查看: 7230|回复: 23
[原创] Berkeley 2012 博士论文 On-chip Benchmarking and Calibration
发表于 2012-1-10 01:55:32 | 显示全部楼层 |阅读模式
Contents
1 Introduction ....................................................................................................... 1
2 Background ....................................................................................................... 3
2.1 Component Variation .................................................................................................... 3
2.1.1 Gaussian Distribution .......................................................................................... 3
2.1.2 Yield .................................................................................................................... 4
2.2 External References ...................................................................................................... 5
2.2.1 External Crystal Oscillators ................................................................................. 5
2.2.2 External Precision Resistors ................................................................................ 5
2.2.3 External Constant Current Source ....................................................................... 5
2.3 Internal References ....................................................................................................... 6
2.3.1 On-chip MOM capacitors .................................................................................... 6
2.3.2 On-chip MOS capacitors ..................................................................................... 6
2.3.3 On-chip Polysilicon resistors ............................................................................... 6
2.3.4 On-chip Inductors ................................................................................................ 6
2.4 Existing Research without External References ........................................................... 7
2.4.1 Bandgap Voltage Reference Generation without Resistor .................................. 7
2.4.2 Current Reference Generation without Resistor .................................................. 7
3 Theory of Benchmarking .................................................................................. 9
3.1 Motivation ..................................................................................................................... 9
3.2 Internal Reference Component ..................................................................................... 9
3.3 Benchmarking Metric Measurement Module ............................................................. 11
3.4 Calibration using Benchmark Values ......................................................................... 17
3.5 Other Examples of BMMM ........................................................................................ 26
3.6 Summary ..................................................................................................................... 30
4 Experimental Prototype .................................................................................. 31
4.1 RC Time Constant Measurement Module (RCMM) .................................................. 31
4.1.1 Architecture ....................................................................................................... 31
4.1.2 Lambda Calibration without an external reference ........................................... 32
4.1.3 Lambda Calibration with an external reference ................................................ 33
4.2 FM Power Amplifier as Demonstration Vehicle ........................................................ 35
4.2.1 Capacitor Bank Tuning ..................................................................................... 35
4.2.2 FMPA Circuit Topology ................................................................................... 36
4.3 Simulation results ....................................................................................................... 39
4.3.1 Process Corner Definition ................................................................................. 39
4.3.2 Harmonic Distortion and Calibration Effect ..................................................... 39
4.3.4 Analysis of Error Sources .................................................................................. 42
4.3.5 Gain code sweep ................................................................................................ 44
5 Measurement ................................................................................................... 45
5.1 Measurement Method ................................................................................................. 45
5.1.1 Test Board ......................................................................................................... 45
5.1.2 Resistor Divider Measurement Method ............................................................. 46
5.1.3 High Pass Filter Measurement Method ............................................................. 46
5.2 Measurement Results .................................................................................................. 48
5.2.1 Harmonic Distortions of 112 dBuVrms output voltage..................................... 48
5.2.2 Harmonic Distortions of 117 dBuVrms output voltage..................................... 52
5.2.3 Output Voltage (Fundamental Tone) Variation ................................................ 54
5.2.4 Qualify Factor Measurement ............................................................................. 56
6 Conclusion ...................................................................................................... 59
6.1 Summary ..................................................................................................................... 59
6.2 Future Work ................................................................................................................ 59
Bibliography ....................................................................................................... 61
PhD On-chip Benchmarking and Calibration without External References(Berkeley, 2012).pdf
1.64 MB, 下载次数: 389 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2012-1-10 08:14:00 | 显示全部楼层
Thanks for your sharing!
发表于 2012-1-10 09:37:31 | 显示全部楼层
thanks ~
发表于 2012-1-10 13:15:55 | 显示全部楼层
谢谢分享,这种论文看看满好的
发表于 2012-1-10 13:36:38 | 显示全部楼层
谢谢分享,这种论文看看满好的
发表于 2012-1-10 15:46:23 | 显示全部楼层
thank you
发表于 2012-1-10 17:04:26 | 显示全部楼层
学习了!
发表于 2012-1-11 15:34:06 | 显示全部楼层
实践性很强的文章!
发表于 2012-1-11 21:18:16 | 显示全部楼层
thanks
发表于 2012-1-11 21:20:14 | 显示全部楼层
Thanks!
GMT+8, 2025-12-17 17:21 , Processed in 0.020483 second(s), 4 queries , Gzip On, Redis On.
