查看: 4296|回复: 12
[资料] Multimedia Multiprocessor Systems Analysis Design and Management
发表于 2012-1-3 16:18:54 | 显示全部楼层 |阅读模式
多媒体多核处理器
Multimedia Multiprocessor Systems Analysis Design and Management.rar (3.71 MB , 下载次数: 154 )
http://www.amazon.com/Multimedia-Multiprocessor-Systems-Analysis-Management/dp/9400700822
Multimedia Multiprocessor Systems: Analysis, Design and Management (Embedded Systems) [Hardcover]
Akash Kumar (Author), Henk Corporaal (Author), Bart Mesman (Author), Yajun Ha (Author)
Book Description
ISBN-10: 9400700822 | ISBN-13: 978-9400700826 | Publication Date: September 23, 2010 | Edition: 2010
Modern multimedia systems are becoming increasingly multiprocessor and heterogeneous to match the high performance and low power demands placed on them by the large number of applications.
The concurrent execution of these applications causes interference and unpredictability in the performance of these systems.
In Multimedia Multiprocessor Systems, an analysis mechanism is presented to accurately predict the performance of multiple applications executing concurrently.
With high consumer demand the time-to-market has become significantly lower.
To cope with the complexity in designing such systems, an automated design-flow is needed that can generate systems from a high-level architectural description such that they are not error-prone and consume less time.
Such a design methodology is presented for multiple use-cases -- combinations of active applications.
A resource manager is also presented to manage the various resources in the system, and to achieve the goals of performance prediction, admission control and budget enforcement.
发表于 2012-1-3 23:42:03 | 显示全部楼层
回复 1# brandnew99
THANK YOU VERY MUCH
发表于 2012-1-4 06:24:13 | 显示全部楼层
Is it new ?
发表于 2012-1-4 10:43:55 | 显示全部楼层
高级啊,顶起,建议下载学习。
发表于 2012-1-4 12:24:38 | 显示全部楼层
tks a lot
发表于 2012-1-4 12:26:04 | 显示全部楼层
tks a lot
发表于 2012-1-8 19:00:20 | 显示全部楼层
书还是文章啊?
发表于 2012-7-26 09:29:39 | 显示全部楼层
tks alot i need this
发表于 2013-1-6 23:58:06 | 显示全部楼层
回复 1# brandnew99
    aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
发表于 2013-5-27 08:24:02 | 显示全部楼层
谢谢楼主
GMT+8, 2025-12-22 08:18 , Processed in 0.028224 second(s), 6 queries , Gzip On, Redis On.
