查看: 12790|回复: 35
[资料] ESD protection diodes for high-speed IO applications
发表于 2012-1-12 13:45:38 | 显示全部楼层 |阅读模式
Study of intrinsic characteristics of ESD protection diodes for high-speed I/O applications
a b s t r a c t
To meet the desired electrostatic discharge (ESD) robustness, ESD diodes was added into the I/O cells of
integrated circuits (ICs). However, the parasitic capacitance from the ESD diodes often caused degradation
on circuit performance, especially in the high-speed I/O applications. In this work, two modified layout
styles to effectively improve the figures of merits (FOMs) of ESD protection diodes have been
proposed, which are called as multi-waffle and multi-waffle-hollow layout styles. Experimental results
in a 90-nm CMOS process have confirmed that the FOMs (RON  CESD, ICP/CESD, VHBM/CESD, and ICP/ALayout)
of ESD protection diodes with new proposed layout styles can be successfully improved.
2011 Elsevier Ltd. All rights reserved.
abbr_06505abd16c252135298607bf1fa391f.pdf
2.86 MB, 下载次数: 463 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2012-1-12 20:07:06 | 显示全部楼层
Thanks for your sharing!
发表于 2012-1-12 23:27:06 | 显示全部楼层
Thanks!
发表于 2012-1-13 01:07:03 | 显示全部楼层
Good ESD paper from Dr. MD Ker
Thanks for sharing
发表于 2012-1-13 09:03:29 | 显示全部楼层
福昕阅读器打不开,一Open就退出???
发表于 2012-1-13 09:13:51 | 显示全部楼层
 楼主| 发表于 2012-1-13 09:28:02 | 显示全部楼层
回复 6# 过路心客
好像没有这个问题啊
发表于 2012-1-14 14:01:23 | 显示全部楼层
good!
发表于 2012-1-16 19:15:28 | 显示全部楼层
公司的福昕阅读器有问题,打不开,拿回家就好了。
谢谢!
发表于 2012-1-16 20:25:34 | 显示全部楼层
thanks!
GMT+8, 2025-12-26 08:48 , Processed in 0.021144 second(s), 5 queries , Gzip On, Redis On.
