楼主 |
发表于 2012-1-28 23:54:35
显示全部楼层
[user@edasever ictemp3]$ encounter
Checking out Encounter license ...
Encounter_Digital_Impl_Sys_XL 10.1 license checkout succeeded.
**ERROR: (ENCOAX-124): OA installation is older than the one this Encounter ver sion was built with. To use the OA installation built and tested with this Encou nter version you should unset the shell variable OA_HOME, or point OA_HOME to a 'p011' or higher version of OA and rerun.
**ERROR: (ENCOAX-332): Failed to initialize OA database. OA related commands ca n not be run. Refer to any earlier error messages.
INFO: OA features are disabled in this session.
* Copyright (c) Cadence Design Systems, Inc. 1996 - 2011. *
* All rights reserved. *
* This program contains confidential and trade secret information *
* of Cadence Design Systems, Inc. and is protected by copyright *
* law and international treaties. Any reproduction, use, *
* distribution or disclosure of this program or any portion of it,*
* or any attempt to obtain a human-readable version of this *
* program, without the express, prior written consent of *
* Cadence Design Systems, Inc., is strictly prohibited. *
* Cadence Design Systems, Inc. *
* 2655 Seely Avenue *
* San Jose, CA 95134, USA *
@(#)CDS: Encounter v10.12-s213_1 (32bit) 09/14/2011 18:36 (Linux 2.6)
@(#)CDS: NanoRoute v10.12-s013 NR110830-1854/10_10_USR2-UB (database version 2.3 0, 124.2.1) {superthreading v1.15}
@(#)CDS: CeltIC v10.12-s211_1 (32bit) 08/31/2011 23:35:43 (Linux 2.6.9-89.0.19.E Lsmp)
@(#)CDS: AAE 10.12-s002 (32bit) 09/14/2011 (Linux 2.6.9-89.0.19.ELsmp)
@(#)CDS: CTE 10.12-s010_1 (32bit) Jul 18 2011 23:05:29 (Linux 2.6.9-89.0.19.ELsm p)
@(#)CDS: CPE v10.12-s009
--- Starting "Encounter v10.12-s213_1" on Sat Jan 28 10:38:01 2012 (mem=45.9M) - --
--- Running on edasever (i686 w/Linux 2.6.9-78.ELsmp) ---
This version was compiled on Wed Sep 14 18:36:10 PDT 2011.
Set DBUPerIGU to 1000.
Set net toggle Scale Factor to 1.00
Set Shrink Factor to 1.00000
encounter 1>
这个 OA干什么的呢 如何设置 如何合并OA目录 。 还有安装encounter的时候 如何 如何办?
他们的OA版本不同 615是 oa_v22.41.004 encounter10 oa_v22.41.011
如何办呢?
http://bbs.eetop.cn/viewthread.php?tid=316964&extra=&highlight=encounter&page=1
如果把OA变量 的目录设置为 encounter10 oa_v22.41.011 则是不会报这个错误的 |
