  MN(N)
  427. --------------------------------------------------------------------------------------------------------------
  428. 56    ** missing instance **                                    XI5/MM3  MN(N)
  429. --------------------------------------------------------------------------------------------------------------
  430. 57    ** missing instance **                                    XI41/MM3  MN(N)
  431. --------------------------------------------------------------------------------------------------------------
  432. 58    ** missing instance **                                    XI15/MM3  MN(N)
  433. --------------------------------------------------------------------------------------------------------------
  434. 59    ** missing instance **                                    XI42/MM3  MN(N)
  435. --------------------------------------------------------------------------------------------------------------
  436. 60    ** missing instance **                                    XI40/MM3  MN(N)
  437. **************************************************************************************************************
  438.                                       PROPERTY ERRORS
  439. DISC#  LAYOUT                                                    SOURCE                      ERROR
  440. **************************************************************************************************************
  441. 61    X120/M0(126.800,168.900)  MP(P)                           MM38  MP(P)
  442.        w: 24 u                                                   w: 144 u                    83.3%
  443. 62    X129/M0(150.800,167.900)  MP(P)                           MM30  MP(P)
  444.        w: 48 u                                                   w: 96 u                       50%
  445. 63    X127/M0(126.800,149.100)  MP(P)                           MM33  MP(P)
  446.        w: 96 u                                                   w: 24 u                      300%
  447. 64    X117/M0(126.800,112.100)  MP(P)                           MM37  MP(P)
  448.        w: 144 u                                                  w: 48 u                      200%
  449. **************************************************************************************************************
  450.                                INFORMATION AND WARNINGS
  451. **************************************************************************************************************
  452.                   Matched    Matched    Unmatched    Unmatched    Component
  453.                    Layout     Source       Layout       Source    Type
  454.                   -------    -------    ---------    ---------    ---------
  455.    Ports:               9          9            0            0
  456.    Nets:               23         23           11           35
  457.    Instances:          16         16            0            5    MN(N)
  458.                         9          9           11            7    MP(P)
  459.                         1          1            0            0    R(WO)
  460.                         4          4            5            0    _invv
  461.                         9          9            1            1    _smn2v
  462.                         8          8            0            5    _sup2v
  463.                   -------    -------    ---------    ---------
  464.    Total Inst:         47         47           17           18
  465. o Statistics:
  466.    156 layout mos transistors were reduced to 35.  32 connecting nets were deleted.
  467.      57 mos transistors were deleted by parallel reduction.
  468.      64 mos transistors and 32 connecting nets were deleted by split-gate reduction.
  469.    16 series/parallel layout resistors were reduced to 1.  8 connecting nets were deleted.
  470.    8 parallel source resistors were reduced to 1.
  471.    1 net was matched arbitrarily.
  472. o Initial Correspondence Points:
  473.    Ports:        AVDD VDD GND IREF IBIAS2 VB2 IBIAS1 VB3 VB1
  474. o Ambiguity Resolution Points:
  475.       (Each one of the following objects belongs to a group of indistinguishable objects.
  476.        The listed objects were matched arbitrarily by the Ambiguity Resolution feature of LVS.
  477.        Arbitrary matching may be prevented by assigning names to these objects or to adjacent nets).
  478.        Layout                                                    Source
  479.        ------                                                    ------
  480.                                      Nets
  481.                                      ----
  482.        6                                                         net0384
  483. **************************************************************************************************************
  484.                                   UNMATCHED OBJECTS
  485.        LAYOUT                                                    SOURCE
  486. **************************************************************************************************************
  487.        M58(196.050,133.200)  MP(P)                               ** unmatched instance **
  488.        X80/M1(195.800,69.175)  MP(P)                             ** unmatched instance **
  489.        X80/M2(195.800,70.675)  MP(P)                             ** unmatched instance **
  490.        X81/M1(195.800,90.275)  MP(P)                             ** unmatched instance **
  491.        X81/M2(195.800,91.775)  MP(P)                             ** unmatched instance **
  492.        X82/M1(195.800,111.375)  MP(P)                            ** unmatched instance **
  493.        X82/M2(195.800,112.875)  MP(P)                            ** unmatched instance **
  494.        X83/M1(195.800,153.225)  MP(P)                            ** unmatched instance **
  495.        X83/M2(195.800,154.725)  MP(P)                            ** unmatched instance **
  496.        X84/M1(195.800,174.325)  MP(P)                            ** unmatched instance **
  497.        X84/M2(195.800,175.825)  MP(P)                            ** unmatched instance **
  498. --------------------------------------------------------------------------------------------------------------
  499.        (_smn2v)                                                  ** unmatched injected instance **
  500.        Devices:
  501.          X79/M0(215.275,135.900)  MN(N)
  502.          X78/M0(215.275,133.200)  MN(N)
  503. --------------------------------------------------------------------------------------------------------------
  504.        ** unmatched instance **                                  XI6/MM5  MP(P)
  505.        ** unmatched instance **                                  XI6/MM1  MP(P)
  506.        ** unmatched instance **                                  XI5/MM0  MP(P)
  507.        ** unmatched instance **                                  XI41/MM0  MP(P)
  508.        ** unmatched instance **                                  XI15/MM0  MP(P)
  509.        ** unmatched instance **                                  XI42/MM0  MP(P)
  510.        ** unmatched instance **                                  XI40/MM0  MP(P)
  511. --------------------------------------------------------------------------------------------------------------
  512.        ** unmatched injected instance **                         (_sup2v)
  513.        Devices:
  514.        XI5/MM2  MP(P)
  515.        XI5/MM4  MP(P)
  516. --------------------------------------------------------------------------------------------------------------
  517.        ** unmatched injected instance **                         (_sup2v)
  518.        Devices:
  519.        XI41/MM2  MP(P)
  520.        XI41/MM4  MP(P)
  521. --------------------------------------------------------------------------------------------------------------
  522.        ** unmatched injected instance **                         (_sup2v)
  523.        Devices:
  524.        XI15/MM2  MP(P)
  525.        XI15/MM4  MP(P)
  526. --------------------------------------------------------------------------------------------------------------
  527.        ** unmatched injected instance **                         (_sup2v)
  528.        Devices:
  529.        XI42/MM2  MP(P)
  530.        XI42/MM4  MP(P)
  531. --------------------------------------------------------------------------------------------------------------
  532.        ** unmatched injected instance **                         (_sup2v)
  533.        Devices:
  534.        XI40/MM2  MP(P)
  535.        XI40/MM4  MP(P)
  536. --------------------------------------------------------------------------------------------------------------
  537.        ** unmatched injected instance **                         (_smn2v)
  538.        Devices:
  539.        XI6/MM6  MN(N)
  540.        XI6/MM7  MN(N)
  541. **************************************************************************************************************
  542.                                          SUMMARY
  543. **************************************************************************************************************
  544. Total CPU Time:      0 sec
  545. Total Elapsed Time:  0 sec
  546.
    复制代码
发表于 2012-4-6 08:27:22 | 显示全部楼层
检查电源和地 版图中是否标对
发表于 2012-4-6 09:30:57 | 显示全部楼层
有可能要宣告 GLOBAL
 楼主| 发表于 2012-4-6 10:31:14 | 显示全部楼层
回复 2# shack
   电源和地我重新确认了一下..能和原理图对应起来..
 楼主| 发表于 2012-4-6 10:32:27 | 显示全部楼层
回复 3# motofatfat
   能否讲得更详细一点?之前画版图没有考虑这个问题...也能通过LVS...这次比较奇怪...
发表于 2012-4-6 17:52:10 | 显示全部楼层
NMOS 少 PMOS多 查一下 N_WELL 是不是
圍到 NMOS 那邊了
改成 LVS REPORT OPTION A B C D S V
報告會詳細些
 楼主| 发表于 2012-4-6 22:22:35 | 显示全部楼层
回复 6# motofatfat
   我仔细看了一下,这个错误有可能是Calibre把我其中的一个器件识别成inv或者别的了,然后没法匹配上,这个我要怎么处理呢?
发表于 2012-4-7 08:31:53 | 显示全部楼层
CDL中把电源和地 声明为全局信号
 楼主| 发表于 2012-4-7 11:16:16 | 显示全部楼层
回复 8# shack 我加上全局变量声明后错误少了一些,但是还是有连线和missing Instance之类的错误,我又检查了一遍,它提示的这些地方都没有连错...请问这个该怎么办?谢谢...
LVS如下
  1.                                OVERALL COMPARISON RESULTS
  2.                   #   #         #####################                     # #          #                   #                      #           #     INCORRECT     #                     # #          #                   #                    #   #         #####################
  3.   Error:    Different numbers of nets.  Error:    Different numbers of instances.  Error:    Connectivity errors.  Error:    Property errors.  Warning:  Ambiguity points were found and resolved arbitrarily.
  4. **************************************************************************************************************                                      CELL  SUMMARY**************************************************************************************************************
  5.   Result         Layout                        Source  -----------    -----------                   --------------  INCORRECT      Mirror                        Mirror
  6. **************************************************************************************************************                                      LVS PARAMETERS**************************************************************************************************************
  7. o LVS Setup:
  8.    // LVS COMPONENT TYPE PROPERTY   // LVS COMPONENT SUBTYPE PROPERTY   // LVS PIN NAME PROPERTY   LVS POWER NAME                         "VDD"   LVS GROUND NAME                        "GND"   LVS CELL SUPPLY                        NO   LVS RECOGNIZE GATES                    ALL   LVS IGNORE PORTS                       NO   LVS CHECK PORT NAMES                   NO   LVS IGNORE TRIVIAL NAMED PORTS         NO   LVS BUILTIN DEVICE PIN SWAP            YES   LVS ALL CAPACITOR PINS SWAPPABLE       YES   LVS DISCARD PINS BY DEVICE             NO   LVS SOFT SUBSTRATE PINS                NO   LVS INJECT LOGIC                       YES   LVS EXPAND UNBALANCED CELLS            YES   LVS EXPAND SEED PROMOTIONS             NO   LVS PRESERVE PARAMETERIZED CELLS       NO   LVS GLOBALS ARE PORTS                  YES   LVS REVERSE WL                         NO   LVS SPICE PREFER PINS                  YES   LVS SPICE SLASH IS SPACE               YES   LVS SPICE ALLOW FLOATING PINS          YES   // LVS SPICE ALLOW INLINE PARAMETERS        LVS SPICE ALLOW UNQUOTED STRINGS       NO   LVS SPICE CONDITIONAL LDD              NO   LVS SPICE CULL PRIMITIVE SUBCIRCUITS   NO   LVS SPICE IMPLIED MOS AREA             NO   // LVS SPICE MULTIPLIER NAME   LVS SPICE OVERRIDE GLOBALS             NO   LVS SPICE REDEFINE PARAM               NO   LVS SPICE REPLICATE DEVICES            NO   LVS SPICE STRICT WL                    NO   // LVS SPICE OPTION   LVS STRICT SUBTYPES                    NO   LAYOUT CASE                            NO   SOURCE CASE                            NO   LVS COMPARE CASE                       NO   LVS DOWNCASE DEVICE                    NO   LVS REPORT MAXIMUM                     50   LVS PROPERTY RESOLUTION MAXIMUM        65536   // LVS SIGNATURE MAXIMUM   LVS FILTER UNUSED OPTION               AB RC RE RG   LVS REPORT OPTION                      A B C D S V   LVS REPORT UNITS                       YES   // LVS NON USER NAME PORT   // LVS NON USER NAME NET   // LVS NON USER NAME INSTANCE
  9.    // Reduction
  10.    LVS REDUCE SERIES MOS                  NO   LVS REDUCE PARALLEL MOS                YES   LVS REDUCE SEMI SERIES MOS             NO   LVS REDUCE SPLIT GATES                 YES   LVS REDUCE PARALLEL BIPOLAR            YES   LVS REDUCE SERIES CAPACITORS           YES   LVS REDUCE PARALLEL CAPACITORS         YES   LVS REDUCE SERIES RESISTORS            YES   LVS REDUCE PARALLEL RESISTORS          YES   LVS REDUCE PARALLEL DIODES             YES   LVS REDUCTION PRIORITY                 PARALLEL
  11.    // Trace Property
  12.    TRACE PROPERTY  mn(nd)  l l 2   TRACE PROPERTY  mn(nd)  w w 2   TRACE PROPERTY  m(y1)  l l 2   TRACE PROPERTY  m(y1)  w w 2   TRACE PROPERTY  mn(n)  l l 2   TRACE PROPERTY  mn(n)  w w 2   TRACE PROPERTY  m(y2)  l l 2   TRACE PROPERTY  m(y2)  w w 2   TRACE PROPERTY  mp(pd)  l l 2   TRACE PROPERTY  mp(pd)  w w 2   TRACE PROPERTY  mp(p)  l l 2   TRACE PROPERTY  mp(p)  w w 2   TRACE PROPERTY  q(pnp10)  a a 0   TRACE PROPERTY  q(pnp5)  a a 0   TRACE PROPERTY  d(dp)  a a 1   TRACE PROPERTY  d(dw)  a a 1   TRACE PROPERTY  d(dn)  a a 1   TRACE PROPERTY  r(m3)  r r 0   TRACE PROPERTY  r(ni)  r r 0   TRACE PROPERTY  r(m1)  r r 0   TRACE PROPERTY  r(pi)  r r 0   TRACE PROPERTY  r(pr)  r r 0   TRACE PROPERTY  r(m2)  r r 0   TRACE PROPERTY  r(m4)  r r 0   TRACE PROPERTY  r(pl)  r r 0   TRACE PROPERTY  r(wo)  r r 0   TRACE PROPERTY  c(pc)  c c 1
  13.                    CELL COMPARISON RESULTS ( TOP LEVEL )
  14.                   #   #         #####################                     # #          #                   #                      #           #     INCORRECT     #                     # #          #                   #                    #   #         #####################
  15.   Error:    Different numbers of nets (see below).  Error:    Different numbers of instances (see below).  Error:    Connectivity errors.  Error:    Property errors.  Warning:  Ambiguity points were found and resolved arbitrarily.
  16. LAYOUT CELL NAME:         MirrorSOURCE CELL NAME:         Mirror
  18. INITIAL NUMBERS OF OBJECTS--------------------------
  19.                 Layout    Source         Component Type                ------    ------         -------------- Ports:              9        11    *
  20. Nets:              92        64    *
  21. Instances:        114        45    *    MN (4 pins)                    97        46    *    MP (4 pins)                    16         8    *    R (2 pins)                ------    ------ Total Inst:       227        99
  22. NUMBERS OF OBJECTS AFTER TRANSFORMATION---------------------------------------
  23.                 Layout    Source         Component Type                ------    ------         -------------- Ports:              9         9
  24. Nets:              34        39    *
  25. Instances:         16        16         MN (4 pins)                    20        10    *    MP (4 pins)                     1         1         R (2 pins)                     9         9         _invv (4 pins)                    10        10         _smn2v (4 pins)                     8        13    *    _smp2v (4 pins)                ------    ------ Total Inst:        64        59
  26.        * = Number of objects in layout different from number in source.
  27. **************************************************************************************************************                                 INCORRECT OBJECTS**************************************************************************************************************
  28. LEGEND:-------
  29.   ne  = Naming Error (same layout name found in source        circuit, but object was matched otherwise).
  30. **************************************************************************************************************                                   INCORRECT NETS
  31. DISC#  LAYOUT NAME                                               SOURCE NAME**************************************************************************************************************
  32.   1    Net AVDD                                                  AVDD       --------------------------                                --------------------------
  33.        --- Incorrect Devices On This Net ---
  34.        X84/M2(195.800,175.825)  MP(P)                            ** missing instance **         g: AVDD                                                   ** AVDD **         s: 20                                                     ** no similar net **         d: VDD                                                    ** VDD **         b: VDD                                                    ** VDD **
  35.        X83/M2(195.800,154.725)  MP(P)                            ** missing instance **         g: AVDD                                                   ** AVDD **         s: 19                                                     ** no similar net **         d: VDD                                                    ** VDD **         b: VDD                                                    ** VDD **
  36.        X81/M2(195.800,91.775)  MP(P)                             ** missing instance **         g: AVDD                                                   ** AVDD **         s: 18                                                     ** no similar net **         d: VDD                                                    ** VDD **         b: VDD                                                    ** VDD **
  37.        X80/M2(195.800,70.675)  MP(P)                             ** missing instance **         g: AVDD                                                   ** AVDD **         s: 17                                                     ** no similar net **         d: VDD                                                    ** VDD **         b: VDD                                                    ** VDD **
  38.        ** missing injected instance **                           (_smp2v)         ** AVDD **                                                in1: AVDD         ** X82/6 **                                               in2: XI5/net14         ** no similar net **                                      out1: XI5/A         ** VDD **                                                 out2: VDD
  39.        Devices:        XI5/MM2  MP(P)        XI5/MM4  MP(P)
  40.        ** missing injected instance **                           (_smp2v)         ** AVDD **                                                in1: AVDD         ** X80/6 **                                               in2: XI41/net14         ** no similar net **                                      out1: XI41/A         ** VDD **                                                 out2: VDD
  41.        Devices:        XI41/MM2  MP(P)        XI41/MM4  MP(P)
  42.        ** missing injected instance **                           (_smp2v)         ** AVDD **                                                in1: AVDD         ** X84/6 **                                               in2: XI15/net14         ** no similar net **                                      out1: XI15/A         ** VDD **                                                 out2: VDD
  43.        Devices:        XI15/MM2  MP(P)        XI15/MM4  MP(P)
  44.        ** missing injected instance **                           (_smp2v)         ** AVDD **                                                in1: AVDD         ** X83/6 **                                               in2: XI42/net14         ** no similar net **                                      out1: XI42/A         ** VDD **                                                 out2: VDD
  45.        Devices:        XI42/MM2  MP(P)        XI42/MM4  MP(P)
  46.        ** missing injected instance **                           (_smp2v)         ** AVDD **                                                in1: AVDD         ** X81/6 **                                               in2: XI40/net14         ** no similar net **                                      out1: XI40/A         ** VDD **                                                 out2: VDD
  47.        Devices:        XI40/MM2  MP(P)        XI40/MM4  MP(P)
  48.        (_invv)                                                   (_invv)         out: X82/6                                                out: XI5/net14         sup1: VDD                                                 sup1: VDD         sup2: GND                                                 sup2: GND         in: 22                                                    ** net0212 **         ** AVDD **                                                in: AVDD
  49.        Devices:          X82/M3(195.800,114.375)  MP(P)                            XI5/MM0  MP(P)          X82/M0(213.200,114.375)  MN(N)                            XI5/MM3  MN(N)
  50.        --- Correct Devices On This Net ---
  51.        (cell ports)                                              (cell ports)         VDD: VDD                                                  VDD: VDD         GND: GND                                                  GND: GND         AVDD: AVDD                                                AVDD: AVDD         IREF: IREF                                                IREF: IREF         IBIAS2: IBIAS2                                            IBIAS2: IBIAS2         VB2: VB2                                                  VB2: VB2         IBIAS1: IBIAS1                                            IBIAS1: IBIAS1         VB3: VB3                                                  VB3: VB3         VB1: VB1                                                  VB1: VB1
  52.        (_smn2v)                                                  (_smn2v)         in1: AVDD                                                 in1: AVDD         in2: AVDD                                                 in2: AVDD         out1: 22                                                  out1: net0212         out2: GND                                                 out2: GND
  53.        Devices:          X78/M0(215.275,133.200)  MN(N)                            XI6/MM6  MN(N)          X79/M0(215.275,135.900)  MN(N)                            XI6/MM7  MN(N)
  54.        (_invv)                                                   (_invv)         in: AVDD                                                  in: AVDD         out: X80/6                                                out: XI41/net14         sup1: VDD                                                 sup1: VDD         sup2: GND                                                 sup2: GND
  55.        Devices:          X80/M3(195.800,72.175)  MP(P)                             XI41/MM0  MP(P)          X80/M0(213.200,72.175)  MN(N)                             XI41/MM3  MN(N)
  56.        (_invv)                                                   (_invv)         in: AVDD                                                  in: AVDD         out: X184/6                                               out: XI3/net14         sup1: VDD                                                 sup1: VDD         sup2: GND                                                 sup2: GND
  57.        Devices:          X184/M3(31.100,124.000)  MP(P)                            XI3/MM2  MP(P)          X184/M2(11.525,124.750)  MN(N)                            XI3/MM3  MN(N)
  58.        (_invv)                                                   (_invv)         in: AVDD                                                  in: AVDD         out: X183/6                                               out: XI0/net14         sup1: VDD                                                 sup1: VDD         sup2: GND                                                 sup2: GND
  59.        Devices:          X183/M3(31.100,102.500)  MP(P)                            XI0/MM2  MP(P)          X183/M2(11.525,103.250)  MN(N)                            XI0/MM3  MN(N)
  60.        (_invv)                                                   (_invv)         in: AVDD                                                  in: AVDD         out: X182/6                                               out: XI2/net14         sup1: VDD                                                 sup1: VDD         sup2: GND                                                 sup2: GND
  61.        Devices:          X182/M3(31.100,81.000)  MP(P)                             XI2/MM2  MP(P)          X182/M2(11.525,81.750)  MN(N)                             XI2/MM3  MN(N)
  62.        (_invv)                                                   (_invv)         in: AVDD                                                  in: AVDD         out: X84/6                                                out: XI15/net14         sup1: VDD                                                 sup1: VDD         sup2: GND                                                 sup2: GND
  63.        Devices:          X84/M3(195.800,177.325)  MP(P)                            XI15/MM0  MP(P)          X84/M0(213.200,177.325)  MN(N)                            XI15/MM3  MN(N)
  64.        (_invv)                                                   (_invv)         in: AVDD                                                  in: AVDD         out: X83/6                                                out: XI42/net14         sup1: VDD                                                 sup1: VDD         sup2: GND                                                 sup2: GND
  65.        Devices:          X83/M3(195.800,156.225)  MP(P)                            XI42/MM0  MP(P)          X83/M0(213.200,156.225)  MN(N)                            XI42/MM3  MN(N)
  66.        (_invv)                                                   (_invv)         in: AVDD                                                  in: AVDD         out: X81/6                                                out: XI40/net14         sup1: VDD                                                 sup1: VDD         sup2: GND                                                 sup2: GND
  67.        Devices:          X81/M3(195.800,93.275)  MP(P)                             XI40/MM0  MP(P)          X81/M0(213.200,93.275)  MN(N)                             XI40/MM3  MN(N)
  68.        (_invv)                                                   (_invv)         in: AVDD                                                  in: AVDD         out: X185/6                                               out: XI1/net14         sup1: VDD                                                 sup1: VDD         sup2: GND                                                 sup2: GND
  69.        Devices:          X185/M3(31.100,145.500)  MP(P)                            XI1/MM2  MP(P)          X185/M2(11.525,146.250)  MN(N)                            XI1/MM3  MN(N)
  70.        X185/M1(11.525,144.750)  MN(N)                            XI1/MM0  MN(N)         g: AVDD                                                   g: AVDD         s: 7                                                      d: net0412         d: GND                                                    s: GND         b: GND                                                    b: GND
  71.        X184/M1(11.525,123.250)  MN(N)                            XI3/MM0  MN(N)         g: AVDD                                                   g: AVDD         s: 6                                                      d: net0384         d: GND                                                    s: GND         b: GND                                                    b: GND
  72.        X183/M1(11.525,101.750)  MN(N)                            XI0/MM0  MN(N)         g: AVDD                                                   g: AVDD         s: 5                                                      d: net0400         d: GND                                                    s: GND         b: GND                                                    b: GND
  73.        X182/M1(11.525,80.250)  MN(N)                             XI2/MM0  MN(N)         g: AVDD                                                   g: AVDD         s: 4                                                      d: net0416         d: GND                                                    s: GND         b: GND                                                    b: GND
  74.        X92/R0(163.275,51.500)  R(WO)                             RR130  R(WO)         pos: GND                                                  neg: GND         neg: AVDD                                                 pos: AVDD
  75.        M58(196.050,133.200)  MP(P)                               XI6/MM5  MP(P)         g: AVDD                                                   g: AVDD         s: VDD                                                    s: VDD         d: 22                                                     d: net0212         b: VDD                                                    b: VDD
  76. --------------------------------------------------------------------------------------------------------------
  77.   2    Net 22                                                    net0212       --------------------------                                --------------------------
  78.        --- Incorrect Devices On This Net ---
  79.        (_invv)                                                   (_invv)         out: X82/6                                                out: XI5/net14         sup1: VDD                                                 sup1: VDD         sup2: GND                                                 sup2: GND         in: 22                                                    ** net0212 **         ** AVDD **                                                in: AVDD
  80.        Devices:          X82/M3(195.800,114.375)  MP(P)                            XI5/MM0  MP(P)          X82/M0(213.200,114.375)  MN(N)                            XI5/MM3  MN(N)
  81.        X82/M2(195.800,112.875)  MP(P)                            ** missing instance **         g: 22                                                     ** net0212 **         s: 21                                                     ** no similar net **         d: VDD                                                    ** VDD **         b: VDD                                                    ** VDD **
  82.        --- Correct Devices On This Net ---
  83.        (_smn2v)                                                  (_smn2v)         in1: AVDD                                                 in1: AVDD         in2: AVDD                                                 in2: AVDD         out1: 22                                                  out1: net0212         out2: GND                                                 out2: GND
  84.        Devices:          X78/M0(215.275,133.200)  MN(N)                            XI6/MM6  MN(N)          X79/M0(215.275,135.900)  MN(N)                            XI6/MM7  MN(N)
  85.        M58(196.050,133.200)  MP(P)                               XI6/MM5  MP(P)         g: AVDD                                                   g: AVDD         s: VDD                                                    s: VDD         d: 22                                                     d: net0212         b: VDD                                                    b: VDD
  86. --------------------------------------------------------------------------------------------------------------
  87.   3    Net 17                                                    ** no similar net **
  88.            --- Devices on layout net 17 ---
  89.        (_smp2v)                                                  (_smp2v)         in2: 8                                                    in2: net0360         out1: IBIAS2                                              out1: IBIAS2         out2: VDD                                                 out2: VDD         in1: 17                                                   ** no similar net **         ** no similar net **                                      in1: net118
  90.        Devices:          X127/M0(126.800,149.100)  MP(P)                           MM33  MP(P)          ** unmatched instance **                                  MM32  MP(P)          X111/M0(126.800,152.050)  MP(P)                           ** unmatched instance **
  91.        X80/M2(195.800,70.675)  MP(P)                             ** missing instance **         g: AVDD                                                   ** AVDD **         s: 17                                                     ** no similar net **         d: VDD                                                    ** VDD **         b: VDD                                                    ** VDD **
  92.        X80/M1(195.800,69.175)  MP(P)                             ** missing instance **         g: X80/6                                                  ** XI41/net14 **         s: 15                                                     ** net17 **         d: 17                                                     ** no similar net **         b: VDD                                                    ** VDD **
  94.   4    Net 18                                                    ** no similar net **
  95.            --- Devices on layout net 18 ---
  96.        (_smp2v)                                                  (_smp2v)         in2: 8                                                    in1: net0360         out1: IBIAS2                                              out1: IBIAS2         out2: VDD                                                 out2: VDD         in1: 18                                                   ** no similar net **         ** no similar net **                                      in2: net146
  97.        Devices:          X129/M0(150.800,167.900)  MP(P)                           MM30  MP(P)          ** unmatched instance **                                  MM31  MP(P)          X112/M0(150.800,164.950)  MP(P)                           ** unmatched instance **
  98.        X81/M2(195.800,91.775)  MP(P)                             ** missing instance **         g: AVDD                                                   ** AVDD **         s: 18                                                     ** no similar net **         d: VDD                                                    ** VDD **         b: VDD                                                    ** VDD **
  99.        X81/M1(195.800,90.275)  MP(P)                             ** missing instance **         g: X81/6                                                  ** XI40/net14 **         s: 15                                                     ** net17 **         d: 18                                                     ** no similar net **         b: VDD                                                    ** VDD **
  100. --------------------------------------------------------------------------------------------------------------
  101.   5    Net 21                                                    ** no similar net **
  102.            --- Devices on layout net 21 ---
  103.        (_smp2v)                                                  (_smp2v)         in2: 8                                                    in2: net0360         out1: IBIAS2                                              out1: IBIAS2         out2: VDD                                                 out2: VDD         in1: 21                                                   ** no similar net **         ** no similar net **                                      in1: net114
  104.        Devices:          X117/M0(126.800,112.100)  MP(P)                           MM37  MP(P)          ** unmatched instance **                                  MM36  MP(P)          X109/M0(126.800,115.050)  MP(P)                           ** unmatched instance **
  105.        X82/M2(195.800,112.875)  MP(P)                            ** missing instance **         g: 22                                                     ** net0212 **         s: 21                                                     ** no similar net **         d: VDD                                                    ** VDD **         b: VDD                                                    ** VDD **
  106.        X82/M1(195.800,111.375)  MP(P)                            ** missing instance **         g: X82/6                                                  ** XI5/net14 **         s: 15                                                     ** net17 **         d: 21                                                     ** no similar net **         b: VDD                                                    ** VDD **
  107. --------------------------------------------------------------------------------------------------------------
  108.   6    Net 19                                                    ** no similar net **
  109.            --- Devices on layout net 19 ---
  110.        (_smp2v)                                                  (_smp2v)         in2: 8                                                    in2: net0360         out1: IBIAS2                                              out1: IBIAS2         out2: VDD                                                 out2: VDD         in1: 19                                                   ** no similar net **         ** no similar net **                                      in1: net150
  111.        Devices:          X120/M0(126.800,168.900)  MP(P)                           MM38  MP(P)          ** unmatched instance **                                  MM39  MP(P)          X113/M0(126.800,171.850)  MP(P)                           ** unmatched instance **
  112.        X83/M2(195.800,154.725)  MP(P)                            ** missing instance **         g: AVDD                                                   ** AVDD **         s: 19                                                     ** no similar net **         d: VDD                                                    ** VDD **         b: VDD                                                    ** VDD **
  113.        X83/M1(195.800,153.225)  MP(P)                            ** missing instance **         g: X83/6                                                  ** XI42/net14 **         s: 15                                                     ** net17 **         d: 19                                                     ** no similar net **         b: VDD                                                    ** VDD **
  114. --------------------------------------------------------------------------------------------------------------
  115.   7    Net 20                                                    ** no similar net **
  116.            --- Devices on layout net 20 ---
  117.        (_smp2v)                                                  (_smp2v)         in1: 8                                                    in2: net0360         out1: IBIAS2                                              out1: IBIAS2         out2: VDD                                                 out2: VDD         in2: 20                                                   ** no similar net **         ** no similar net **                                      in1: net94
  118.        Devices:          X95/M0(150.800,177.800)  MP(P)                            MM34  MP(P)          ** unmatched instance **                                  MM35  MP(P)          X104/M0(150.800,174.850)  MP(P)                           ** unmatched instance **
  119.        X84/M2(195.800,175.825)  MP(P)                            ** missing instance **         g: AVDD                                                   ** AVDD **         s: 20                                                     ** no similar net **         d: VDD                                                    ** VDD **         b: VDD                                                    ** VDD **
  120.        X84/M1(195.800,174.325)  MP(P)                            ** missing instance **         g: X84/6                                                  ** XI15/net14 **         s: 15                                                     ** net17 **         d: 20                                                     ** no similar net **         b: VDD                                                    ** VDD **
  121. --------------------------------------------------------------------------------------------------------------
  122.   8    ** no similar net **                                      XI5/A
  123.            --- Devices on source net XI5/A ---
  124.        ** missing injected instance **                           (_smp2v)         ** AVDD **                                                in1: AVDD         ** X82/6 **                                               in2: XI5/net14         ** no similar net **                                      out1: XI5/A         ** VDD **                                                 out2: VDD
  125.        Devices:        XI5/MM2  MP(P)        XI5/MM4  MP(P)
  126. --------------------------------------------------------------------------------------------------------------
  127.   9    ** no similar net **                                      XI41/A
  128.            --- Devices on source net XI41/A ---
  129.        ** missing injected instance **                           (_smp2v)         ** AVDD **                                                in1: AVDD         ** X80/6 **                                               in2: XI41/net14         ** no similar net **                                      out1: XI41/A         ** VDD **                                                 out2: VDD
  130.        Devices:        XI41/MM2  MP(P)        XI41/MM4  MP(P)
  131. --------------------------------------------------------------------------------------------------------------
  132. 10    ** no similar net **                                      XI15/A
  133.            --- Devices on source net XI15/A ---
  134.        ** missing injected instance **                           (_smp2v)         ** AVDD **                                                in1: AVDD         ** X84/6 **                                               in2: XI15/net14         ** no similar net **                                      out1: XI15/A         ** VDD **                                                 out2: VDD
  135.        Devices:        XI15/MM2  MP(P)        XI15/MM4  MP(P)
  136. --------------------------------------------------------------------------------------------------------------
  137. 11    ** no similar net **                                      XI42/A
  138.            --- Devices on source net XI42/A ---
  139.        ** missing injected instance **                           (_smp2v)         ** AVDD **                                                in1: AVDD         ** X83/6 **                                               in2: XI42/net14         ** no similar net **                                      out1: XI42/A         ** VDD **                                                 out2: VDD
  140.        Devices:        XI42/MM2  MP(P)        XI42/MM4  MP(P)
  142. 12    ** no similar net **                                      XI40/A
  143.            --- Devices on source net XI40/A ---
  144.        ** missing injected instance **                           (_smp2v)         ** AVDD **                                                in1: AVDD         ** X81/6 **                                               in2: XI40/net14         ** no similar net **                                      out1: XI40/A         ** VDD **                                                 out2: VDD
  145.        Devices:        XI40/MM2  MP(P)        XI40/MM4  MP(P)
  146. --------------------------------------------------------------------------------------------------------------
  147. 13    ** no similar net **                                      net94
  148.            --- Devices on source net net94 ---
  149.        (_smp2v)                                                  (_smp2v)         in1: 8                                                    in2: net0360         out1: IBIAS2                                              out1: IBIAS2         out2: VDD                                                 out2: VDD         in2: 20                                                   ** no similar net **         ** no similar net **                                      in1: net94
  150.        Devices:          X95/M0(150.800,177.800)  MP(P)                            MM34  MP(P)          ** unmatched instance **                                  MM35  MP(P)          X104/M0(150.800,174.850)  MP(P)                           ** unmatched instance **
  151. --------------------------------------------------------------------------------------------------------------
  152. 14    ** no similar net **                                      net114
  153.            --- Devices on source net net114 ---
  154.        (_smp2v)                                                  (_smp2v)         in2: 8                                                    in2: net0360         out1: IBIAS2                                              out1: IBIAS2         out2: VDD                                                 out2: VDD         in1: 21                                                   ** no similar net **         ** no similar net **                                      in1: net114
  155.        Devices:          X117/M0(126.800,112.100)  MP(P)                           MM37  MP(P)          ** unmatched instance **                                  MM36  MP(P)          X109/M0(126.800,115.050)  MP(P)                           ** unmatched instance **
  156. --------------------------------------------------------------------------------------------------------------
  157. 15    ** no similar net **                                      net118
  158.            --- Devices on source net net118 ---
  159.        (_smp2v)                                                  (_smp2v)         in2: 8                                                    in2: net0360         out1: IBIAS2                                              out1: IBIAS2         out2: VDD                                                 out2: VDD         in1: 17                                                   ** no similar net **         ** no similar net **                                      in1: net118
  160.        Devices:          X127/M0(126.800,149.100)  MP(P)                           MM33  MP(P)          ** unmatched instance **                                  MM32  MP(P)          X111/M0(126.800,152.050)  MP(P)                           ** unmatched instance **
  161. --------------------------------------------------------------------------------------------------------------
  162. 16    ** no similar net **                                      net146
  163.            --- Devices on source net net146 ---
  164.        (_smp2v)                                                  (_smp2v)         in2: 8                                                    in1: net0360         out1: IBIAS2                                              out1: IBIAS2         out2: VDD                                                 out2: VDD         in1: 18                                                   ** no similar net **         ** no similar net **                                      in2: net146
  165.        Devices:          X129/M0(150.800,167.900)  MP(P)                           MM30  MP(P)          ** unmatched instance **                                  MM31  MP(P)          X112/M0(150.800,164.950)  MP(P)                           ** unmatched instance **
  166. --------------------------------------------------------------------------------------------------------------
  167. 17    ** no similar net **                                      net150
  168.            --- Devices on source net net150 ---
  169.        (_smp2v)                                                  (_smp2v)         in2: 8                                                    in2: net0360         out1: IBIAS2                                              out1: IBIAS2         out2: VDD                                                 out2: VDD         in1: 19                                                   ** no similar net **         ** no similar net **                                      in1: net150
  170.        Devices:          X120/M0(126.800,168.900)  MP(P)                           MM38  MP(P)          ** unmatched instance **                                  MM39  MP(P)          X113/M0(126.800,171.850)  MP(P)                           ** unmatched instance **
  171. **************************************************************************************************************                                 INCORRECT INSTANCES
  172. DISC#  LAYOUT NAME                                               SOURCE NAME**************************************************************************************************************
  173. 18    X80/M1(195.800,69.175)  MP(P)                             ** missing instance **         g: X80/6                                                  ** XI41/net14 **         s: 15                                                     ** net17 **         d: 17                                                     ** no similar net **         b: VDD                                                    ** VDD **
  174. --------------------------------------------------------------------------------------------------------------
  175. 19    X80/M2(195.800,70.675)  MP(P)                             ** missing instance **         g: AVDD                                                   ** AVDD **         s: 17                                                     ** no similar net **         d: VDD                                                    ** VDD **         b: VDD                                                    ** VDD **
  176. --------------------------------------------------------------------------------------------------------------
  177. 20    X81/M1(195.800,90.275)  MP(P)                             ** missing instance **         g: X81/6                                                  ** XI40/net14 **         s: 15                                                     ** net17 **         d: 18                                                     ** no similar net **         b: VDD                                                    ** VDD **
  178. --------------------------------------------------------------------------------------------------------------
  179. 21    X81/M2(195.800,91.775)  MP(P)                             ** missing instance **         g: AVDD                                                   ** AVDD **         s: 18                                                     ** no similar net **         d: VDD                                                    ** VDD **         b: VDD                                                    ** VDD **
  180. --------------------------------------------------------------------------------------------------------------
  181. 22    X82/M1(195.800,111.375)  MP(P)                            ** missing instance **         g: X82/6                                                  ** XI5/net14 **         s: 15                                                     ** net17 **         d: 21                                                     ** no similar net **         b: VDD                                                    ** VDD **
  182. --------------------------------------------------------------------------------------------------------------
  183. 23    X82/M2(195.800,112.875)  MP(P)                            ** missing instance **         g: 22                                                     ** net0212 **         s: 21                                                     ** no similar net **         d: VDD                                                    ** VDD **         b: VDD                                                    ** VDD **
  184. --------------------------------------------------------------------------------------------------------------
  185. 24    X83/M1(195.800,153.225)  MP(P)                            ** missing instance **         g: X83/6                                                  ** XI42/net14 **         s: 15                                                     ** net17 **         d: 19                                                     ** no similar net **         b: VDD                                                    ** VDD **
  186. --------------------------------------------------------------------------------------------------------------
  187. 25    X83/M2(195.800,154.725)  MP(P)                            ** missing instance **         g: AVDD                                                   ** AVDD **         s: 19                                                     ** no similar net **         d: VDD                                                    ** VDD **         b: VDD                                                    ** VDD **
  188. --------------------------------------------------------------------------------------------------------------
  189. 26    X84/M1(195.800,174.325)  MP(P)                            ** missing instance **         g: X84/6                                                  ** XI15/net14 **         s: 15                                                     ** net17 **         d: 20                                                     ** no similar net **         b: VDD                                                    ** VDD **
  190. --------------------------------------------------------------------------------------------------------------
  191. 27    X84/M2(195.800,175.825)  MP(P)                            ** missing instance **         g: AVDD                                                   ** AVDD **         s: 20                                                     ** no similar net **         d: VDD                                                    ** VDD **         b: VDD                                                    ** VDD **
  192. --------------------------------------------------------------------------------------------------------------
  193. 28    ** missing injected instance **                           (_smp2v)         ** AVDD **                                                in1: AVDD         ** X81/6 **                                               in2: XI40/net14         ** no similar net **                                      out1: XI40/A         ** VDD **                                                 out2: VDD
  194.        Devices:        XI40/MM2  MP(P)        XI40/MM4  MP(P)
  195. --------------------------------------------------------------------------------------------------------------
  196. 29    ** missing injected instance **                           (_smp2v)         ** AVDD **                                                in1: AVDD         ** X83/6 **                                               in2: XI42/net14         ** no similar net **                                      out1: XI42/A         ** VDD **                                                 out2: VDD
  197.        Devices:        XI42/MM2  MP(P)        XI42/MM4  MP(P)
  198. --------------------------------------------------------------------------------------------------------------
  199. 30    ** missing injected instance **                           (_smp2v)         ** AVDD **                                                in1: AVDD         ** X84/6 **                                               in2: XI15/net14         ** no similar net **                                      out1: XI15/A         ** VDD **                                                 out2: VDD
  200.        Devices:        XI15/MM2  MP(P)        XI15/MM4  MP(P)
  201. --------------------------------------------------------------------------------------------------------------
  202. 31    ** missing injected instance **                           (_smp2v)         ** AVDD **                                                in1: AVDD         ** X80/6 **                                               in2: XI41/net14         ** no similar net **                                      out1: XI41/A         ** VDD **                                                 out2: VDD
  203.        Devices:        XI41/MM2  MP(P)        XI41/MM4  MP(P)
  204. --------------------------------------------------------------------------------------------------------------
  205. 32    ** missing injected instance **                           (_smp2v)         ** AVDD **                                                in1: AVDD         ** X82/6 **                                               in2: XI5/net14         ** no similar net **                                      out1: XI5/A         ** VDD **                                                 out2: VDD
  206.        Devices:        XI5/MM2  MP(P)        XI5/MM4  MP(P)
  207. **************************************************************************************************************                                      PROPERTY ERRORS
  208. DISC#  LAYOUT                                                    SOURCE                      ERROR**************************************************************************************************************
  209. 33    X120/M0(126.800,168.900)  MP(P)                           MM38  MP(P)       w: 24 u                                                   w: 144 u                    83.3%
  210. 34    X129/M0(150.800,167.900)  MP(P)                           MM30  MP(P)       w: 48 u                                                   w: 96 u                       50%
  211. 35    X127/M0(126.800,149.100)  MP(P)                           MM33  MP(P)       w: 96 u                                                   w: 24 u                      300%
  212. 36    X117/M0(126.800,112.100)  MP(P)                           MM37  MP(P)       w: 144 u                                                  w: 48 u                      200%
  213. **************************************************************************************************************                               INFORMATION AND WARNINGS**************************************************************************************************************
  214.                   Matched    Matched    Unmatched    Unmatched    Component                   Layout     Source       Layout       Source    Type                  -------    -------    ---------    ---------    ---------   Ports:               9          9            0            0
  215.    Nets:               29         29            5           10
  216.    Instances:          16         16            0            0    MN(N)                       10         10           10            0    MP(P)                        1          1            0            0    R(WO)                        9          9            0            0    _invv                       10         10            0            0    _smn2v                        8          8            0            5    _smp2v                  -------    -------    ---------    ---------   Total Inst:         54         54           10            5
  217. o Statistics:
  218.    2 passthrough source nets were deleted.
  219.    156 layout mos transistors were reduced to 35.  32 connecting nets were deleted.     57 mos transistors were deleted by parallel reduction.     64 mos transistors and 32 connecting nets were deleted by split-gate reduction.   2 source mos transistors were reduced to 1.     1 mos transistor was deleted by parallel reduction.
  220.    16 series/parallel layout resistors were reduced to 1.  8 connecting nets were deleted.   8 parallel source resistors were reduced to 1.
  221.    1 net was matched arbitrarily.
  222. o Initial Correspondence Points:
  223.    Ports:        VDD GND AVDD IREF IBIAS2 VB2 IBIAS1 VB3 VB1
  224. o Ambiguity Resolution Points:
  225.       (Each one of the following objects belongs to a group of indistinguishable objects.       The listed objects were matched arbitrarily by the Ambiguity Resolution feature of LVS.       Arbitrary matching may be prevented by assigning names to these objects or to adjacent nets).
  226.        Layout                                                    Source       ------                                                    ------
  227.                                      Nets                                     ----
  228.        6                                                         net0384
  229. **************************************************************************************************************                             DETAILED INSTANCE CONNECTIONS
  230.        LAYOUT NAME                                               SOURCE NAME**************************************************************************************************************
  231.           (This section contains detailed information about connections of           matched instances that are involved in net discrepancies).
  232. --------------------------------------------------------------------------------------------------------------
  233.        (_invv)                                                   (_invv)         out: X82/6                                                out: XI5/net14         sup1: VDD                                                 sup1: VDD         sup2: GND                                                 sup2: GND         in: 22                                                    ** net0212 **         ** AVDD **                                                in: AVDD
  234.        Devices:          X82/M3(195.800,114.375)  MP(P)                            XI5/MM0  MP(P)          X82/M0(213.200,114.375)  MN(N)                            XI5/MM3  MN(N)
  235.
    复制代码
发表于 2012-4-7 13:22:17 | 显示全部楼层
把GDS和CDL rul发给我,我给你试试
GMT+8, 2025-9-15 05:22 , Processed in 0.019952 second(s), 3 queries , Gzip On, Redis On.
