查看: 4826|回复: 8
[求助] 求助Encounter Warning:failed to add edge...
发表于 2012-4-3 22:55:41 | 显示全部楼层 |阅读模式
当Encounter读入def时,即defin OOXX.def(来源于前段综合dft输出scan chain文件write_scan_def),出现 Warning:failed to add edge...,经过分析netlist,def文件应该没问题,请教layout高手们,如何进一步排查?
发表于 2012-4-3 23:33:24 | 显示全部楼层
贴全Warning
 楼主| 发表于 2012-4-5 10:19:50 | 显示全部楼层
Creating constraint file...
**WARN: (SOCSYT-3034):        commitConfig can only be run once per session.
This command is skipped since it's already run by user or by loadConfig command implicitly.
<CMD> defIn data/scan/p111_main.def
Reading DEF file 'data/scan/p111_main.def', current time is Sun Apr  1 16:24:16 2012 ...
--- CASESENSITIVE ON
--- DIVIDERCHAR '/'
*warn: failed to add edge 'AAA_top/AAF_ddc_top/u_adc_nco/cos_sign_reg''Q' - 'AAA_top/AAF_ddc_top/u_adc_nco/mix_acc_reg_0_''SI' to scan chain 1!
*warn: failed to add edge 'AAA_top/AAF_ddc_top/u_adc_nco/U362''Y' - 'AAA_top/AAF_ddc_top/u_adc_nco/mix_acc_reg_1_''SI' to scan chain 1!
*warn: failed to add edge 'AAA_top/AAF_ddc_top/u_adc_nco/U362''Y' - 'AAA_top/AAF_ddc_top/u_adc_nco/mix_acc_reg_2_''SI' to scan chain 1!
*warn: failed to add edge 'AAA_top/AAF_ddc_top/u_adc_nco/U362''Y' - 'AAA_top/AAF_ddc_top/u_adc_nco/mix_acc_reg_3_''SI' to scan chain 1!
*warn: failed to add edge 'AAA_top/AAF_ddc_top/u_adc_nco/U362''Y' - 'AAA_top/AAF_ddc_top/u_adc_nco/mix_acc_reg_4_''SI' to scan chain 1!
*warn: failed to add edge 'AAA_top/AAF_ddc_top/u_adc_nco/U362''Y' - 'AAA_top/AAF_ddc_top/u_adc_nco/mix_acc_reg_5_''SI' to scan chain 1!
*warn: failed to add edge 'AAA_top/AAF_ddc_top/u_adc_nco/U362''Y' - 'AAA_top/AAF_ddc_top/u_adc_nco/mix_acc_reg_9_''SI' to scan chain 1!
*warn: failed to add edge 'AAA_top/AAF_ddc_top/u_adc_nco/U362''Y' - 'AAA_top/AAF_ddc_top/u_adc_nco/mix_acc_reg_10_''SI' to scan chain 1!
*warn: failed to add edge 'AAA_top/AAF_ddc_top/u_adc_nco/U362''Y' - 'AAA_top/AAF_ddc_top/u_adc_nco/mix_acc_reg_11_''SI' to scan chain 1!
*warn: failed to add edge 'AAA_top/AAF_ddc_top/u_adc_nco/U362''Y' - 'AAA_top/AAF_ddc_top/u_adc_nco/mix_acc_reg_12_''SI' to scan chain 1!
*warn: failed to add edge 'AAA_top/AAF_ddc_top/u_adc_nco/mix_sign_reg''Q' - 'AAA_top/AAF_ddc_top/u_adc_nco/phase_acc_reg_0_''SI' to scan chain 1!
*warn: failed to add edge 'AAA_top/AAF_ddc_top/u_adc_nco/mix_sign_reg''Q' - 'AAA_top/AAF_ddc_top/u_adc_nco/phase_acc_reg_11_''SI' to scan chain 1!
*warn: failed to add edge 'AAA_top/AAF_ddc_top/u_adc_nco/mix_sign_reg''Q' - 'AAA_top/AAF_ddc_top/u_adc_nco/phase_acc_reg_14_''SI' to scan chain 1!
*warn: failed to add edge 'AAA_top/AAF_ddc_top/u_adc_nco/mix_sign_reg''Q' - 'AAA_top/AAF_ddc_top/u_adc_nco/phase_acc_reg_15_''SI' to scan chain 1!
*warn: failed to add edge 'AAA_top/AAF_ddc_top/u_adc_nco/mix_sign_reg''Q' - 'AAA_top/AAF_ddc_top/u_adc_nco/phase_acc_reg_19_''SI' to scan chain 1!
VERSION 5.5 ;
NAMESCASESENSITIVE ON ;
DIVIDERCHAR "/" ;
BUSBITCHARS "[]" ;
DESIGN ddc_top ;
SCANCHAINS 8 ;
- 1
+ START AAA_top/U489 Y
+ FLOATING AAA_top/AAF_ddc_top/u_adc_nco/cos_sign_reg ( IN SI ) ( OUT Q )
           AAA_top/AAF_ddc_top/u_adc_nco/mix_acc_reg_1_ ( IN SI ) ( OUT Q )
+ ORDERED AAA_top/AAF_ddc_top/u_adc_nco/mix_acc_reg_0_ ( IN SI ) ( OUT Q )
                AAA_top/AAF_ddc_top/u_adc_nco/U362               ( IN A ) ( OUT Y )
 楼主| 发表于 2012-4-5 10:23:09 | 显示全部楼层
我觉得是encounter在trace scan chain cell时,没有找到下一个SI,看到一个test_si能够找到第一个DFF SI端。但是,经过ORDERED CELL时,没法trace下一个DFF的SI端,所以这个ORDERED CELL会search不同的DFF的SI端。check Encounter log。另外,def文件,在楼上的下半部分。谢谢
发表于 2012-4-6 11:31:24 | 显示全部楼层
从warning看,是因为scan chain里面混有其他逻辑单元
而且感觉你的scan def与warning不符
 楼主| 发表于 2012-4-6 22:29:27 | 显示全部楼层
陈老师:确实scan chain混有其他逻辑,就是ORDERED的部分,即SO没有直接连SI,而是通过buff连。
warning和def确实一一对应的。
不过,你在哪里看出来,不是scan def和warning不符?可能是我贴的不全,太长了,我截取部分。
发表于 2012-7-31 21:30:45 | 显示全部楼层
回复 1# akencgs
    请问你的这个问题解决了吗?我也遇到这个问题,求指教呀~
发表于 2015-4-16 08:53:54 | 显示全部楼层
谁能解释下DEF文件?用通俗易懂的方式
发表于 2015-4-16 10:45:13 | 显示全部楼层
感觉网表和scandef没有对应起来,
建议再把dc输出的网表和scandef 再读入一次看看,或者看看scan哪里出了问题没
GMT+8, 2025-11-14 12:24 , Processed in 1.521002 second(s), 6 queries , Gzip On, Redis On.
