查看: 4131|回复: 8
[求助] Modelsim 仿真遇到的问题
发表于 2012-1-14 20:31:14 | 显示全部楼层 |阅读模式
鄙人使用Modelsim仿真简单的verilog代码,以前一直挺正常,可是最近仿真的时候,编译成功后,进行simulate却一直在loading状态,也不出波形,半天后出现一个Error:Failed to start simulation kernel的错误信息。请各位高手予以指点,不胜感激!
发表于 2012-1-15 12:56:04 | 显示全部楼层
是否尝试过重新安装?另外以前和现在的电脑环境变化大吗?是否同一台电脑?
发表于 2012-1-17 15:31:43 | 显示全部楼层
哪个版本?
发表于 2012-1-20 11:23:44 | 显示全部楼层
感謝大大無私的教學
发表于 2012-3-4 10:55:28 | 显示全部楼层
呵呵,用好modelsim其实就是安装环境要正确,license要对,还有和别的软件连用一定要编译库。
   这些做好了应该没有问题了
发表于 2012-3-4 11:52:21 | 显示全部楼层
建议重装
发表于 2013-12-2 17:57:37 | 显示全部楼层
K, i found the reason.
vsimk.exe was blocked from connecting to the internet, this caused it to throw that error. as soon as i stop enabling all in my firewall it crashes.
this is strange, because it was working fine for about 3 months when i had no internet on the machine. anyways, hope this helps someone.
发表于 2013-12-2 20:18:25 | 显示全部楼层
回复 7# eaglefanxp
    这个原因还真是有意思
发表于 2013-12-26 15:07:20 | 显示全部楼层
顶一个
GMT+8, 2025-12-15 13:50 , Processed in 0.024287 second(s), 8 queries , Gzip On, Redis On.
