查看: 8801|回复: 28
一篇讲述 Gate Resistor(栅电阻)影响器件性能的论文
发表于 2006-11-23 09:20:06 | 显示全部楼层 |阅读模式
by
Razavi   in 1994 IEEE
Impact of Distributed Gate Resistance on the Performance of MOS Devices94.pdf
366.57 KB, 下载次数: 194 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2006-11-23 09:24:41 | 显示全部楼层
12bit 5M TwoStep CMOS AD Converter(Razavi1992)
A 12-b 5-MSample/s Two-Step CMOS A/D Converter
Behzad Razavi, Member, IEEE, and Bruce A. Wooley, Fellow, IEEE
Abstract
   Two-step flash architectures are an effective means
of realizing high-speed, high-resolution analog-to-digital converters
(ADC’S) because they can be implemented without the
need for operational amplifiers having either high gain or a
large output swing. Moreover, with conversion rates approaching
half those of fully parallel designs, such half-flash architectures
provide both a relatively small input capacitance and low
power dissipation. This paper describes the design of a 12-b, 5-
Msample/s A/D converter that is based on a two-step flash
topology and has been integrated in a l-pm CMOS technology.
Configured as a fully differential circuit, the converter performs
a 7-b coarse flash conversion followed by a 6-b fine flash
conversion. Both analog and digital error correction are used
to achieve a resolution of 12 b. The converter dissipates only
200 mW from a single 5-V supply and occupies an area of
2.5 mm x 3.7 mm.
IEEE JOURNAL OF .SOLID-STATE 12JRcuITs, VOL. 27, NO, 12, DECEMBER 1992
A 12bit 5MSample Two-Step CMOS AD Converter.pdf
1.34 MB, 下载次数: 73 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2006-11-23 20:17:06 | 显示全部楼层
谢谢,楼主了
发表于 2006-11-23 20:25:56 | 显示全部楼层
回复 #2 semico_ljj 的帖子
谢谢了,楼主
发表于 2006-11-23 20:31:47 | 显示全部楼层
多谢了,楼主
发表于 2006-11-24 08:59:07 | 显示全部楼层
En, ..... you're good
发表于 2006-11-25 11:24:08 | 显示全部楼层
发表于 2006-12-9 21:15:52 | 显示全部楼层
好的,谢谢了
发表于 2006-12-28 21:22:15 | 显示全部楼层
谢谢了,先看看
发表于 2006-12-28 21:23:08 | 显示全部楼层
全是公式的东西啊
GMT+8, 2025-12-30 05:08 , Processed in 0.025891 second(s), 7 queries , Gzip On, Redis On.
