查看: 20612|回复: 24
[求助] uvm+questasim
发表于 2012-3-23 23:53:11 | 显示全部楼层 |阅读模式
昨天在用questasim10.0a编译dpi库的时候,报了下面的错误:
# In file included from D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_dpi.cc:29:
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_regex.cc:29:22: error: vpi_user.h: No such file or directory
# In file included from D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_dpi.cc:30:
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_hdl.c:23:22: error: veriuser.h: No such file or directory
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_hdl.c:24:19: error: svdpi.h: No such file or directory
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_regex.cc: In member function 'int uvm_re_cache::re_match(const char*, const char*)':
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_regex.cc:124: error: 'PLI_BYTE8' was not declared in this scope
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_regex.cc:124: error: expected primary-expression before ')' token
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_regex.cc:124: error: 'vpi_printf' was not declared in this scope
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_hdl.c: In function 'int uvm_hdl_max_width()':
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_hdl.c:49: error: 'vpiHandle' was not declared in this scope
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_hdl.c:49: error: expected `;' before 'ms'
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_hdl.c:50: error: 's_vpi_value' was not declared in this scope
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_hdl.c:50: error: expected `;' before 'value_s'
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_dpi.cc:34: error: expected `}' at end of input
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_dpi.cc: At global scope:
我使用的命令是D:/questa_sim_10.0a/gcc-4.2.1-mingw32vc9/bin/g++.exe \
        -g \
        -DQUESTA \
        -W \
        -shared \
        -Bsymbolic \
        -ID:/questa_sim_10.0a/gcc-4.2.1-mingw32vc9/include \
        D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_dpi.cc \
        -o D:/questa_sim_10.0a/verilog_src/uvm-1.0/lib/uvm_dpi.dll \
  D:/questa_sim_10.0a/win32/mtipli.dll -lregex
因为我没有uvm_dpi.dll文件,所以就用上面的命令先生成,不知道怎么会报出这种错误,我用的库是从官网上下啊,怎么会没有需要的文件?
求大神指点!
发表于 2012-4-13 22:36:37 | 显示全部楼层
楼主,你有questasim-gcc-4.2.1-mingw32vc9.zip?可否共享一下。
谢先!
tmsg2004@hotmail.com
发表于 2012-4-22 14:51:21 | 显示全部楼层
回复 2# bennymao
   你下modelsim 的官方FTP里可以找到
发表于 2012-6-26 10:29:09 | 显示全部楼层
学习了 。
发表于 2012-6-29 16:50:07 | 显示全部楼层
了解了!
发表于 2012-7-4 21:57:51 | 显示全部楼层
ddddddd 收藏了
发表于 2012-11-3 16:39:42 | 显示全部楼层
BUCUO  BUCUO  BUCUO
发表于 2013-11-7 15:16:50 | 显示全部楼层
应该是你的"include"文件夹位置没有对.
发表于 2013-11-12 15:06:34 | 显示全部楼层
回复 1# zhaowf
你好 请问楼主最后怎么解决的啊?
发表于 2013-11-25 19:53:58 | 显示全部楼层
靠回帖赚积分真累啊
GMT+8, 2025-12-19 14:04 , Processed in 0.028773 second(s), 7 queries , Gzip On, Redis On.
