楼主: oscillator_cn1
[求助] 问一个systemverilog 字符串串联的问题
发表于 2012-3-19 23:48:22 | 显示全部楼层
直接用{}不行?
发表于 2012-11-28 10:45:19 | 显示全部楼层
学习了
谢谢
发表于 2013-5-29 15:55:30 | 显示全部楼层
谢谢将你的解决方法写出来!
Useful SystemVerilog System Tasks
Task NameDescription
$sscanf(str,format,args);
$sscanf 将字符串按照某个模板格式进行扫描,其字符串格式和C语言中的printf()函数类似
$sformat(str,format,args);
$sformat是$sscanf的反函数。将字符串按照给定的格式填入相应的参数args中
$display(format,args);
$display就是Verilog的printf语句,在stdout上显示格式化的字符串
$sformatf(format,args);
$sformatf任务和$sformat相似,除了其返回字符串结果。字符串作为$sformatf的返回值,而不是像$sformt一样放在第一个参数上。
发表于 2013-12-4 15:59:32 | 显示全部楼层
同志们得勤翻看sv LRM, 里面有明确的内容解决这问题:
In Verilog, the ‘define macro text can include a backslash ( \ ) at the end of a line to show continuation on
the next line.
In SystemVerilog, the macro text can also include `", `\`" and ``.
An `" overrides the usual lexical meaning of ", and indicates that the expansion should include an actual quo-
tation mark. This allows string literals to be constructed from macro arguments.
A `\`" indicates that the expansion should include the escape sequence \", e.g.
`define msg(x,y) `"x: `\`"y`\`"`"
This expands:
$display(`msg(left side,right side));
to:
$display("left side: \"right side\"");
A `` delimits lexical tokens without introducing white space, allowing identifiers to be constructed from argu-
ments, e.g.
`define foo(f) f``_suffix
This expands:
‘foo(bar)
to:
bar_suffix
发表于 2013-12-5 17:43:13 | 显示全部楼层
$psprintf()可以返回字符串
发表于 2018-8-29 15:27:09 | 显示全部楼层
反正总而言之就是用sformat这个函数是么
GMT+8, 2025-9-18 02:39 , Processed in 0.013186 second(s), 3 queries , Gzip On, Redis On.
